Ring Keypad
Hello all.
With smartthings removing support for the LUM smartapp, has anybody found a way to make the ring keypad work with the system?
Thank you,
Mike
Welcome! In the future, you can check the quick browse lists in the community-created wiki. In this particular case, the edge driver for the ring keypad is included on both the security list and the “remotes/buttons“ list. :sunglasses:
https://thingsthataresmart.wiki/index.php?title=Quick_Browse_Lists_for_Edge_Drivers
I looked at this but have no idew what to do
The community FAQ should answer most of your questions:
FAQ: I have no idea what Edge is. Is that a new developer tool? (2022)
I am currently using the hmorsti driver which yours seems to be but it does not work with the pincode i set in settings.
Best to post in the topic for the driver so the author will be notified and can take a look at what might be happening.
Try this, it allows for programmable codes, custom actions (which replicates a lot of LUM functionality) and also for direct integration with home monitor.
