Introducing the Ring Keypad edge driver
Make your Ring Alarm Gen2 keypad work like a security keypad or virtual lock keypad in SmartThings to manage locks/doors/garage doors, user codes etc through Automations. (see below for more details). It makes an excellent doorbell chime with 5 tones to choose from with an option to select a different chime for each door. It even has a spoken countdown for entry/exit delays. You can also use to control Home Monitor with two synchronization.
Screenshots
Security Keypad + Virtual Lock (with programmable codes)
Other Features
Automation Features
Classic App
Where to buy Ring Alarm 2nd Generation keypad
- Amazon (~$48) with wall mounting plate
- Best Buy (~$50)
- Home Depot (~$50)
- Ring (~$50)
This edge driver supports the following features (refer to the release notes/website for latest updates):
- Selectable operating modes (enable/disable integration with Home Monitor)
- Security keypad + Virtual lock with programmable codes
- Virtual lock with programmable codes
- Works as a keypad lock in SmartThings
- Set/use 4-10 digit codes
- View programmed user names/codes
- Enable/disable keypad
- Enable/disable auto lock
- Lock and unlock using user codes
- Invalid code notifications
- Direct arming (arm directly with buttons without user code)
- Assign dedicated or toggle action (disarm/arm stay/arm away) to √ button
- Detect Main/Battery power
- Battery level
- 3 buttons reporting for Police, Fire and Medical emergencies
- Panic button (press X and √ simultaneously)
- Use with Automations
- Door bell
- Custom ringtones
- Security mode
- Lock state
- User code/name specific actions separately for arming away/arming stay/disarming/locking/unlocking
- Panic alarm
- 4 separate emergency buttons (panic, police, fire, medical)
- Invalid code, lock/unlock action type (remote, keypad) custom actions
- Battery levels
- Power source
- Dimmer
- Hardware failure notifications
- Use as a Tone capability device (beep/chime)
- Use as a Siren/Alarm capability device (supported models)
- Locate keypad using a beep
- Spoken countdown for entry/exit delays
- Ability to configure the following parameters:
- Choose from 5 chime/ring tones to play
- Pin code length
- Pin code timeout
- Auto lock delay
- Enable/disable direct arming
- Announcement volume
- Emergency buttons press duration (seconds)
- Ambient light sensor sensitivity
- Enable/disable proximity sensor
- Backlight dimmer
- Disable alarms for emergency buttons (to use automations)
Compatible SmartApps
- Smart Lock Guest Access (SLGA)
- Advanced Web UI
- Lock User Management (LUM) to control STHM from the keypad using virtual switches
- Rental Lock Automater (RLA) to automate your rental properties with keypads
- Lock & Door Synchronizer to control Garage Doors, Patio Doors and synchronize with other locks/devices
- Chime and Notifications for Doorbells and Sensors to play a custom door chime
- Security System - Intruder Alerts with Actions to create a custom security system with entry/exit delays and custom arming scenarios
Siren and Chime Features
- Built in beeper which can be used as a Chime for sensors/buttons (e.g. door bells or door open/close) using the Beep or Tone capability
- Built in Siren that can be triggered with the emergency buttons or independently as an Alarm. The alarm sound can be adjusted from about 60dB to 110dB
- You can use these keypads with SmartThings automations or a compatible Chime SmartApp
Sample Use Cases for Keypads in SmartThings (through Automations or compatible SmartApps)
- Siren/alarm (models which support it)
- Chime/beeper to notify when doors/windows are opened/closed
- 4 panic buttons
- Secondary keypad for locks
- Primary keypad for garage doors/patio doors
- Program codes and create custom actions for each code or each button (away/night/home)
- Run/activate/deactivate switches/controls/routines etc
- Create custom actions
- Arm/disarm Home Monitor/Hub modes
- Chime the keypad when doors/windows are opened or something is turned on/off
INSTALLATION INSTRUCTIONS
Install the edge driver using the step by step instructions here
INCLUSION
It is recommended to install the edge driver BEFORE paring the device for easier setup.
- Bring the keypad close to the hub
- Plug the USB cable into a USB charger, this is make the Network LED start flashing green slowly (make sure it’s flashing green otherwise do a factory reset or device exclusion, see below)
- From the SmartThings mobile app click on + → Add device → Scan QR code and then scan the QR code behind the keypad. NOTE: If you don’t use S2 pairing via the QR code, the keypad may have trouble communicating with the hub (red network light, key codes not working etc)
- Keep the
1key pressed for about 5 seconds until the Network LED starts flashing green quickly and then release the key
TIPS
- This keypad supports S2 level security and performs better when using S2 mode. If the device pairs but SmartThings gives you a message about reduced security, exclude the device and pair it again using the QR code until pairs successfully without any error messages
- If you’re having trouble pairing the device, power cycle your hub and try to exclude the device first
- If Network LED starts flashing red, this means that the keypad has lost it’s connection with the mesh. Move the keypad closer to the hub (or add a Z-Wave repeater)
- If Network LED is flashing green, that means it isn’t paired with the hub
EXCLUSION
- Bring the keypad within 5ft of the hub
- Put the hub into Exclusion mode
- Use a pin to press the button in the hole behind the keypad, the network LED should flash red to indicate the exclusion was successful and then start flashing green
FACTORY RESET INSTRUCTIONS
- Use a pin to press the button in the hole behind the keypad for about 10 seconds until the network LED flashes red and then starts flashing green slowly
Arming/Disarming the keypad
- Program the user codes using a supported app like Smart Lock Guest Access (SLGA), Advanced Web UI , LUM, RLA
- Enter a valid code followed by one of the 3 modes buttons on top (Disarm, Arm Stay or Arm Away)
NOTE:
Lockedmeans the keypad isArmedandUnlockedmeans that it’sDisarmed.- Since the device has no “physical” locking mechanism, it is recommended to use it in conjunction with Automations or SmartApps like SLGA, LUM or RLA to control a physical switch or lock etc.
- When set to arm directly, it does not use a code to arm to Away or Stay
Low Battery: If your battery falls below 20% consider charging it. The unit will start flashing a battery light when the battery level is low.
Home Monitor (HM) Synchronization
- It should automatically sync with Home Monitor (two way)
- Try to uninstall and reinstall Home Monitor from the Life tab. Reinstalling usually resolves the issue.
- Check that Home Monitor Integration option is enabled in the keypad settings page.
- Check that the keypad is selected in the Home Monitor → Settings (gear icon) → Security → Devices linked to security mode
Comparison of Keypad Features
Check out the Ring Gen1 Keypad Edge Driver
Check out the ZigBee Keypad Device Handler
More features to added, if you have any suggestions or ideas please feel free to ask and we’ll try to add it.
This driver is available on the RBOY APPS Server, http://www.rboyapps.com. Refer to our website or facebook page below to get access to the server.
Visit our Facebook page for updates on new apps and to get access to our Premium Apps. http://www.facebook.com/RBoySTApps
(c) RBOY APPS
