Phil hasn’t done any work on his drivers in several years and doesn’t support newer devices. @csstup took up support for Phil’s drivers and consolidated all the GE/Jasco into a single driver. You should install his Z-Wave Switch CS driver from his channel here. If your device’s fingerprint is not supported in his driver, post a request here.
EDIT:
If your device fingerprint is this:
- id: “0063/4944/3138”
deviceLabel: GE Fan 14314
manufacturerId: 0x0063
productType: 0x4944
productId: 0x3138
Corey’s driver will support it with these capabilities:
components:
- id: main
capabilities:
- id: switch
version: 1
- id: switchLevel
version: 1
- id: fanSpeed
version: 1
- id: firmwareUpdate
version: 1
- id: refresh
version: 1
categories:
- name: Fan
metadata:
deviceType: Fan
ocfDeviceType: oic.d.fan
deviceTypeId: Fan
vid: 12a872c0-6b74-3e99-ace1-2ff81e1f283b
mnmn: SmartThingsCommunity
preferences:
- title: "LED Indicator"
description: "Turn LED indicator on"
required: true
preferenceType: enumeration
definition:
options:
0: "Turn on when switch is on"
1: "Turn on when switch is off"
2: "Always off"
default: 0
- title: "Invert Switch"
description: "Invert switch"
required: true
definition:
options:
0: "No"
1: "Yes"
default: 0
