5ZVP
March 3, 2024, 7:14pm
1
I have a ST Hub v3 and want to add the Ring Kepad Gen 2. I read that I needed to add the edge driver to have access to many of the features. Is this still true? TIA
Barkis
(John C)
March 3, 2024, 7:56pm
2
There have been several threads lately that address the Ring Keypad. Perhaps they will answer your questions. Here’s one to get you started…
I have created an Edge driver for the Ring Keypad 2nd Gen.
[image]
You can find the source code here: https://github.com/hmorsti/SmartThingsEdgeDrivers/tree/main/drivers/SmartThings/zwave-keypad
Here are some features:
setting the PIN code for the “disarm” and “arm home” buttons (you can set an empty PIN too)
the PIN code can handle long pressed digits - they are then mapped to the letters:
1-9 is mapped to A-I
0 is mapped to “@”
wrong PIN signal
motion sensor
power source indication
most alarms support strobe only and some support siren only
panic combination (hold simultaneously “X” and “Check” buttons)
doorbell with selection of 5 sounds
entry and exit delay counters
most configuration options were mapped in the settings
Due to the limit of 20 components per device I commented…
Yes, at the time of this posting you will need a custom edge driver.
There are two choices now available.
One was created by a community member and is freely available to anyone who wants to try it.
Another more sophisticated one with a number of additional features is available as part of a paid license from Rboy apps.
You can find author threads for both on the “edge_security“ Quick browse list.
FAQ: Using the quick browse lists without the community wiki
Choice is good.
5ZVP
March 4, 2024, 3:02am
4
Thank you. That was very helpful.
RBoy
July 16, 2024, 3:33pm
5
If you have access to RBOY APPS, try this driver. It’s fixed many issues the keypad had with the new platform and adds more features the keypad can use with the new platform
