(EDGE Driver-Mc) Zigbee switch MC, Zigbee switch power MC, Zigbee multi switch and child MC
(NEW RELEASE) Version 5 of the Edge Beta Driver: Zigbee Switch Mc
As this driver has many users I have put it in a new separate thread
Link to original thread:
https://community.smartthings.com/t/beta-zigbee-edge-driver-compatible-with-lidl-ecosmart-osram-smartthings-others/231689?u=mariano_colmenarejo
Improvements:
At the request of @milandjurovic71 , one of his many good ideas, Add to devices a simulated meter of power and energy consumption.
  • Added Capability PowerMeter:
    • Displays the rated power entered in preferences, when device is On
    • The standard graph shows the consumption in each hour or day
  • Added Capability EnergyMeter:
    • Displays the energy consumption accumulated during the device’s operating time (On)
    • The Standard Graph shows the accumulated Energy meter by hour or days of the last month
  • Added Custom Capability to Reset Energy Meter Accumulated Value:
    • The switch always gets into On state (blue)
    • When device is first installed, it displays the installation date.
    • when you run a Energy reset it displays the current date as the last reset
  • Added in Preference the setting to enter the Rated Power in W of the load connected to the device:
    • Power range between 0 w and 4000 w
    • If 0 w is entered , the power calculation and power and Energy consumption function is disabled. The accumulated values are not deleted.
As the driver has a new Capabilities, profiles and changes in preferences the update will not be done automatically .
To facilitate the update, I am going to change driver version 4.0 to the name Zigbee Switch Mc- (OLD).
I will publish the new version 5 with the original name Zigbee Switch Mc
In this way, your driver installed will renamed with (OLD), indicating that there is a new version available and you can install the new version with a driver change whenever you want.
Link to Devices supported Zigbee Switch Mc
Link to Devices supported Zigbee Switch Power Mc
Link to Devices supported Zigbee Multi Switch and Child Mc
Everything is tested, in my devices or other user devices
This is the invitation link to the channel:
SmartThings. Add a little smartness to your things.
As some users have asked me, if you find these Mc drivers useful and wants to invite me to a coffee , Thanks
Using IFTTT, virtual switch and automation, Power consumption can be reset on specific date
Did you clear the cache? This has a new capability.
Don’t have the - (OLD) in your Hub?
Do you want me to publish it for you to try?
@milandjurovic71, @fido
Good and bad news
Power and energy events can be captured in a google sheet with the smart app simple event logger.
With this you can perform calculations by device, periods, totals …
The bad news is that this app is groovy.
Date/Time Device Event Name Event Value Description
30/12/2021 19:19:58 Lidl Plug energy 0.06785 0.06785 kWh
30/12/2021 19:19:55 Lidl Plug power 150 150 W
30/12/2021 19:19:52 Lidl Plug energy 0.067725 0.067725 kWh
30/12/2021 19:19:52 Lidl Plug power 0 0 W
30/12/2021 19:16:33 Puerta Sotano temperature 14.3 14.3 C
30/12/2021 19:16:11 Termostato temperature 20 20.0 C
30/12/2021 19:14:54 Sensor Mov-3 temperature 16 16.0 C
30/12/2021 19:14:41 Lidl Plug energy 0.06664166667 0.066641666666667 kWh
30/12/2021 19:09:24 Lidl Plug energy 0.06593333333 0.065933333333333 kWh
Hi @Mariano_Colmenarejo all good?
Can you please include these two sockets in the driver with consumption metering?
Metrics
Last Hop LQI: 220
Last Hop RSSI: -45
Received Messages From Device: 5808
Received Messages From Device (Duplicates): 83
Messages Transmitted to Device: 5908
Messages Transmitted to Device (Failures): 2
Updated Time: 2022-01-07 8:41 AM BRT
Date
application: 41
endpointId: 01
manufacturer: _TZ3000_vtscrpmw
model: TS0121
zigbeeNodeType: ROUTER
Raw Description 01 0104 0051 01 06 0000 0004 0005 0006 0702 0B04 02 0019 000A
Metrics
Last Hop LQI: 196
Last Hop RSSI: -51
Received Messages From Device: 5102
Received Messages From Device (Duplicates): 99
Messages Transmitted to Device: 5190
Messages Transmitted to Device (Failures): 0
Updated Time: 2022-01-07 8:42 AM BRT
Date
application: 41
divider: 1
endpointId: 01
manufacturer: _TZ3000_rdtixbnu
model: TS0121
zigbeeNodeType: SLEEPY_END_DEVICE
Added to this driver version
β”Œβ”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”¬β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”
β”‚ Name        β”‚ Zigbee Switch Power Mc               β”‚
β”‚ Version     β”‚ 2022-01-07T14:49:45.515176           β”‚
  - id: "_TZ3000_vtscrpmw/plug"
    deviceLabel: _TZ3000_vtscrpmw plug
    model: TS0121
    deviceProfileName: switch-power-energy
  - id: "_TZ3000_rdtixbnu/plug"
    deviceLabel: _TZ3000_rdtixbnu plug
    model: TS0121
Has anyone tried this Device Handler with the _TZ3000_w0qqde0g TS011F plug?
A couple of links to sellers:
I found the ID in yet another item sold (a picture of the graph from ConBee), but now I can’t find the link to that one anymore.
I have also noted that this plug has a driver for ConBee since end of november. They added it with a bit of problem, some smaller bugs appeared with energy reporting.
Anyways, the form factor of this plug is exactly what I need and it must be ZigBee…
I will order a few and help out testing them, as long as I know that I get help integrating them… :slight_smile:
Hi Mariano,
I have old (2015?) SmartThings Power Plug which I deleted from SmartThings to see if it has Edge driver available. It pairs with wrong driver (Aqara) and does not work, but I was able to get some information about it;
β€œEp#1 device_id:0x0100 profile_id:0x0104 model:β€˜3200-Sgb’ manufacturer:β€˜CentraLite’ Client clusters:[OTAUpgrade, ] Server clusters:[Basic, Identify, Groups, Scenes, OnOff, ElectricalMeasurement, Diagnostics, ]”
Can you please add to your driver and is the information above enough you to do that?
What can be done will be done, but nobody can guarantee anything.
Everything has its risk or buy products certified by smartthings
Added to this driver version of swit with power and energy
I don’t know if it will measure the power and consumption well. Smartthings have made changes in the libraries and I still don’t know what changes they are
β”‚ Version     β”‚ 2022-01-20T15:21:21.794641           β”‚
β””β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”΄β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”€β”˜
  - id: "CentraLite/3200-Sgb"
    deviceLabel: CentraLite Plug
    manufacturer: CentraLite
    model: 3200-Sgb
    deviceProfileName: switch-power-energy-plug
Thank you Mariano,
the driver works with Centralite plug and looks that power reporting is working too.
I ordered two, I will come back when they have arrived from China.
Great improv. Mariano; just updated all my switches to this version. Some got quicker response.
TY!
Hi @Mariano_Colmenarejo, Can you please include these plug in the driver with consumption metering? Thanks
Metrics * Last Hop LQI: 255
  • Last Hop RSSI: -58
  • Received Messages From Device: 55
  • Received Messages From Device (Duplicates): 0
  • Messages Transmitted to Device: 58
  • Messages Transmitted to Device (Failures): 0
  • Updated Time: 2022-01-25 10:12 AM CET
    Data * zigbeeNodeType: ROUTER
  • application: 44
  • endpointId: 01
  • manufacturer: _TZ3000_w0qqde0g
  • model: TS011F
    Raw Description 01 0104 010A 01 09 0003 0004 0005 0006 0702 0B04 E001 E000 0000 02 0019 000A
Hello @Mariano_Colmenarejo
Today within my isolation (covid-yay) i ended up with wiring a ZIGBEE DIMMER MODULE MS-105Z from Moes. No luck with few options tried within Smartthings. Is it possible to add it to your EDGE drives or do i have to look for DTH ?
Data:
  • application: 44
  • endpointId: 01
  • manufacturer: _TZE200_la2c2uo9
  • model: TS0601
  • zigbeeNodeType: ROUTER
Raw Description: 01 0104 0051 01 04 0000 0004 0005 EF00 02 0019 000A
This does not work with my drivers, it does not have the cluster 0006 and 0008.
It uses the TUYA EF00 cluster.
Search the community for Moes cluster EF00 and you will surely find something
β”‚ Version     β”‚ 2022-01-25T13:08:37.698155           β”‚
  - id: "_TZ3000_w0qqde0g/TS011F"
    deviceLabel: TS011F Plug
    model: TS011F
Hello
Is it possible to ad this Blitzwolf SHP13 zigbee plug with
Data
application: 41
divisor: 10
endpointId: 01
firmwareImageType: 5634
firmwareManufacturerCode: 4098
manufacturer: _TZ3000_g5xawfcq
model: TS0121
Regards,
Dusan
Added to this new driver version with Groups functions
β”‚ Version     β”‚ 2022-01-26T18:22:17.045126           β”‚
  - id: "_TZ3000_g5xawfcq/TS0121"
    deviceLabel: TS0121 Plug
    model: TS0121
