MOES Star Ring 2/3 Gang Swtich display
I able to add into smartthings using this driver
However, the 2 gang switch is showed as 1 device in the devices list. I need to click inside to control individual switche. Is there a way to display each switch in the device list? Thank you.
Thank you
Open device tile > click 3 dots in upper right > select settings > and see if there is an option to create child devices. I don’t know if this option exists, but if it does that is how you would do it.
Thank you. I saw the option to create single device for switch 2.
