[ST Edge] Driver for GE/Jasco/Honeywell Z-Wave Switches, Dimmers, Fans, Outlets, and Plug-Ins
This is an Edge driver for GE/Jasco/Honeywell Z-Wave switches, dimmers, fans, outlets, and plug-ins, covering the range of generations from the legacy non-Plus devices to the current Z-Wave Plus devices with central scene support. Depending on the capabilities of the particular model, the driver supports:
  • Setting configuration parameters
  • Adding nodes to association groups 2 (load) and 3 (double tap)
  • Double/triple tap button events
  • Hub is automatically added to association group 3 for models that support double tap but do not support central scene
The list of fingerprints currently included can be found here. If you have a model that’s not included, let me know and I’ll look into adding it.
To install:
Use the following link to enroll in the channel and install the driver on your hub: Channel Invitation
If your device is already using an Edge driver, you can use the driver utility in the app to switch drivers.
If your device is currently using a Groovy DTH, you will need to exclude and then add it back to SmartThings to pick up this driver. If you have any custom Groovy DTHs installed that have the device’s fingerprint, either delete the DTH or comment out the fingerprint before attempting to re-join the device.
Code:
[ST Edge] Driver for GE/Jasco Z-Wave Motion Switches and Dimmers - 24770, 26931, 26932, 26933
GE ceiling fan switch
Can’t for the life of me to get the LED indicator working on my Jasco Zwave Plus fan control
Hub Connected Devices Now Use Edge Drivers
GE zwave switch - placeholder?
Add Support for GE ZW4101 (aka Jasco) Appliance Module
Double Tap event
GE light switch Z-Wave device time
GE switches stopped working (April 2023)
Z-Wave Switches Mirror Each Other?
Switches no longer working after Edge migration
Device routines and "local" vs. "cloud" execution
Use Z-wave wall switch for routine to control Enbrighten 40amp Z-Wave Direct-Wire Smart Switch?
Dimmers for New Construction?
GE plug in wireless Zigbee smart switch
Trouble adding old Aeon DSC06106-ZWUS device
LED Settings for Enbrighten Toggle Switch Missing
Jasco/GE Dimmers stopped 'remembering' last setting since migration to stock Edge Driver
Edge Drivers for old zwave devices?
GE Switch Double Tap?
100% light level between 2 programmed level after Feb 2023 update
Post Requests for Zwave Edge Drivers Here (community-created)
Strange New Flickering of Devices on Dimmers
GE Jasco Fan Switch - Can’t Control Speed via Alexa/Google Anymore
In Desperate Need of Help! (Delays, random on, incorrect app state, etc)
Change DTH to edge driver
Z-wave devices just stopped working throughout the house (14 Feb 2023)
No neutral switch for bulbs that require ELV dimmer?
Can't Connect New Devices
GE ZWave suddenly disappeared
Multiple Devices Offline Since Mid July
SmartThings Hub V3 vs Wink and a Lutron Question
Bug in Routine with Period of Time based on Sunset?
Cannot add devices, suddenly
[OBSOLETE] GE/Jasco Z-Wave Plus Dimmer Switch With Double-Tap
Update on Groovy Platform Migrations
[OBSOLETE] GE/Jasco 46201 On/Off Switch
GE Smart Dimmer ZW3106 (plugin adapter): independently control two sockets?
[OBSOLETE] Jasco/GE Z-Wave Plus On/Off Switch (14291) With Double-Tap and Associations
[ST Edge] Hampton Bay / King of Fans Zigbee Fan Controller
Jasco 14285 40-Amp Outdoor Switch and power metering
[OBSOLETE] GE Motion Switch (26931) and Motion Dimmer (26933)
[ST Edge] vEdge Creator: a virtual device generator for end users
Buttons not showing up for GE 14294 under "If" routine condition
Jasco 46202 toggle lost control of LED in toggle
Need help switching driver for new Jasco (embrighten) to fan (from switch)
SmartThings extreme delay
[Request] DH request for GE Jasco Switch 52252
[ST EDGE] Enhanced Z-Wave Fan Controller
Z-Wave Fan Controllers with Alexa Speed Control? (2023)
Change setting: Blue light on when light is off [and blue light off when light is on]
Zwave ultrapro Dimmer Control?
Z-wave repair missing in Web portal and not working on app
Will there be Edge Drivers for GE Jasco/Enbrighten lights/dimmers?
All Z-wave devices stopped working - Help!
Hub Problems, Replacement?
Z-Wave Dimmer identifying as a Switch after conversion
Turn on a GE light-switch without setting the DIM% value, after motion is detected, how?
[ST Edge] GE/Jasco Zigbee Switches and Dimmers
Enbrighten switch drivers?
Will the Enbrighten Z wave Smart Switch be compatible with the ongoing updates?
Cannot control both switches in a GE ZW4105 2-switch plug in outlet
GE Enbrighten Z-Wave Plus Smart Light Dimmer custom options
Ultra Pro Z-wave switch Edge driver?
Thanks for developing and sharing. I will give it a try.
EDIT: I have 2 GE switches working using this driver and they are working fine. One is an older 14292 and one is a newer 46201.
I have a 14294 and its working perfectly , doubble tap work.
I already set like i want .
Will let you know if i found something.
Thank you @philh30
Is yours the toggle (46202) or paddle (46201)? I’m trying to track what’s verified as working and realized I had both set to be named 46201 when joined.
The 46201 is the paddle style.
Wouldn’t (shouldn’t) Smartthings be making edge drivers for these switches? I have way too many on these, and no desire to remove and rejoin them, and then redo the automation.
At some point ST will transition your devices to Edge drivers without requiring any action on your part - no exclude/include. The process should be seamless for you, and they’ll map your devices to an appropriate stock driver. It’s completely ok to wait for ST to transition your devices, since that should be less disruptive for you.
ST has written an Edge driver for z-wave switches, and if you wait then that will likely be what your GE switches are mapped to. In its current state, that driver has all the basic functionality covered, but none of the additional features like configuration parameters, association, or double tap. After the transition, you’ll be able to swap drivers just like you can swap DTHs, and there may be other community options to choose from by then.
@philh30
Could you add the following relay to your driver. It currently uses the “Z-wave switch generic” DTH.
@philh30
Would LOVE to see the Motion DImmer switches family (26931/26933) added!
@Paul_Oliver My intended scope for this driver is just the Jasco-made devices. I’ll follow up via PM.
I actually just ordered one of the motion switches after seeing the rave reviews from @nathancu. Should be here tomorrow, so stay tuned.
I have a couple of recently purchased Jasco in wall outlets: mfr:0063 prod:4952 model:3233
Added. I couldn’t find anything on that model, but I found 3235 which supports central scene. I’ve put yours in the central scene profile assuming it’s the same. The choice of profiles only matters for the button events (which you may not care about on an outlet) so if you find that double tap isn’t working I can shift it to a different profile.
I recently asked about this, and the answer I received is that there is a difference in this regard between groovy DTHs and edge drivers.
With a groovy DTH, you can just manually assign it to any DTH you want.
With an edge driver, the fingerprint of that specific device must be listed in the driver, or the driver must’ve been written to specifically accept a generic pairing, which not all do.
Hard to tell how much of an issue this will be once everything goes live, but I just thought I’d mention it.
So while this transition from groovy DTHs to Edge Drivers is going on, how can I tell while devices are using DTHs and which are using Edge Drivers?
@damohabir If you log into the Groovy IDE and list your devices, those devices using a driver will be of type “placeholder”. Alternatively, if you list your devices using the CLI, those using a device handler will be type “DTH” while those using a driver will be type “ZWAVE”.
When the device is open in the app click on the 3 dots on top right corner. If driver is an option it is using an Edge Driver.
I know the IDE will list device fingerprints for all devices that use a DTH. Is there an equivalent in the CLI yet? I have a few devices that were initially added with the samsung generic switch driver, and I’m not sure how to view the fingerprint.
Also, what should the hexid be in devices that are using drivers? A device network ID is no longer shown in the IDE.
If you use the -y or -j flags when running devices in the CLI then you’ll get a lot more info, including the fingerprint and network ID.
I had some time today, and I wanted to see what it is like to install an edge driver. So I decided to install this one and change one switch over to use the driver. I was pleasantly surprised at how easy it was to install. So now I have one switch using this driver. However, IDE is showing that this is now “cloud” execution instead “local” execution. Did I do something wrong?
Name ge-switch-legacy
Label Basement Light
Type placeholder
Version Published
Status ONLINE
Group Basement
Last Activity At 2021-12-29 11:13 AM EST
Date Created 2021-12-29 11:10 AM EST
Last Updated 2021-12-29 11:12 AM EST
Data No data found for device
Current States No states found
Execution Location Cloud
