[Edge drivers] Issue opening the device's Detail View
@Mariano_Colmenarejo thanks very much for your constant help!
I have bought the Aubess Switch and I have found in the Type a corresponding “Zigbee Metering Plug Power Consumption Report”. My device has:
  • application: 4D
  • endpointId: 01
  • manufacturer: _TZ3000_hdopuwv6
  • model: TS011F
  • zigbeeNodeType: ROUTER
I tried enrolling and installing the Zigbee Switch Mc but I cannot find it anywhere in the Type. I remember enrolling to another repository in the past month. How can I pick you edge driver?
Edit: I think I will be needing to connect to the CLI, right? It cannot be done through the EDI…
@Mariano_Colmenarejo thank you! But how do I enable it? Do I go to the My devices → Device in question → Edit → Type and it will have your type there? I have enrolled and installed the Zigbee Switch Mc but I cannot find it in my api.smartthings.com section… Sorry for the newbie question.
You have to install my Edge driver Zigbee Switch Power Mc.
  • click on this link to roll up your Hub on my Edge drivers shared channel.
    SmartThings. Add a little smartness to your things.
  • Follow the steps to accept and enroll
  • Enter to see the drivers that the channel has and look for the Zigbee Switch Power Mc driver
  • Click on install. The driver will be installed on your Hub
  • In the App add the device with the option to search nearby
  • The device will appear in Unassigned Room
I have done all that but it does not pick your driver.
I understand that in the conf page you can click in the app on the three dots and select the driver you wish, right? The driver option is not shown (I only get Edit and Information) :frowning: In the IDE it is joined as a Zigbee Switch.
By the way, in the IDE, it still says Local in the Execution Location (not sure if this makes sense).
I also have another Osram Lightify SMART+ Plug and there I can go to the three dots and select your driver :wink: (the alternative is Zigbee Switch driver from ST). This is only shown when I pick the custom device handler Type that I had found in these forums. The moment I switch the Type, it is lost :frowning:
@nickolasemp
For Edge drivers, please you forget IDE
Are you installed in your hub the driver Zigbee Switch Power Mc, Version 2022-11-27T16:25:04.092419894 ?
If you have a previous version date of Zigbee Switch Power Mc then wait 12 hours to update to new vesion date
If not, please install it from my channel
Then if driver is installed:
Uninstall your device from App
Add device from App with search nearby option
Device will appears in unassigned room
Update: here is the version
PS C:\Users\nicko\Documents\smartthings> .\smartthings.exe edge:drivers:installed
 #  Name                                    Driver Id                             Version                        Channel Id
 1  Zigbee Sensors Edge Driver [YG] 1.8.16  5ab64dc7-5d08-44a4-9806-5a5b823a18d2  2022-11-02T20:38:55.968069369  14bcc056-f80d-416b-9445-467b0db325e3
 2  Zigbee Switch                           f2e891c6-00cc-446c-9192-8ebda63d9898  2022-11-22T19:58:10.230427939  15ea8adc-8be7-4ea6-8b51-4155f56dc6cf
 3  Zigbee Switch Mc                        bc53adfe-d18f-4ea4-9610-6aade6696b7a  2022-11-22T17:17:32.914130426  c8bb99e1-04a3-426b-9d94-2d260134d624
 4  Zigbee Switch Power Mc                  7fee6e41-26cc-49ef-b1f4-b30a43e02fe6  2022-11-27T16:25:04.092419894  c8bb99e1-04a3-426b-9d94-2d260134d624
and the device pairs?
How do I find the device pairs?
PS C:\Users\nicko\Documents\smartthings> .\smartthings.exe devices
 #   Label                            Name                                      Type     Device Id
 5   Bedroom plug                     Outlet                                    DTH      4098ed98-e276-46f2-b713-7ca9228f460b
@nickolasemp
Perform these steps in App
Yes! After the 3rd time, it picks it up as “Aubess TS011F Plug”.
However, when clicking on the tile, it doesn’t take me anywhere. There is only the on/off button up right on the tile.
I tried removing it again and adding it once more while keeping the log->
connecting… connected
2022-11-27T22:27:17.913440951+00:00 TRACE Zigbee Switch Power Mc Received event with handler device_lifecycle
2022-11-27T22:27:17.932925021+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: ffbeb5a4-8db7-41cc-9c04-76131712372b [0x55F4] (Aubess TS011F Plug)> received lifecycle event: removed
2022-11-27T22:27:17.958542824+00:00 TRACE Zigbee Switch Power Mc Received event with handler driver_lifecycle
2022-11-27T22:27:17.978973034+00:00 TRACE Zigbee Switch Power Mc Found DeviceLifecycleDispatcher handler in Zigbee_Switch
2022-11-27T22:27:17.984870314+00:00 DEBUG Zigbee Switch Power Mc Aubess TS011F Plug device thread event handled
2022-11-27T22:27:17.993187471+00:00 DEBUG Zigbee Switch Power Mc Aubess TS011F Plug device thread event handled
2022-11-27T22:27:21.751723134+00:00 DEBUG Zigbee Switch Power Mc driver device thread event handled
2022-11-27T22:28:44.075995468+00:00 TRACE Zigbee Switch Power Mc Setup driver Zigbee_Switch with lifecycle handlers:
DeviceLifecycleDispatcher: Zigbee_Switch
default_handlers:
removed:
init:
driverSwitched:
doConfigure:
infoChanged:
child_dispatchers:
2022-11-27T22:28:44.082579468+00:00 TRACE Zigbee Switch Power Mc Setup driver Zigbee_Switch with Capability handlers:
CapabilityCommandDispatcher: Zigbee_Switch
default_handlers:
legendabsolute60149.randomOnOff2:
setRandomOnOff
energyMeter:
resetEnergyMeter
legendabsolute60149.getGroups:
setGetGroups
switchLevel:
setLevel
switch:
off
on
refresh:
refresh
child_dispatchers:
2022-11-27T22:28:44.090308468+00:00 TRACE Zigbee Switch Power Mc Setup driver Zigbee_Switch with Zigbee handlers:
ZigbeeMessageDispatcher: Zigbee_Switch
default_handlers:
attr:
ZclClusterAttributeValueHandler: cluster: ElectricalMeasurement, attribute: ACPowerMultiplier
ZclClusterAttributeValueHandler: cluster: ElectricalMeasurement, attribute: ACPowerDivisor
ZclClusterAttributeValueHandler: cluster: ElectricalMeasurement, attribute: ActivePower
ZclClusterAttributeValueHandler: cluster: OnOff, attribute: OnOff
ZclClusterAttributeValueHandler: cluster: SimpleMetering, attribute: InstantaneousDemand
ZclClusterAttributeValueHandler: cluster: SimpleMetering, attribute: Multiplier
ZclClusterAttributeValueHandler: cluster: SimpleMetering, attribute: Divisor
ZclClusterAttributeValueHandler: cluster: SimpleMetering, attribute: CurrentSummationDelivered
ZclClusterAttributeValueHandler: cluster: Level, attribute: CurrentLevel
global:
ZclGlobalCommandHandler: cluster: OnOff, command: DefaultResponse
cluster:
ZclClusterCommandHandler: cluster: Groups, command: GetGroupMembership
zdo:
child_dispatchers:
2022-11-27T22:28:44.185776134+00:00 TRACE Zigbee Switch Power Mc Zigbee Device: cf04ef05-28d1-4e7e-a9b3-e67482e15334
Manufacturer: _TZ3000_hdopuwv6 Model: TS011F
[1]: Identify, Groups, Scenes, OnOff, SimpleMetering, ElectricalMeasurement, 0xE000, 0xE001, Basic [242]:
2022-11-27T22:28:44.197455134+00:00 TRACE Zigbee Switch Power Mc Received event with handler _resync
2022-11-27T22:28:44.202795468+00:00 TRACE Zigbee Switch Power Mc Received event with handler environment_info
2022-11-27T22:28:44.218164468+00:00 DEBUG Zigbee Switch Power Mc driver device thread event handled
2022-11-27T22:28:44.225110468+00:00 TRACE Zigbee Switch Power Mc Received event with handler environment_info
2022-11-27T22:28:44.230330468+00:00 DEBUG Zigbee Switch Power Mc Z-Wave hub node ID environment changed.
2022-11-27T22:28:44.236347468+00:00 TRACE Zigbee Switch Power Mc Found DeviceLifecycleDispatcher handler in Zigbee_Switch
2022-11-27T22:28:44.262528134+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: cf04ef05-28d1-4e7e-a9b3-e67482e15334 [0x2B99] (Aubess TS011F Plug)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x2B99, dest_endpoint: 0x01, profile: 0x0000, cluster: 0x0021 >, < ZDOMessageBody || < ZDOHeader || seqno: 0x00 >, < BindRequest || src_address: A4C138732A3D79D0, src_endpoint: 0x01, cluster: ElectricalMeasurement, dest_addr_mode: 0x03, dest_address: 286D9700020133C2, dest_endpoint: 0x01 > > >
2022-11-27T22:28:44.319844134+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: cf04ef05-28d1-4e7e-a9b3-e67482e15334 [0x2B99] (Aubess TS011F Plug)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x2B99, dest_endpoint: 0x01, profile: 0x0104, cluster: ElectricalMeasurement >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x06 >, < ConfigureReporting || < AttributeReportingConfiguration || direction: 0x00, attr_id: 0x050B, DataType: Int16, minimum_reporting_interval: 0x0001, maximum_reporting_interval: 0x0E10, reportable_change: 5 > > > >
2022-11-27T22:28:44.354851134+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: cf04ef05-28d1-4e7e-a9b3-e67482e15334 [0x2B99] (Aubess TS011F Plug)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x2B99, dest_endpoint: 0x01, profile: 0x0000, cluster: 0x0021 >, < ZDOMessageBody || < ZDOHeader || seqno: 0x00 >, < BindRequest || src_address: A4C138732A3D79D0, src_endpoint: 0x01, cluster: SimpleMetering, dest_addr_mode: 0x03, dest_address: 286D9700020133C2, dest_endpoint: 0x01 > > >
2022-11-27T22:28:44.436731468+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: cf04ef05-28d1-4e7e-a9b3-e67482e15334 [0x2B99] (Aubess TS011F Plug)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x2B99, dest_endpoint: 0x01, profile: 0x0104, cluster: SimpleMetering >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x06 >, < ConfigureReporting || < AttributeReportingConfiguration || direction: 0x00, attr_id: 0x0000, DataType: Uint48, minimum_reporting_interval: 0x0005, maximum_reporting_interval: 0x0E10, reportable_change: 0x000000000001 > > > >
2022-11-27T22:28:44.478737801+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: cf04ef05-28d1-4e7e-a9b3-e67482e15334 [0x2B99] (Aubess TS011F Plug)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x2B99, dest_endpoint: 0x01, profile: 0x0104, cluster: SimpleMetering >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x06 >, < ConfigureReporting || < AttributeReportingConfiguration || direction: 0x00, attr_id: 0x0400, DataType: Int24, minimum_reporting_interval: 0x0001, maximum_reporting_interval: 0x0E10, reportable_change: 5 > > > >
2022-11-27T22:28:44.523710468+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: cf04ef05-28d1-4e7e-a9b3-e67482e15334 [0x2B99] (Aubess TS011F Plug)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x2B99, dest_endpoint: 0x01, profile: 0x0000, cluster: 0x0021 >, < ZDOMessageBody || < ZDOHeader || seqno: 0x00 >, < BindRequest || src_address: A4C138732A3D79D0, src_endpoint: 0x01, cluster: OnOff, dest_addr_mode: 0x03, dest_address: 286D9700020133C2, dest_endpoint: 0x01 > > >
2022-11-27T22:28:44.549155468+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: cf04ef05-28d1-4e7e-a9b3-e67482e15334 [0x2B99] (Aubess TS011F Plug)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x2B99, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x06 >, < ConfigureReporting || < AttributeReportingConfiguration || direction: 0x00, attr_id: 0x0000, DataType: Boolean, minimum_reporting_interval: 0x0000, maximum_reporting_interval: 0x012C > > > >
2022-11-27T22:28:44.570242468+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: cf04ef05-28d1-4e7e-a9b3-e67482e15334 [0x2B99] (Aubess TS011F Plug)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x2B99, dest_endpoint: 0x01, profile: 0x0104, cluster: ElectricalMeasurement >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x0605 > > >
2022-11-27T22:28:44.617097801+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: cf04ef05-28d1-4e7e-a9b3-e67482e15334 [0x2B99] (Aubess TS011F Plug)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x2B99, dest_endpoint: 0x01, profile: 0x0104, cluster: ElectricalMeasurement >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x0604 > > >
2022-11-27T22:28:44.672618801+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: cf04ef05-28d1-4e7e-a9b3-e67482e15334 [0x2B99] (Aubess TS011F Plug)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x2B99, dest_endpoint: 0x01, profile: 0x0104, cluster: SimpleMetering >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x0302 > > >
2022-11-27T22:28:44.756140135+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: cf04ef05-28d1-4e7e-a9b3-e67482e15334 [0x2B99] (Aubess TS011F Plug)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x2B99, dest_endpoint: 0x01, profile: 0x0104, cluster: SimpleMetering >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x0301 > > >
2022-11-27T22:28:44.795368135+00:00 PRINT Zigbee Switch Power Mc <<<< random_state >>>>
2022-11-27T22:28:44.805034801+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: cf04ef05-28d1-4e7e-a9b3-e67482e15334 [0x2B99] (Aubess TS011F Plug)> emitting event: {“attribute_id”:“randomOnOff”,“capability_id”:“legendabsolute60149.randomOnOff2”,“component_id”:“main”,“state”:{“value”:“Inactive”}}
2022-11-27T22:28:44.881911801+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: cf04ef05-28d1-4e7e-a9b3-e67482e15334 [0x2B99] (Aubess TS011F Plug)> emitting event: {“attribute_id”:“randomNext”,“capability_id”:“legendabsolute60149.randomNextStep2”,“component_id”:“main”,“state”:{“value”:“Inactive”}}
2022-11-27T22:28:44.972359468+00:00 PRINT Zigbee Switch Power Mc device_running[id]= <ZigbeeDevice: cf04ef05-28d1-4e7e-a9b3-e67482e15334 [0x2B99] (Aubess TS011F Plug)>
2022-11-27T22:28:45.003203135+00:00 PRINT Zigbee Switch Power Mc device_running, random_Step= <ZigbeeDevice: cf04ef05-28d1-4e7e-a9b3-e67482e15334 [0x2B99] (Aubess TS011F Plug)> 1
2022-11-27T22:28:45.056967468+00:00 PRINT Zigbee Switch Power Mc device_running, random_totalStep= <ZigbeeDevice: cf04ef05-28d1-4e7e-a9b3-e67482e15334 [0x2B99] (Aubess TS011F Plug)> 2
2022-11-27T22:28:45.070956135+00:00 PRINT Zigbee Switch Power Mc device_running, random_timer= <ZigbeeDevice: cf04ef05-28d1-4e7e-a9b3-e67482e15334 [0x2B99] (Aubess TS011F Plug)> 17
2022-11-27T22:28:45.076063468+00:00 PRINT Zigbee Switch Power Mc random_state >>>>> Inactive
2022-11-27T22:28:45.108403135+00:00 DEBUG Zigbee Switch Power Mc Aubess TS011F Plug device thread event handled
2022-11-27T22:28:45.126106468+00:00 TRACE Zigbee Switch Power Mc Received event with handler device_lifecycle
2022-11-27T22:28:45.131682468+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: cf04ef05-28d1-4e7e-a9b3-e67482e15334 [0x2B99] (Aubess TS011F Plug)> received lifecycle event: added
2022-11-27T22:28:45.147275135+00:00 TRACE Zigbee Switch Power Mc Received event with handler device_lifecycle
2022-11-27T22:28:45.157732135+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: cf04ef05-28d1-4e7e-a9b3-e67482e15334 [0x2B99] (Aubess TS011F Plug)> received lifecycle event: doConfigure
2022-11-27T22:28:45.164616135+00:00 TRACE Zigbee Switch Power Mc <ZigbeeDevice: cf04ef05-28d1-4e7e-a9b3-e67482e15334 [0x2B99] (Aubess TS011F Plug)> received unhandled lifecycle event: added
2022-11-27T22:28:45.169703468+00:00 DEBUG Zigbee Switch Power Mc Aubess TS011F Plug device thread event handled
2022-11-27T22:28:45.176334802+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-11-27T22:28:45.186393135+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: cf04ef05-28d1-4e7e-a9b3-e67482e15334 [0x2B99] (Aubess TS011F Plug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x2B99, src_endpoint: 0x00, dest_addr: 0x0000, dest_endpoint: 0x00, profile: 0x0000, cluster: 0x8021 >, lqi: 0xAC, rssi: -75, body_length: 0x0002, < ZDOMessageBody || < ZDOHeader || seqno: 0x20 >, < BindRequestResponse || status: 0x00 > > >
2022-11-27T22:28:45.200698802+00:00 TRACE Zigbee Switch Power Mc Found DeviceLifecycleDispatcher handler in Zigbee_Switch
2022-11-27T22:28:45.206288802+00:00 TRACE Zigbee Switch Power Mc Found CapabilityCommandDispatcher handler in Zigbee_Switch
2022-11-27T22:28:45.214631468+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: cf04ef05-28d1-4e7e-a9b3-e67482e15334 [0x2B99] (Aubess TS011F Plug)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x2B99, dest_endpoint: 0x01, profile: 0x0104, cluster: ElectricalMeasurement >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x050B > > >
2022-11-27T22:28:45.239666802+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: cf04ef05-28d1-4e7e-a9b3-e67482e15334 [0x2B99] (Aubess TS011F Plug)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x2B99, dest_endpoint: 0x01, profile: 0x0104, cluster: SimpleMetering >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x0000 > > >
2022-11-27T22:28:45.283990135+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: cf04ef05-28d1-4e7e-a9b3-e67482e15334 [0x2B99] (Aubess TS011F Plug)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x2B99, dest_endpoint: 0x01, profile: 0x0104, cluster: SimpleMetering >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x0400 > > >
2022-11-27T22:28:45.339872135+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: cf04ef05-28d1-4e7e-a9b3-e67482e15334 [0x2B99] (Aubess TS011F Plug)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x2B99, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x00 >, < ReadAttribute || AttributeId: 0x0000 > > >
2022-11-27T22:28:45.419611468+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: cf04ef05-28d1-4e7e-a9b3-e67482e15334 [0x2B99] (Aubess TS011F Plug)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x2B99, dest_endpoint: 0x01, profile: 0x0000, cluster: 0x0021 >, < ZDOMessageBody || < ZDOHeader || seqno: 0x00 >, < BindRequest || src_address: A4C138732A3D79D0, src_endpoint: 0x01, cluster: ElectricalMeasurement, dest_addr_mode: 0x03, dest_address: 286D9700020133C2, dest_endpoint: 0x01 > > >
2022-11-27T22:28:45.451899468+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: cf04ef05-28d1-4e7e-a9b3-e67482e15334 [0x2B99] (Aubess TS011F Plug)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x2B99, dest_endpoint: 0x01, profile: 0x0104, cluster: ElectricalMeasurement >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x06 >, < ConfigureReporting || < AttributeReportingConfiguration || direction: 0x00, attr_id: 0x050B, DataType: Int16, minimum_reporting_interval: 0x0001, maximum_reporting_interval: 0x0E10, reportable_change: 5 > > > >
2022-11-27T22:28:45.535754802+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: cf04ef05-28d1-4e7e-a9b3-e67482e15334 [0x2B99] (Aubess TS011F Plug)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x2B99, dest_endpoint: 0x01, profile: 0x0000, cluster: 0x0021 >, < ZDOMessageBody || < ZDOHeader || seqno: 0x00 >, < BindRequest || src_address: A4C138732A3D79D0, src_endpoint: 0x01, cluster: SimpleMetering, dest_addr_mode: 0x03, dest_address: 286D9700020133C2, dest_endpoint: 0x01 > > >
2022-11-27T22:28:45.601800802+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: cf04ef05-28d1-4e7e-a9b3-e67482e15334 [0x2B99] (Aubess TS011F Plug)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x2B99, dest_endpoint: 0x01, profile: 0x0104, cluster: SimpleMetering >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x06 >, < ConfigureReporting || < AttributeReportingConfiguration || direction: 0x00, attr_id: 0x0000, DataType: Uint48, minimum_reporting_interval: 0x0005, maximum_reporting_interval: 0x0E10, reportable_change: 0x000000000001 > > > >
2022-11-27T22:28:45.653378802+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: cf04ef05-28d1-4e7e-a9b3-e67482e15334 [0x2B99] (Aubess TS011F Plug)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x2B99, dest_endpoint: 0x01, profile: 0x0104, cluster: SimpleMetering >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x06 >, < ConfigureReporting || < AttributeReportingConfiguration || direction: 0x00, attr_id: 0x0400, DataType: Int24, minimum_reporting_interval: 0x0001, maximum_reporting_interval: 0x0E10, reportable_change: 5 > > > >
2022-11-27T22:28:45.742133468+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: cf04ef05-28d1-4e7e-a9b3-e67482e15334 [0x2B99] (Aubess TS011F Plug)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x2B99, dest_endpoint: 0x01, profile: 0x0000, cluster: 0x0021 >, < ZDOMessageBody || < ZDOHeader || seqno: 0x00 >, < BindRequest || src_address: A4C138732A3D79D0, src_endpoint: 0x01, cluster: OnOff, dest_addr_mode: 0x03, dest_address: 286D9700020133C2, dest_endpoint: 0x01 > > >
2022-11-27T22:28:45.809270469+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: cf04ef05-28d1-4e7e-a9b3-e67482e15334 [0x2B99] (Aubess TS011F Plug)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x2B99, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x06 >, < ConfigureReporting || < AttributeReportingConfiguration || direction: 0x00, attr_id: 0x0000, DataType: Boolean, minimum_reporting_interval: 0x0000, maximum_reporting_interval: 0x012C > > > >
2022-11-27T22:28:45.898897469+00:00 DEBUG Zigbee Switch Power Mc Aubess TS011F Plug device thread event handled
2022-11-27T22:28:45.925000135+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-11-27T22:28:45.968410135+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: cf04ef05-28d1-4e7e-a9b3-e67482e15334 [0x2B99] (Aubess TS011F Plug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x2B99, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: ElectricalMeasurement >, lqi: 0xD2, rssi: -74, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x18, ZCLCommandId: 0x07 >, < ConfigureReportingResponse || < ConfigureReportingResponseRecord || ZclStatus: SUCCESS, direction: 0x00, attr_id: 0x050B > > > >
2022-11-27T22:28:46.342559135+00:00 DEBUG Zigbee Switch Power Mc Aubess TS011F Plug device thread event handled
2022-11-27T22:28:46.442742135+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-11-27T22:28:46.696393802+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: cf04ef05-28d1-4e7e-a9b3-e67482e15334 [0x2B99] (Aubess TS011F Plug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x2B99, src_endpoint: 0x00, dest_addr: 0x0000, dest_endpoint: 0x00, profile: 0x0000, cluster: 0x8021 >, lqi: 0xD0, rssi: -76, body_length: 0x0002, < ZDOMessageBody || < ZDOHeader || seqno: 0x21 >, < BindRequestResponse || status: 0x00 > > >
2022-11-27T22:28:46.892878802+00:00 DEBUG Zigbee Switch Power Mc Aubess TS011F Plug device thread event handled
2022-11-27T22:28:46.924554136+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-11-27T22:28:47.079794136+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: cf04ef05-28d1-4e7e-a9b3-e67482e15334 [0x2B99] (Aubess TS011F Plug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x2B99, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: SimpleMetering >, lqi: 0xCE, rssi: -75, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x1A, ZCLCommandId: 0x07 >, < ConfigureReportingResponse || < ConfigureReportingResponseRecord || ZclStatus: UNSUPPORTED_ATTRIBUTE, direction: 0x00, attr_id: 0x0400 > > > >
2022-11-27T22:28:47.264180803+00:00 DEBUG Zigbee Switch Power Mc Aubess TS011F Plug device thread event handled
2022-11-27T22:28:47.352615469+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-11-27T22:28:47.520521136+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: cf04ef05-28d1-4e7e-a9b3-e67482e15334 [0x2B99] (Aubess TS011F Plug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x2B99, src_endpoint: 0x00, dest_addr: 0x0000, dest_endpoint: 0x00, profile: 0x0000, cluster: 0x8021 >, lqi: 0xCC, rssi: -80, body_length: 0x0002, < ZDOMessageBody || < ZDOHeader || seqno: 0x22 >, < BindRequestResponse || status: 0x00 > > >
2022-11-27T22:28:47.602329469+00:00 DEBUG Zigbee Switch Power Mc Aubess TS011F Plug device thread event handled
2022-11-27T22:28:47.616079136+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-11-27T22:28:47.681022136+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: cf04ef05-28d1-4e7e-a9b3-e67482e15334 [0x2B99] (Aubess TS011F Plug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x2B99, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0xD0, rssi: -74, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x1B, ZCLCommandId: 0x07 >, < ConfigureReportingResponse || < ConfigureReportingResponseRecord || ZclStatus: SUCCESS, direction: 0x00, attr_id: 0x0000 > > > >
2022-11-27T22:28:47.732328136+00:00 DEBUG Zigbee Switch Power Mc Aubess TS011F Plug device thread event handled
2022-11-27T22:28:47.739219136+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-11-27T22:28:47.760337136+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: cf04ef05-28d1-4e7e-a9b3-e67482e15334 [0x2B99] (Aubess TS011F Plug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x2B99, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: ElectricalMeasurement >, lqi: 0xD0, rssi: -77, body_length: 0x0006, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x1C, ZCLCommandId: 0x01 >, < ReadAttributeResponse || < AttributeRecord || AttributeId: 0x0605, ZclStatus: UNSUPPORTED_ATTRIBUTE > > > >
2022-11-27T22:28:47.796434136+00:00 DEBUG Zigbee Switch Power Mc Aubess TS011F Plug device thread event handled
2022-11-27T22:28:47.815452469+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-11-27T22:28:47.845020136+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: cf04ef05-28d1-4e7e-a9b3-e67482e15334 [0x2B99] (Aubess TS011F Plug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x2B99, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: ElectricalMeasurement >, lqi: 0xCA, rssi: -76, body_length: 0x0006, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x1D, ZCLCommandId: 0x01 >, < ReadAttributeResponse || < AttributeRecord || AttributeId: 0x0604, ZclStatus: UNSUPPORTED_ATTRIBUTE > > > >
2022-11-27T22:28:47.872657136+00:00 DEBUG Zigbee Switch Power Mc Aubess TS011F Plug device thread event handled
2022-11-27T22:28:47.882604470+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-11-27T22:28:47.940010136+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: cf04ef05-28d1-4e7e-a9b3-e67482e15334 [0x2B99] (Aubess TS011F Plug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x2B99, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: SimpleMetering >, lqi: 0xD0, rssi: -76, body_length: 0x0006, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x1E, ZCLCommandId: 0x01 >, < ReadAttributeResponse || < AttributeRecord || AttributeId: 0x0302, ZclStatus: UNSUPPORTED_ATTRIBUTE > > > >
2022-11-27T22:28:47.973323136+00:00 DEBUG Zigbee Switch Power Mc Aubess TS011F Plug device thread event handled
2022-11-27T22:28:47.987385470+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-11-27T22:28:48.006978803+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: cf04ef05-28d1-4e7e-a9b3-e67482e15334 [0x2B99] (Aubess TS011F Plug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x2B99, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: SimpleMetering >, lqi: 0xCA, rssi: -76, body_length: 0x0006, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x1F, ZCLCommandId: 0x01 >, < ReadAttributeResponse || < AttributeRecord || AttributeId: 0x0301, ZclStatus: UNSUPPORTED_ATTRIBUTE > > > >
2022-11-27T22:28:48.058488136+00:00 DEBUG Zigbee Switch Power Mc Aubess TS011F Plug device thread event handled
2022-11-27T22:28:48.090641136+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-11-27T22:28:48.118954136+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: cf04ef05-28d1-4e7e-a9b3-e67482e15334 [0x2B99] (Aubess TS011F Plug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x2B99, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: ElectricalMeasurement >, lqi: 0xCC, rssi: -78, body_length: 0x0009, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x20, ZCLCommandId: 0x01 >, < ReadAttributeResponse || < AttributeRecord || AttributeId: 0x050B, ZclStatus: SUCCESS, DataType: Int16, ActivePower: 0 > > > >
2022-11-27T22:28:48.167520136+00:00 DEBUG Zigbee Switch Power Mc Aubess TS011F Plug device thread event handled
2022-11-27T22:28:48.181988470+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-11-27T22:28:48.214594470+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: cf04ef05-28d1-4e7e-a9b3-e67482e15334 [0x2B99] (Aubess TS011F Plug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x2B99, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: SimpleMetering >, lqi: 0xD0, rssi: -77, body_length: 0x000D, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x21, ZCLCommandId: 0x01 >, < ReadAttributeResponse || < AttributeRecord || AttributeId: 0x0000, ZclStatus: SUCCESS, DataType: Uint48, CurrentSummationDelivered: 0x000000000003 > > > >
2022-11-27T22:28:48.252565803+00:00 DEBUG Zigbee Switch Power Mc Aubess TS011F Plug device thread event handled
2022-11-27T22:28:48.304833803+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-11-27T22:28:48.341973803+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: cf04ef05-28d1-4e7e-a9b3-e67482e15334 [0x2B99] (Aubess TS011F Plug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x2B99, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: SimpleMetering >, lqi: 0xD4, rssi: -78, body_length: 0x0006, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x22, ZCLCommandId: 0x01 >, < ReadAttributeResponse || < AttributeRecord || AttributeId: 0x0400, ZclStatus: UNSUPPORTED_ATTRIBUTE > > > >
2022-11-27T22:28:48.401636470+00:00 TRACE Zigbee Switch Power Mc Found ZigbeeMessageDispatcher handler in Zigbee_Switch
2022-11-27T22:28:48.427004470+00:00 INFO Zigbee Switch Power Mc Executing ZclClusterAttributeValueHandler: cluster: ElectricalMeasurement, attribute: ActivePower
2022-11-27T22:28:48.440651470+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: cf04ef05-28d1-4e7e-a9b3-e67482e15334 [0x2B99] (Aubess TS011F Plug)> emitting event: {“attribute_id”:“power”,“capability_id”:“powerMeter”,“component_id”:“main”,“state”:{“unit”:“W”,“value”:0.0}}
2022-11-27T22:28:48.462968470+00:00 DEBUG Zigbee Switch Power Mc Aubess TS011F Plug device thread event handled
2022-11-27T22:28:48.479277803+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-11-27T22:28:48.487931136+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: cf04ef05-28d1-4e7e-a9b3-e67482e15334 [0x2B99] (Aubess TS011F Plug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x2B99, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0xC8, rssi: -78, body_length: 0x0008, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x23, ZCLCommandId: 0x01 >, < ReadAttributeResponse || < AttributeRecord || AttributeId: 0x0000, ZclStatus: SUCCESS, DataType: Boolean, OnOff: true > > > >
2022-11-27T22:28:48.513604803+00:00 TRACE Zigbee Switch Power Mc Found ZigbeeMessageDispatcher handler in Zigbee_Switch
2022-11-27T22:28:48.525475136+00:00 INFO Zigbee Switch Power Mc Executing ZclClusterAttributeValueHandler: cluster: SimpleMetering, attribute: CurrentSummationDelivered
2022-11-27T22:28:48.532389136+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: cf04ef05-28d1-4e7e-a9b3-e67482e15334 [0x2B99] (Aubess TS011F Plug)> emitting event: {“attribute_id”:“energy”,“capability_id”:“energyMeter”,“component_id”:“main”,“state”:{“unit”:“kWh”,“value”:3.0}}
2022-11-27T22:28:48.560370803+00:00 DEBUG Zigbee Switch Power Mc Aubess TS011F Plug device thread event handled
2022-11-27T22:28:48.573076803+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-11-27T22:28:48.592533137+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: cf04ef05-28d1-4e7e-a9b3-e67482e15334 [0x2B99] (Aubess TS011F Plug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x2B99, src_endpoint: 0x00, dest_addr: 0x0000, dest_endpoint: 0x00, profile: 0x0000, cluster: 0x8021 >, lqi: 0xCE, rssi: -78, body_length: 0x0002, < ZDOMessageBody || < ZDOHeader || seqno: 0x23 >, < BindRequestResponse || status: 0x00 > > >
2022-11-27T22:28:48.608541803+00:00 DEBUG Zigbee Switch Power Mc Aubess TS011F Plug device thread event handled
2022-11-27T22:28:48.615439137+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-11-27T22:28:48.633073803+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: cf04ef05-28d1-4e7e-a9b3-e67482e15334 [0x2B99] (Aubess TS011F Plug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x2B99, src_endpoint: 0x00, dest_addr: 0x0000, dest_endpoint: 0x00, profile: 0x0000, cluster: 0x8021 >, lqi: 0xAA, rssi: -79, body_length: 0x0002, < ZDOMessageBody || < ZDOHeader || seqno: 0x24 >, < BindRequestResponse || status: 0x00 > > >
2022-11-27T22:28:48.659010137+00:00 TRACE Zigbee Switch Power Mc Found ZigbeeMessageDispatcher handler in Zigbee_Switch
2022-11-27T22:28:48.666883803+00:00 INFO Zigbee Switch Power Mc Executing ZclClusterAttributeValueHandler: cluster: OnOff, attribute: OnOff
2022-11-27T22:28:48.675859470+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: cf04ef05-28d1-4e7e-a9b3-e67482e15334 [0x2B99] (Aubess TS011F Plug)> emitting event: {“attribute_id”:“signalMetrics”,“capability_id”:“legendabsolute60149.signalMetrics”,“component_id”:“main”,“state”:{“value”:“<em table style=‘font-size:70%’;‘font-weight: bold’GMT: 2022/11/27 Time: 22:28
DNI: 0x2B99 LQI: 200 RSSI: -78dbm
”},“visibility”:{“displayed”:false}}
2022-11-27T22:28:48.696905137+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: cf04ef05-28d1-4e7e-a9b3-e67482e15334 [0x2B99] (Aubess TS011F Plug)> emitting event: {“attribute_id”:“switch”,“capability_id”:“switch”,“component_id”:“main”,“state”:{“value”:“on”}}
2022-11-27T22:28:48.717090470+00:00 DEBUG Zigbee Switch Power Mc Aubess TS011F Plug device thread event handled
2022-11-27T22:28:48.723980803+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-11-27T22:28:48.732561137+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: cf04ef05-28d1-4e7e-a9b3-e67482e15334 [0x2B99] (Aubess TS011F Plug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x2B99, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: ElectricalMeasurement >, lqi: 0xCA, rssi: -77, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x24, ZCLCommandId: 0x07 >, < ConfigureReportingResponse || < ConfigureReportingResponseRecord || ZclStatus: SUCCESS, direction: 0x00, attr_id: 0x050B > > > >
2022-11-27T22:28:48.748213470+00:00 DEBUG Zigbee Switch Power Mc Aubess TS011F Plug device thread event handled
2022-11-27T22:28:48.755649803+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-11-27T22:28:48.767352137+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: cf04ef05-28d1-4e7e-a9b3-e67482e15334 [0x2B99] (Aubess TS011F Plug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x2B99, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: SimpleMetering >, lqi: 0xCA, rssi: -79, body_length: 0x000C, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x65, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0000, DataType: Uint48, CurrentSummationDelivered: 0x000000000003 > > > >
2022-11-27T22:28:48.781755137+00:00 DEBUG Zigbee Switch Power Mc Aubess TS011F Plug device thread event handled
2022-11-27T22:28:48.788628137+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-11-27T22:28:48.798061470+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: cf04ef05-28d1-4e7e-a9b3-e67482e15334 [0x2B99] (Aubess TS011F Plug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x2B99, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: SimpleMetering >, lqi: 0xC4, rssi: -81, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x26, ZCLCommandId: 0x07 >, < ConfigureReportingResponse || < ConfigureReportingResponseRecord || ZclStatus: UNSUPPORTED_ATTRIBUTE, direction: 0x00, attr_id: 0x0400 > > > >
2022-11-27T22:28:48.813574137+00:00 DEBUG Zigbee Switch Power Mc Aubess TS011F Plug device thread event handled
2022-11-27T22:28:48.820459137+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-11-27T22:28:48.835390803+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: cf04ef05-28d1-4e7e-a9b3-e67482e15334 [0x2B99] (Aubess TS011F Plug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x2B99, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: ElectricalMeasurement >, lqi: 0xC2, rssi: -83, body_length: 0x0012, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x66, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0505, DataType: Uint16, RMSVoltage: 0x00EE >, < AttributeRecord || AttributeId: 0x0508, DataType: Uint16, RMSCurrent: 0x0000 >, < AttributeRecord || AttributeId: 0x050B, DataType: Int16, ActivePower: 0 > > > >
2022-11-27T22:28:48.860927137+00:00 TRACE Zigbee Switch Power Mc Found ZigbeeMessageDispatcher handler in Zigbee_Switch
2022-11-27T22:28:48.866317137+00:00 INFO Zigbee Switch Power Mc Executing ZclClusterAttributeValueHandler: cluster: SimpleMetering, attribute: CurrentSummationDelivered
2022-11-27T22:28:48.872942470+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: cf04ef05-28d1-4e7e-a9b3-e67482e15334 [0x2B99] (Aubess TS011F Plug)> emitting event: {“attribute_id”:“energy”,“capability_id”:“energyMeter”,“component_id”:“main”,“state”:{“unit”:“kWh”,“value”:3.0}}
2022-11-27T22:28:48.889441470+00:00 DEBUG Zigbee Switch Power Mc Aubess TS011F Plug device thread event handled
2022-11-27T22:28:48.896715803+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-11-27T22:28:48.906304137+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: cf04ef05-28d1-4e7e-a9b3-e67482e15334 [0x2B99] (Aubess TS011F Plug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x2B99, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: SimpleMetering >, lqi: 0xC8, rssi: -82, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x25, ZCLCommandId: 0x07 >, < ConfigureReportingResponse || < ConfigureReportingResponseRecord || ZclStatus: SUCCESS, direction: 0x00, attr_id: 0x0000 > > > >
2022-11-27T22:28:48.920829803+00:00 DEBUG Zigbee Switch Power Mc Aubess TS011F Plug device thread event handled
2022-11-27T22:28:48.927885137+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-11-27T22:28:48.937210803+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: cf04ef05-28d1-4e7e-a9b3-e67482e15334 [0x2B99] (Aubess TS011F Plug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x2B99, src_endpoint: 0x00, dest_addr: 0x0000, dest_endpoint: 0x00, profile: 0x0000, cluster: 0x8021 >, lqi: 0xCA, rssi: -86, body_length: 0x0002, < ZDOMessageBody || < ZDOHeader || seqno: 0x25 >, < BindRequestResponse || status: 0x00 > > >
2022-11-27T22:28:48.955713470+00:00 TRACE Zigbee Switch Power Mc Found ZigbeeMessageDispatcher handler in Zigbee_Switch
2022-11-27T22:28:48.960802470+00:00 INFO Zigbee Switch Power Mc Executing ZclClusterAttributeValueHandler: cluster: ElectricalMeasurement, attribute: ActivePower
2022-11-27T22:28:48.967363803+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: cf04ef05-28d1-4e7e-a9b3-e67482e15334 [0x2B99] (Aubess TS011F Plug)> emitting event: {“attribute_id”:“power”,“capability_id”:“powerMeter”,“component_id”:“main”,“state”:{“unit”:“W”,“value”:0.0}}
2022-11-27T22:28:48.984047137+00:00 DEBUG Zigbee Switch Power Mc Aubess TS011F Plug device thread event handled
2022-11-27T22:28:48.991373803+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-11-27T22:28:49.000559470+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: cf04ef05-28d1-4e7e-a9b3-e67482e15334 [0x2B99] (Aubess TS011F Plug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x2B99, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0x72, rssi: -94, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x27, ZCLCommandId: 0x07 >, < ConfigureReportingResponse || < ConfigureReportingResponseRecord || ZclStatus: SUCCESS, direction: 0x00, attr_id: 0x0000 > > > >
2022-11-27T22:28:49.015650470+00:00 DEBUG Zigbee Switch Power Mc Aubess TS011F Plug device thread event handled
2022-11-27T22:28:49.023181803+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-11-27T22:28:49.034461803+00:00 WARN Zigbee Switch Power Mc Error encountered parsing Zigbee message defaulting to generic body: [string “st/zigbee/data_types/ZigbeeDataType.lua”]:32: DataType value is an unrecognized data type: 0x06
2022-11-27T22:28:49.041635137+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: cf04ef05-28d1-4e7e-a9b3-e67482e15334 [0x2B99] (Aubess TS011F Plug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x2B99, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: 0xE000 >, lqi: 0xAA, rssi: -83, body_length: 0x0009, GenericBody: 08 67 0A 01 D0 48 02 00 06 >
2022-11-27T22:28:49.065004470+00:00 DEBUG Zigbee Switch Power Mc Aubess TS011F Plug device thread event handled
2022-11-27T22:28:49.071919470+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-11-27T22:28:49.079928137+00:00 WARN Zigbee Switch Power Mc Error encountered parsing Zigbee message defaulting to generic body: [string “st/buf.lua”]:695: buffer too short
2022-11-27T22:28:49.087382470+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: cf04ef05-28d1-4e7e-a9b3-e67482e15334 [0x2B99] (Aubess TS011F Plug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x2B99, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: 0xE000 >, lqi: 0xC6, rssi: -84, body_length: 0x0009, GenericBody: 08 68 0A 02 D0 48 02 00 0A >
2022-11-27T22:28:49.102130137+00:00 DEBUG Zigbee Switch Power Mc Aubess TS011F Plug device thread event handled
2022-11-27T22:28:49.109570137+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-11-27T22:28:49.126710137+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: cf04ef05-28d1-4e7e-a9b3-e67482e15334 [0x2B99] (Aubess TS011F Plug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x2B99, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0xC6, rssi: -80, body_length: 0x0021, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x69, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0000, DataType: Boolean, OnOff: true >, < AttributeRecord || AttributeId: 0x4001, DataType: Uint16, OnTime: 0x0000 >, < AttributeRecord || AttributeId: 0x4002, DataType: Uint16, OffWaitTime: 0x0000 >, < AttributeRecord || AttributeId: 0x8001, DataType: Enum8, Enum8: 0x01 >, < AttributeRecord || AttributeId: 0x8002, DataType: Enum8, Enum8: 0x02 >, < AttributeRecord || AttributeId: 0x5000, DataType: Enum8, Enum8: 0x01 >, < AttributeRecord || AttributeId: 0x8000, DataType: Boolean, Boolean: false > > > >
2022-11-27T22:28:49.162865470+00:00 DEBUG Zigbee Switch Power Mc Aubess TS011F Plug device thread event handled
2022-11-27T22:28:49.169771803+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-11-27T22:28:49.184541803+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: cf04ef05-28d1-4e7e-a9b3-e67482e15334 [0x2B99] (Aubess TS011F Plug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x2B99, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: 0xE001 >, lqi: 0xC6, rssi: -82, body_length: 0x0032, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x6A, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0xD010, DataType: Enum8, Enum8: 0x02 >, < AttributeRecord || AttributeId: 0xD030, DataType: Enum8, Enum8: 0x00 >, < AttributeRecord || AttributeId: 0xD000, DataType: Uint8, Uint8: 0x01 >, < AttributeRecord || AttributeId: 0xD001, DataType: Bitmap32, Bitmap32: 0x00000000 >, < AttributeRecord || AttributeId: 0xD002, DataType: Uint32, Uint32: 0x002B1F6C >, < AttributeRecord || AttributeId: 0xD003, DataType: Uint32, Uint32: 0x0000007A >, < AttributeRecord || AttributeId: 0xD004, DataType: Uint32, Uint32: 0x000029DA >, < AttributeRecord || AttributeId: 0xD005, DataType: Uint32, Uint32: 0x000004F9 > > > >
2022-11-27T22:28:49.200967137+00:00 DEBUG Zigbee Switch Power Mc Aubess TS011F Plug device thread event handled
2022-11-27T22:28:49.208207470+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-11-27T22:28:49.216719137+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: cf04ef05-28d1-4e7e-a9b3-e67482e15334 [0x2B99] (Aubess TS011F Plug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x2B99, src_endpoint: 0x00, dest_addr: 0x0000, dest_endpoint: 0x00, profile: 0x0000, cluster: 0x8021 >, lqi: 0xC0, rssi: -85, body_length: 0x0002, < ZDOMessageBody || < ZDOHeader || seqno: 0x22 >, < BindRequestResponse || status: 0x00 > > >
2022-11-27T22:28:49.230941803+00:00 TRACE Zigbee Switch Power Mc Found ZigbeeMessageDispatcher handler in Zigbee_Switch
2022-11-27T22:28:49.236240470+00:00 INFO Zigbee Switch Power Mc Executing ZclClusterAttributeValueHandler: cluster: OnOff, attribute: OnOff
2022-11-27T22:28:49.255975137+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: cf04ef05-28d1-4e7e-a9b3-e67482e15334 [0x2B99] (Aubess TS011F Plug)> emitting event: {“attribute_id”:“signalMetrics”,“capability_id”:“legendabsolute60149.signalMetrics”,“component_id”:“main”,“state”:{“value”:“<em table style=‘font-size:70%’;‘font-weight: bold’GMT: 2022/11/27 Time: 22:28
DNI: 0x2B99 LQI: 198 RSSI: -80dbm
2022-11-27T22:28:49.277568470+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: cf04ef05-28d1-4e7e-a9b3-e67482e15334 [0x2B99] (Aubess TS011F Plug)> emitting event: {“attribute_id”:“switch”,“capability_id”:“switch”,“component_id”:“main”,“state”:{“value”:“on”}}
2022-11-27T22:28:49.293801804+00:00 DEBUG Zigbee Switch Power Mc Aubess TS011F Plug device thread event handled
2022-11-27T22:28:49.301483137+00:00 TRACE Zigbee Switch Power Mc Received event with handler device_lifecycle
2022-11-27T22:28:49.317614804+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: cf04ef05-28d1-4e7e-a9b3-e67482e15334 [0x2B99] (Aubess TS011F Plug)> received lifecycle event: infoChanged
2022-11-27T22:28:49.332046804+00:00 DEBUG Zigbee Switch Power Mc Aubess TS011F Plug device thread event handled
2022-11-27T22:28:49.339041470+00:00 DEBUG Zigbee Switch Power Mc Aubess TS011F Plug device thread event handled
2022-11-27T22:28:49.346250804+00:00 TRACE Zigbee Switch Power Mc Found DeviceLifecycleDispatcher handler in Zigbee_Switch
2022-11-27T22:28:49.355205137+00:00 PRINT Zigbee Switch Power Mc device.preferences[infoChanged]= 10.0
2022-11-27T22:28:49.360720470+00:00 PRINT Zigbee Switch Power Mc << Preference changed: name, old, new >> randomMax nil 10.0
2022-11-27T22:28:49.366509470+00:00 PRINT Zigbee Switch Power Mc device.preferences[infoChanged]= 0.0
2022-11-27T22:28:49.371870470+00:00 PRINT Zigbee Switch Power Mc << Preference changed: name, old, new >> groupAdd nil 0.0
2022-11-27T22:28:49.378720804+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: cf04ef05-28d1-4e7e-a9b3-e67482e15334 [0x2B99] (Aubess TS011F Plug)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x2B99, dest_endpoint: 0x01, profile: 0x0104, cluster: Groups >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x01, seqno: 0x00, ZCLCommandId: 0x02 >, < GetGroupMembership || group_list_length: 0x00 > > >
2022-11-27T22:28:49.397891470+00:00 PRINT Zigbee Switch Power Mc device.preferences[infoChanged]= 1.0
2022-11-27T22:28:49.416532804+00:00 PRINT Zigbee Switch Power Mc << Preference changed: name, old, new >> randomMin nil 1.0
2022-11-27T22:28:49.422001470+00:00 PRINT Zigbee Switch Power Mc device.preferences[infoChanged]= 1.0
2022-11-27T22:28:49.427485137+00:00 PRINT Zigbee Switch Power Mc << Preference changed: name, old, new >> groupRemove nil 1.0
2022-11-27T22:28:49.432629470+00:00 PRINT Zigbee Switch Power Mc Remove Groups >>>>>>>>>>>>>>>>>
2022-11-27T22:28:49.445234137+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: cf04ef05-28d1-4e7e-a9b3-e67482e15334 [0x2B99] (Aubess TS011F Plug)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x2B99, dest_endpoint: 0x01, profile: 0x0104, cluster: Groups >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x01, seqno: 0x00, ZCLCommandId: 0x03 >, < RemoveGroup || group_id: 0x0001 > > >
2022-11-27T22:28:49.495476804+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: cf04ef05-28d1-4e7e-a9b3-e67482e15334 [0x2B99] (Aubess TS011F Plug)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x2B99, dest_endpoint: 0x01, profile: 0x0104, cluster: Groups >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x01, seqno: 0x00, ZCLCommandId: 0x02 >, < GetGroupMembership || group_list_length: 0x00 > > >
2022-11-27T22:28:49.528105137+00:00 PRINT Zigbee Switch Power Mc device.preferences[infoChanged]= 0
2022-11-27T22:28:49.533609470+00:00 PRINT Zigbee Switch Power Mc << Preference changed: name, old, new >> localTimeOffset nil 0
2022-11-27T22:28:49.580475137+00:00 PRINT Zigbee Switch Power Mc device.preferences[infoChanged]= 10
2022-11-27T22:28:49.601761804+00:00 PRINT Zigbee Switch Power Mc << Preference changed: name, old, new >> onTime nil 10
2022-11-27T22:28:49.637065470+00:00 PRINT Zigbee Switch Power Mc device.preferences[infoChanged]= 10
2022-11-27T22:28:49.657524470+00:00 PRINT Zigbee Switch Power Mc << Preference changed: name, old, new >> offTime nil 10
2022-11-27T22:28:49.689993470+00:00 PRINT Zigbee Switch Power Mc device.preferences[infoChanged]= Plug
2022-11-27T22:28:49.701687137+00:00 PRINT Zigbee Switch Power Mc << Preference changed: name, old, new >> changeProfileEner nil Plug
2022-11-27T22:28:49.770843470+00:00 PRINT Zigbee Switch Power Mc device.preferences[infoChanged]=
2022-11-27T22:28:49.778710804+00:00 PRINT Zigbee Switch Power Mc << Preference changed: name, old, new >> version nil
2022-11-27T22:28:49.794990470+00:00 PRINT Zigbee Switch Power Mc device.preferences[infoChanged]= 255
2022-11-27T22:28:49.808516137+00:00 PRINT Zigbee Switch Power Mc << Preference changed: name, old, new >> restoreState nil 255
2022-11-27T22:28:49.816481470+00:00 PRINT Zigbee Switch Power Mc <<< Write restore state >>>
2022-11-27T22:28:49.829797804+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: cf04ef05-28d1-4e7e-a9b3-e67482e15334 [0x2B99] (Aubess TS011F Plug)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x2B99, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x02 >, < WriteAttribute || < AttributeRecord || attr_id: 0x4003, DataType: Enum8, data: 0xFF > > > >
2022-11-27T22:28:49.856923804+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: cf04ef05-28d1-4e7e-a9b3-e67482e15334 [0x2B99] (Aubess TS011F Plug)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0x2B99, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x00, seqno: 0x00, ZCLCommandId: 0x02 >, < WriteAttribute || < AttributeRecord || attr_id: 0x8002, DataType: Enum8, data: 0x02 > > > >
2022-11-27T22:28:49.948058804+00:00 PRINT Zigbee Switch Power Mc device.preferences[infoChanged]= No
2022-11-27T22:28:50.038102137+00:00 PRINT Zigbee Switch Power Mc << Preference changed: name, old, new >> signalMetricsVisibles nil No
2022-11-27T22:28:50.045651137+00:00 PRINT Zigbee Switch Power Mc Device ID <ZigbeeDevice: cf04ef05-28d1-4e7e-a9b3-e67482e15334 [0x2B99] (Aubess TS011F Plug)>
2022-11-27T22:28:50.059363471+00:00 PRINT Zigbee Switch Power Mc Manufacturer >>> _TZ3000_hdopuwv6 Manufacturer_Len >>> 16
2022-11-27T22:28:50.121146137+00:00 PRINT Zigbee Switch Power Mc Model >>> TS011F Model_len >>> 6
2022-11-27T22:28:50.126907471+00:00 PRINT Zigbee Switch Power Mc Memory >>>>>>> 1803.9560546875 Kbytes
2022-11-27T22:28:50.132789471+00:00 DEBUG Zigbee Switch Power Mc Aubess TS011F Plug device thread event handled
2022-11-27T22:28:50.139623471+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-11-27T22:28:50.148762137+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: cf04ef05-28d1-4e7e-a9b3-e67482e15334 [0x2B99] (Aubess TS011F Plug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x2B99, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: Groups >, lqi: 0xCA, rssi: -77, body_length: 0x0005, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x19, seqno: 0x28, ZCLCommandId: 0x02 >, < GetGroupMembershipResponse || capacity: 0x20, group_list_length: 0x00 > > >
2022-11-27T22:28:50.212336804+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-11-27T22:28:50.220829804+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: cf04ef05-28d1-4e7e-a9b3-e67482e15334 [0x2B99] (Aubess TS011F Plug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x2B99, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: Groups >, lqi: 0xC6, rssi: -77, body_length: 0x0005, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x28, ZCLCommandId: 0x0B >, < DefaultResponse || cmd: 0x02, ZclStatus: SUCCESS > > >
2022-11-27T22:28:50.236260804+00:00 TRACE Zigbee Switch Power Mc Found ZigbeeMessageDispatcher handler in Zigbee_Switch
2022-11-27T22:28:50.241722804+00:00 INFO Zigbee Switch Power Mc Executing ZclClusterCommandHandler: cluster: Groups, command: GetGroupMembership
2022-11-27T22:28:50.252622471+00:00 PRINT Zigbee Switch Power Mc group_list >>>>>> {}
2022-11-27T22:28:50.258347471+00:00 PRINT Zigbee Switch Power Mc All Deleted
2022-11-27T22:28:50.266064804+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: cf04ef05-28d1-4e7e-a9b3-e67482e15334 [0x2B99] (Aubess TS011F Plug)> emitting event: {“attribute_id”:“getGroups”,“capability_id”:“legendabsolute60149.getGroups”,“component_id”:“main”,“state”:{“value”:“All Deleted”}}
2022-11-27T22:28:50.286770804+00:00 DEBUG Zigbee Switch Power Mc Aubess TS011F Plug device thread event handled
2022-11-27T22:28:50.294206804+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-11-27T22:28:50.308812137+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: cf04ef05-28d1-4e7e-a9b3-e67482e15334 [0x2B99] (Aubess TS011F Plug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x2B99, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: Groups >, lqi: 0xC0, rssi: -78, body_length: 0x0006, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x19, seqno: 0x29, ZCLCommandId: 0x03 >, < RemoveGroupResponse || status: 0x8B, group_id: 0x0001 > > >
2022-11-27T22:28:50.324314804+00:00 DEBUG Zigbee Switch Power Mc Aubess TS011F Plug device thread event handled
2022-11-27T22:28:50.332013804+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-11-27T22:28:50.341236137+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: cf04ef05-28d1-4e7e-a9b3-e67482e15334 [0x2B99] (Aubess TS011F Plug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x2B99, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: Groups >, lqi: 0xCA, rssi: -78, body_length: 0x0005, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x29, ZCLCommandId: 0x0B >, < DefaultResponse || cmd: 0x03, ZclStatus: SUCCESS > > >
2022-11-27T22:28:50.356724471+00:00 DEBUG Zigbee Switch Power Mc Aubess TS011F Plug device thread event handled
2022-11-27T22:28:50.366239137+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-11-27T22:28:50.375772471+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: cf04ef05-28d1-4e7e-a9b3-e67482e15334 [0x2B99] (Aubess TS011F Plug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x2B99, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: Groups >, lqi: 0xCC, rssi: -77, body_length: 0x0005, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x19, seqno: 0x2A, ZCLCommandId: 0x02 >, < GetGroupMembershipResponse || capacity: 0x20, group_list_length: 0x00 > > >
2022-11-27T22:28:50.392526471+00:00 DEBUG Zigbee Switch Power Mc Aubess TS011F Plug device thread event handled
2022-11-27T22:28:50.399651804+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-11-27T22:28:50.440037137+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: cf04ef05-28d1-4e7e-a9b3-e67482e15334 [0x2B99] (Aubess TS011F Plug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x2B99, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: Groups >, lqi: 0xC8, rssi: -76, body_length: 0x0005, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x2A, ZCLCommandId: 0x0B >, < DefaultResponse || cmd: 0x02, ZclStatus: SUCCESS > > >
2022-11-27T22:28:50.464903471+00:00 TRACE Zigbee Switch Power Mc Found ZigbeeMessageDispatcher handler in Zigbee_Switch
2022-11-27T22:28:50.497399137+00:00 INFO Zigbee Switch Power Mc Executing ZclClusterCommandHandler: cluster: Groups, command: GetGroupMembership
2022-11-27T22:28:50.506340471+00:00 PRINT Zigbee Switch Power Mc group_list >>>>>> {}
2022-11-27T22:28:50.512797137+00:00 PRINT Zigbee Switch Power Mc All Deleted
2022-11-27T22:28:50.518514137+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: cf04ef05-28d1-4e7e-a9b3-e67482e15334 [0x2B99] (Aubess TS011F Plug)> emitting event: {“attribute_id”:“getGroups”,“capability_id”:“legendabsolute60149.getGroups”,“component_id”:“main”,“state”:{“value”:“All Deleted”}}
2022-11-27T22:28:50.546189137+00:00 DEBUG Zigbee Switch Power Mc Aubess TS011F Plug device thread event handled
2022-11-27T22:28:50.571552137+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-11-27T22:28:50.584380804+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: cf04ef05-28d1-4e7e-a9b3-e67482e15334 [0x2B99] (Aubess TS011F Plug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x2B99, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0xCE, rssi: -77, body_length: 0x0006, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x2B, ZCLCommandId: 0x04 >, < WriteAttributeReponse || < WriteAttributeResponseRecord || ZclStatus: UNSUPPORTED_ATTRIBUTE, AttributeId: 0x4003 > > > >
2022-11-27T22:28:50.602683471+00:00 DEBUG Zigbee Switch Power Mc Aubess TS011F Plug device thread event handled
2022-11-27T22:28:50.610257471+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-11-27T22:28:50.618971471+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: cf04ef05-28d1-4e7e-a9b3-e67482e15334 [0x2B99] (Aubess TS011F Plug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x2B99, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0xC8, rssi: -77, body_length: 0x0004, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x2C, ZCLCommandId: 0x04 >, < WriteAttributeReponse || ZclStatus: SUCCESS > > >
2022-11-27T22:28:50.636607804+00:00 DEBUG Zigbee Switch Power Mc Aubess TS011F Plug device thread event handled
2022-11-27T22:28:50.643939471+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-11-27T22:28:50.657202804+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: cf04ef05-28d1-4e7e-a9b3-e67482e15334 [0x2B99] (Aubess TS011F Plug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x2B99, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0xB4, rssi: -81, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x6C, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x8002, DataType: Enum8, Enum8: 0x02 > > > >
2022-11-27T22:28:50.672501804+00:00 DEBUG Zigbee Switch Power Mc Aubess TS011F Plug device thread event handled
2022-11-27T22:28:50.680216804+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-11-27T22:28:50.689942138+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: cf04ef05-28d1-4e7e-a9b3-e67482e15334 [0x2B99] (Aubess TS011F Plug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x2B99, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: 0xE001 >, lqi: 0xD0, rssi: -79, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x6D, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0xD010, DataType: Enum8, Enum8: 0x02 > > > >
2022-11-27T22:28:50.705153138+00:00 DEBUG Zigbee Switch Power Mc Aubess TS011F Plug device thread event handled
2022-11-27T22:28:50.713915804+00:00 DEBUG Zigbee Switch Power Mc Aubess TS011F Plug device thread event handled
2022-11-27T22:29:04.309007477+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-11-27T22:29:04.330983144+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: cf04ef05-28d1-4e7e-a9b3-e67482e15334 [0x2B99] (Aubess TS011F Plug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x2B99, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: SimpleMetering >, lqi: 0xD0, rssi: -77, body_length: 0x000C, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x6E, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0000, DataType: Uint48, CurrentSummationDelivered: 0x000000000003 > > > >
2022-11-27T22:29:04.390419811+00:00 TRACE Zigbee Switch Power Mc Found ZigbeeMessageDispatcher handler in Zigbee_Switch
2022-11-27T22:29:04.396215144+00:00 INFO Zigbee Switch Power Mc Executing ZclClusterAttributeValueHandler: cluster: SimpleMetering, attribute: CurrentSummationDelivered
2022-11-27T22:29:04.402615144+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: cf04ef05-28d1-4e7e-a9b3-e67482e15334 [0x2B99] (Aubess TS011F Plug)> emitting event: {“attribute_id”:“energy”,“capability_id”:“energyMeter”,“component_id”:“main”,“state”:{“unit”:“kWh”,“value”:3.0}}
2022-11-27T22:29:04.421983477+00:00 DEBUG Zigbee Switch Power Mc Aubess TS011F Plug device thread event handled
2022-11-27T22:29:04.430703477+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-11-27T22:29:04.440378477+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: cf04ef05-28d1-4e7e-a9b3-e67482e15334 [0x2B99] (Aubess TS011F Plug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x2B99, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: ElectricalMeasurement >, lqi: 0xC8, rssi: -76, body_length: 0x0012, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x08, seqno: 0x6F, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0505, DataType: Uint16, RMSVoltage: 0x00EE >, < AttributeRecord || AttributeId: 0x0508, DataType: Uint16, RMSCurrent: 0x0000 >, < AttributeRecord || AttributeId: 0x050B, DataType: Int16, ActivePower: 0 > > > >
2022-11-27T22:29:04.463041477+00:00 TRACE Zigbee Switch Power Mc Found ZigbeeMessageDispatcher handler in Zigbee_Switch
2022-11-27T22:29:04.471555144+00:00 INFO Zigbee Switch Power Mc Executing ZclClusterAttributeValueHandler: cluster: ElectricalMeasurement, attribute: ActivePower
2022-11-27T22:29:04.478327477+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: cf04ef05-28d1-4e7e-a9b3-e67482e15334 [0x2B99] (Aubess TS011F Plug)> emitting event: {“attribute_id”:“power”,“capability_id”:“powerMeter”,“component_id”:“main”,“state”:{“unit”:“W”,“value”:0.0}}
2022-11-27T22:29:04.497379811+00:00 DEBUG Zigbee Switch Power Mc Aubess TS011F Plug device thread event handled
2022-11-27T22:29:14.113092149+00:00 DEBUG Zigbee Switch Power Mc driver device thread event handled
2022-11-27T22:29:44.123211830+00:00 DEBUG Zigbee Switch Power Mc driver device thread event handled
2022-11-27T22:30:08.279329175+00:00 TRACE Zigbee Switch Power Mc Received event with handler zigbee
2022-11-27T22:30:08.288324175+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: cf04ef05-28d1-4e7e-a9b3-e67482e15334 [0x2B99] (Aubess TS011F Plug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x2B99, src_endpoint: 0x00, dest_addr: 0x0000, dest_endpoint: 0x00, profile: 0x0000, cluster: 0x8001 >, lqi: 0xCA, rssi: -80, body_length: 0x000C, < ZDOMessageBody || < ZDOHeader || seqno: 0x2B >, GenericBody: 00 D0 79 3D 2A 73 38 C1 A4 99 2B > >
2022-11-27T22:30:08.306793175+00:00 DEBUG Zigbee Switch Power Mc Aubess TS011F Plug device thread event handled
2022-11-27T22:30:08.564408508+00:00 TRACE Zigbee Switch Power Mc Received event with handler device_lifecycle
2022-11-27T22:30:08.578334841+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: cf04ef05-28d1-4e7e-a9b3-e67482e15334 [0x2B99] (Bedroom Plug)> received lifecycle event: infoChanged
2022-11-27T22:30:08.586737175+00:00 TRACE Zigbee Switch Power Mc Found DeviceLifecycleDispatcher handler in Zigbee_Switch
2022-11-27T22:30:08.592092841+00:00 PRINT Zigbee Switch Power Mc device.preferences[infoChanged]= 10.0
2022-11-27T22:30:08.655102841+00:00 PRINT Zigbee Switch Power Mc device.preferences[infoChanged]= 0.0
2022-11-27T22:30:08.660343175+00:00 PRINT Zigbee Switch Power Mc device.preferences[infoChanged]= 1.0
2022-11-27T22:30:08.665794175+00:00 PRINT Zigbee Switch Power Mc device.preferences[infoChanged]= 1.0
2022-11-27T22:30:08.670919508+00:00 PRINT Zigbee Switch Power Mc device.preferences[infoChanged]= 0
2022-11-27T22:30:08.676228841+00:00 PRINT Zigbee Switch Power Mc device.preferences[infoChanged]= 10
2022-11-27T22:30:08.681343508+00:00 PRINT Zigbee Switch Power Mc device.preferences[infoChanged]= 10
2022-11-27T22:30:08.686819841+00:00 PRINT Zigbee Switch Power Mc device.preferences[infoChanged]= Plug
2022-11-27T22:30:08.691954841+00:00 PRINT Zigbee Switch Power Mc device.preferences[infoChanged]=
2022-11-27T22:30:08.697026508+00:00 PRINT Zigbee Switch Power Mc device.preferences[infoChanged]= 255
2022-11-27T22:30:08.702134841+00:00 PRINT Zigbee Switch Power Mc device.preferences[infoChanged]= No
2022-11-27T22:30:08.707776841+00:00 PRINT Zigbee Switch Power Mc Device ID <ZigbeeDevice: cf04ef05-28d1-4e7e-a9b3-e67482e15334 [0x2B99] (Bedroom Plug)>
2022-11-27T22:30:08.712911508+00:00 PRINT Zigbee Switch Power Mc Manufacturer >>> _TZ3000_hdopuwv6 Manufacturer_Len >>> 16
2022-11-27T22:30:08.718156175+00:00 PRINT Zigbee Switch Power Mc Model >>> TS011F Model_len >>> 6
2022-11-27T22:30:08.723741841+00:00 PRINT Zigbee Switch Power Mc Memory >>>>>>> 1040.16796875 Kbytes
2022-11-27T22:30:08.728805508+00:00 DEBUG Zigbee Switch Power Mc Aubess TS011F Plug device thread event handled
2022-11-27T22:30:14.132608177+00:00 DEBUG Zigbee Switch Power Mc driver device thread event handled
2022-11-27T22:30:44.132757525+00:00 DEBUG Zigbee Switch Power Mc driver device thread event handled
2022-11-27T22:31:14.142719378+00:00 DEBUG Zigbee Switch Power Mc driver device thread event handled
2022-11-27T22:31:44.153235059+00:00 DEBUG Zigbee Switch Power Mc driver device thread event handled
2022-11-27T22:32:14.152721740+00:00 DEBUG Zigbee Switch Power Mc driver device thread event handled
2022-11-27T22:32:44.163214754+00:00 DEBUG Zigbee Switch Power Mc driver device thread event handled
2022-11-27T22:33:14.162687769+00:00 DEBUG Zigbee Switch Power Mc driver device thread event handled
2022-11-27T22:33:45.487653117+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: cf04ef05-28d1-4e7e-a9b3-e67482e15334 [0x2B99] (Bedroom Plug)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0x2B99, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: OnOff >, lqi: 0x94, rssi: -84, body_length: 0x0007, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x70, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0000, DataType: Boolean, OnOff: true > > > >
2022-11-27T22:33:45.554683117+00:00 TRACE Zigbee Switch Power Mc Found ZigbeeMessageDispatcher handler in Zigbee_Switch
2022-11-27T22:33:45.559817117+00:00 INFO Zigbee Switch Power Mc Executing ZclClusterAttributeValueHandler: cluster: OnOff, attribute: OnOff
2022-11-27T22:33:45.567660784+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: cf04ef05-28d1-4e7e-a9b3-e67482e15334 [0x2B99] (Bedroom Plug)> emitting event: {“attribute_id”:“signalMetrics”,“capability_id”:“legendabsolute60149.signalMetrics”,“component_id”:“main”,“state”:{“value”:“<em table style=‘font-size:70%’;‘font-weight: bold’GMT: 2022/11/27 Time: 22:33
DNI: 0x2B99 LQI: 148 RSSI: -84dbm
2022-11-27T22:33:45.587626784+00:00 INFO Zigbee Switch Power Mc <ZigbeeDevice: cf04ef05-28d1-4e7e-a9b3-e67482e15334 [0x2B99] (Bedroom Plug)> emitting event: {“attribute_id”:“switch”,“capability_id”:“switch”,“component_id”:“main”,“state”:{“value”:“on”}}
2022-11-27T22:33:45.610854450+00:00 DEBUG Zigbee Switch Power Mc Aubess TS011F Plug device thread event handled
Apologies for breaking it into 3, I could not upload it otherwise. I see that it is picking up the right driver, but there is something off :confused:
@nickolasemp
Please, could You remove the format </> for logs?
For me is better see It as CLI
@Mariano_Colmenarejo sure thing, done
@nickolasemp
What I see in the logs is that it works fine.
It emits on and off, power 0w and energy 3kwh.
The error seen in the logs does not affect operation.
This is a problem with some Tuya devices, which emit values for the generic body with unknown data types for the default libraries. It does not affect the capabilities of the profile.
It should work fine.
What is not working for you?
When I click on the tile, it does not show anything. I have recorded my screen that I click on another tile that shows temperature stuff and then I go and click the power socket tile. Please see below:
Hi @nickolasemp
I have never seen such behavior and I have not seen anyone report this before.
It has to be a problem with the App, that is not controlled by the driver.
Did you try clearing the cache of the app, if you use Android.?
Do a reboot of the hub?
I assume you have already tried uninstalling and reinstalling device.
Hello @Mariano_Colmenarejo
I have just rebooted the hub, cleared the cache and uninstalled and reinstalled the device. Still the same behavior. Smartthings App is at 1.7.91.24.
@nickolasemp
Are You tried if works in my.smartthings.com.
My be @nayelyz can help
