[ST EDGE] Z-Wave Lock PH
@philh30
My apologies!
I mistakenly posted about your Z-Wave Lock PH Edge Driver for Schlage 468/469 Locks under your [ST Edge] Z-Wave Masquerade Post !
I’m bringing it into this new post focused on your Z-Wave Lock PH Edge Driver for future clarity :slight_smile:
Now following up on my last post…
I spoke too soon :frowning:
In Smart Things Home Monitor, I had a 30 second delay set for the response. I think Home Monitor was responding to when I physically “Unlocked” the door, not the “Activity Alert”.
If someone can recommend a way to get the Schlage Lock to activate Home Monitor when there is Activity Detected, it would be greatly appreciated.
STHM doesn’t use the tamperAlert capability. You could set up a virtual sensor of one of the types that it does use (maybe contact sensor?) and use routines to sync the virtual sensor with the tamperAlert capability.
THANK YOU @philh30 !!!
I’m dropping in a (more or less) complete Step-By-Step here should anyone else like to Enable the Tamper Alert of their Schlage BE468/468 Lock in SmartThings Home Monitor Security.
STEPS COMMENTS
Join Philh30’s Channel Drivers: Philh30 - Z-Wave Drivers - philh30 - Overview and Invite
Install Philh30’s Lock Drivers: Z-Wave Lock PH v1.00
Change Your Schlage Lock Driver: IF your Driver is already an Edge Driver, change it in Device/3-Dots/Driver/SelectDifferentDriver to Z-Wave Lock PH v1.00
If it’s NOT an Edge Driver Already: Remove your old Schlage Lock from your Z-Wave Network first; Then Add it again; Should grab Philh30’s Z-Wave Driver
Set Schlage Lock Alarm Mode to Tamper: Edit the Schlage Lock Device in SmartThings. Change Alarm Mode to Tamper (adjust the Sensitivity to your liking).
NOTE THIS WILL ENABLE A LOUD AUDIBLE ALARM FROM WITHIN THE LOCK ITSELF.
THE TAMPER ALERT WILL ONLY FIRE OFF WHEN THE DOOR IS LOCKED AND DOOR IS PUSHED OR LOCK IS TAMPERED
IF Controls are Disabled: Try swiping down in the Device Detail Screen a few times to refresh it. Controls should become enabled.
Create a Virtual Driver TAustin Follow the Instructions there for the Channel Invitation
Install Virtual Devices V2 Driver: Click the link; Available Drivers; Install Virtual Devices V2
Create a Virtual Motion Sensor: Press the Device Card vEdge Virtual Devices v2 (may be found in No Room Assigned; but may need search in All Devices
Quantity to Create: 1 (unless you’re doing more locks at the same time)
Select & Create Virtual Device(s)
Choose Motion Sensor (it creates the device)
Note: Virtual Device Inventory, then the Type of Device, will show you how many Virtual Devices of that type you’ve created.
Go to No Room Assigned, find the vEdge Motion Device you created above and select it.
Edit the Name to your liking (ex: vEdge Foyer Tamper)
Edit Settings: Auto Restore to Inactive; 10 seconds
Create a Routine: Press Routines at the bottom of the Device Card
Routine Name = Foyer Door - Tampered
IF = Select your Schlage Lock. Under Main, select Tamper Alert: Tampered
THEN = Select your vEdge Foyer Tamper Device Card. Select Turn On; Auto Turn Off = After 10 seconds
SmartThings Home Monitor Settings Gear: Security; Set Up Armed (away) Sensors: Use All Motion Sensors (OR Toggle OFF, then press Text to select Individual sensors)
Assure your vEdge Foyer Tamper is selected
Security; Set Up Armed (stay) Sensors: Use All Motion Sensors (OR Toggle OFF, then press Text to select Individual sensors)
Anyone have a method of Triggering the Tamper Alert of the Schlage BE469 Alarm from within SmartThings?
I’d like to have a routine that causes the Tamper Alert to sound.
So far, the only way I can get the Alarm to sound is by, well, physically tampering with the Lock :grin:
Got both of my locks switched over to your drivers. One is working completely fine. The other gives me the “This device has not updated yet…” message and only the Alarm mode is not populated in the tile. I’ve attached a logcat of the issue. The lock in question is a Schlage BE469 FW ver: MAIN_8.0.
For both of the locks, the setting to disable “Query lock codes on refresh” will not stay set and will revert to being enabled one you leave the Settings dialog. The other lock is a Schlage BE469ZP FW ver: 0.10.8. My phone is a Galaxy S10+ running Android 12 and ST App ver 1.7.94.21
Thanks for this driver @philh30!
2023-01-17T17:01:42.940455397+00:00 TRACE Z-Wave Lock PH v1.00  Received event with handler capability
2023-01-17T17:01:42.968973001+00:00 INFO Z-Wave Lock PH v1.00  <ZwaveDevice: 95130d4e-f4ee-4c39-b624-ad6013361692 [38] (Laundry Room Door Lock)> received command: {"args":{},"capability":"refresh","command":"refresh","component":"main","positional_args":{}}
2023-01-17T17:01:42.976276085+00:00 TRACE Z-Wave Lock PH v1.00  Found CapabilityCommandDispatcher handler in zwave_lock -> Schlage Lock -> Schlage BE469
2023-01-17T17:01:42.983224293+00:00 INFO Z-Wave Lock PH v1.00  <ZwaveDevice: 95130d4e-f4ee-4c39-b624-ad6013361692 [38] (Laundry Room Door Lock)> sending Z-Wave command: {args={}, cmd_class="DOOR_LOCK", cmd_id="OPERATION_GET", dst_channels={}, encap="AUTO", payload="", src_channel=0, version=1}
2023-01-17T17:01:42.996772731+00:00 TRACE Z-Wave Lock PH v1.00  Z-Wave command(d4db733a) queued for radio transmission: CC:Door Lock, CID:0x02
2023-01-17T17:01:43.003451731+00:00 INFO Z-Wave Lock PH v1.00  <ZwaveDevice: 95130d4e-f4ee-4c39-b624-ad6013361692 [38] (Laundry Room Door Lock)> emitting event: {"attribute_id":"lockCodes","capability_id":"lockCodes","component_id":"main","state":{"value":"{}"}}
2023-01-17T17:01:43.090007043+00:00 INFO Z-Wave Lock PH v1.00  <ZwaveDevice: 95130d4e-f4ee-4c39-b624-ad6013361692 [38] (Laundry Room Door Lock)> emitting event: {"attribute_id":"scanCodes","capability_id":"lockCodes","component_id":"main","state":{"value":"Scanning"}}
2023-01-17T17:01:43.172332293+00:00 INFO Z-Wave Lock PH v1.00  <ZwaveDevice: 95130d4e-f4ee-4c39-b624-ad6013361692 [38] (Laundry Room Door Lock)> sending Z-Wave command: {args={user_identifier=1}, cmd_class="USER_CODE", cmd_id="GET", dst_channels={}, encap="AUTO", payload="\x01", src_channel=0, version=1}
2023-01-17T17:01:43.188060480+00:00 TRACE Z-Wave Lock PH v1.00  Z-Wave command(5e989e5e) queued for radio transmission: CC:User Code, CID:0x02
2023-01-17T17:01:43.194182022+00:00 INFO Z-Wave Lock PH v1.00  <ZwaveDevice: 95130d4e-f4ee-4c39-b624-ad6013361692 [38] (Laundry Room Door Lock)> sending Z-Wave command: {args={parameter_number=3}, cmd_class="CONFIGURATION", cmd_id="GET", dst_channels={}, encap="AUTO", payload="\x03", src_channel=0, version=1}
2023-01-17T17:01:43.205451355+00:00 TRACE Z-Wave Lock PH v1.00  Z-Wave command(49cea732) queued for radio transmission: CC:Configuration, CID:0x05
2023-01-17T17:01:43.210756939+00:00 INFO Z-Wave Lock PH v1.00  <ZwaveDevice: 95130d4e-f4ee-4c39-b624-ad6013361692 [38] (Laundry Room Door Lock)> sending Z-Wave command: {args={parameter_number=4}, cmd_class="CONFIGURATION", cmd_id="GET", dst_channels={}, encap="AUTO", payload="\x04", src_channel=0, version=1}
2023-01-17T17:01:43.221487730+00:00 TRACE Z-Wave Lock PH v1.00  Z-Wave command(fa3ff929) queued for radio transmission: CC:Configuration, CID:0x05
2023-01-17T17:01:43.226844085+00:00 INFO Z-Wave Lock PH v1.00  <ZwaveDevice: 95130d4e-f4ee-4c39-b624-ad6013361692 [38] (Laundry Room Door Lock)> sending Z-Wave command: {args={parameter_number=5}, cmd_class="CONFIGURATION", cmd_id="GET", dst_channels={}, encap="AUTO", payload="\x05", src_channel=0, version=1}
2023-01-17T17:01:43.240138439+00:00 TRACE Z-Wave Lock PH v1.00  Z-Wave command(8f2d93c6) queued for radio transmission: CC:Configuration, CID:0x05
2023-01-17T17:01:43.246101189+00:00 INFO Z-Wave Lock PH v1.00  <ZwaveDevice: 95130d4e-f4ee-4c39-b624-ad6013361692 [38] (Laundry Room Door Lock)> sending Z-Wave command: {args={parameter_number=7}, cmd_class="CONFIGURATION", cmd_id="GET", dst_channels={}, encap="AUTO", payload="\x07", src_channel=0, version=1}
2023-01-17T17:01:43.266347876+00:00 TRACE Z-Wave Lock PH v1.00  Z-Wave command(aaaeb1f4) queued for radio transmission: CC:Configuration, CID:0x05
2023-01-17T17:01:43.272093459+00:00 INFO Z-Wave Lock PH v1.00  <ZwaveDevice: 95130d4e-f4ee-4c39-b624-ad6013361692 [38] (Laundry Room Door Lock)> sending Z-Wave command: {args={parameter_number=8}, cmd_class="CONFIGURATION", cmd_id="GET", dst_channels={}, encap="AUTO", payload="\x08", src_channel=0, version=1}
2023-01-17T17:01:43.282454251+00:00 TRACE Z-Wave Lock PH v1.00  Z-Wave command(e4bc9871) queued for radio transmission: CC:Configuration, CID:0x05
2023-01-17T17:01:43.287928168+00:00 INFO Z-Wave Lock PH v1.00  <ZwaveDevice: 95130d4e-f4ee-4c39-b624-ad6013361692 [38] (Laundry Room Door Lock)> sending Z-Wave command: {args={parameter_number=9}, cmd_class="CONFIGURATION", cmd_id="GET", dst_channels={}, encap="AUTO", payload="\x09", src_channel=0, version=1}
2023-01-17T17:01:43.298292876+00:00 TRACE Z-Wave Lock PH v1.00  Z-Wave command(2c9e0e13) queued for radio transmission: CC:Configuration, CID:0x05
2023-01-17T17:01:43.303945897+00:00 INFO Z-Wave Lock PH v1.00  <ZwaveDevice: 95130d4e-f4ee-4c39-b624-ad6013361692 [38] (Laundry Room Door Lock)> sending Z-Wave command: {args={parameter_number=10}, cmd_class="CONFIGURATION", cmd_id="GET", dst_channels={}, encap="AUTO", payload="\x0A", src_channel=0, version=1}
2023-01-17T17:01:43.313801959+00:00 TRACE Z-Wave Lock PH v1.00  Z-Wave command(1d3603ec) queued for radio transmission: CC:Configuration, CID:0x05
2023-01-17T17:01:43.319395105+00:00 INFO Z-Wave Lock PH v1.00  <ZwaveDevice: 95130d4e-f4ee-4c39-b624-ad6013361692 [38] (Laundry Room Door Lock)> sending Z-Wave command: {args={parameter_number=11}, cmd_class="CONFIGURATION", cmd_id="GET", dst_channels={}, encap="AUTO", payload="\x0B", src_channel=0, version=1}
2023-01-17T17:01:43.329250689+00:00 TRACE Z-Wave Lock PH v1.00  Z-Wave command(caaf32af) queued for radio transmission: CC:Configuration, CID:0x05
2023-01-17T17:01:43.335030397+00:00 INFO Z-Wave Lock PH v1.00  <ZwaveDevice: 95130d4e-f4ee-4c39-b624-ad6013361692 [38] (Laundry Room Door Lock)> sending Z-Wave command: {args={parameter_number=15}, cmd_class="CONFIGURATION", cmd_id="GET", dst_channels={}, encap="AUTO", payload="\x0F", src_channel=0, version=1}
2023-01-17T17:01:43.344702314+00:00 TRACE Z-Wave Lock PH v1.00  Z-Wave command(72b17655) queued for radio transmission: CC:Configuration, CID:0x05
2023-01-17T17:01:43.348815980+00:00 DEBUG Z-Wave Lock PH v1.00  Laundry Room Door Lock device thread event handled
2023-01-17T17:01:43.352721355+00:00 TRACE Z-Wave Lock PH v1.00  Received event with handler capability
2023-01-17T17:01:43.366702626+00:00 INFO Z-Wave Lock PH v1.00  <ZwaveDevice: 95130d4e-f4ee-4c39-b624-ad6013361692 [38] (Laundry Room Door Lock)> received command: {"args":{},"capability":"refresh","command":"refresh","component":"settings","positional_args":{}}
2023-01-17T17:01:43.371997689+00:00 TRACE Z-Wave Lock PH v1.00  Found CapabilityCommandDispatcher handler in zwave_lock -> Schlage Lock -> Schlage BE469
2023-01-17T17:01:43.377559918+00:00 INFO Z-Wave Lock PH v1.00  <ZwaveDevice: 95130d4e-f4ee-4c39-b624-ad6013361692 [38] (Laundry Room Door Lock)> sending Z-Wave command: {args={}, cmd_class="DOOR_LOCK", cmd_id="OPERATION_GET", dst_channels={}, encap="AUTO", payload="", src_channel=0, version=1}
2023-01-17T17:01:43.387642439+00:00 TRACE Z-Wave Lock PH v1.00  Z-Wave command(00bc8525) queued for radio transmission: CC:Door Lock, CID:0x02
2023-01-17T17:01:43.392299709+00:00 INFO Z-Wave Lock PH v1.00  <ZwaveDevice: 95130d4e-f4ee-4c39-b624-ad6013361692 [38] (Laundry Room Door Lock)> emitting event: {"attribute_id":"lockCodes","capability_id":"lockCodes","component_id":"main","state":{"value":"{}"}}
2023-01-17T17:01:43.474094063+00:00 INFO Z-Wave Lock PH v1.00  <ZwaveDevice: 95130d4e-f4ee-4c39-b624-ad6013361692 [38] (Laundry Room Door Lock)> sending Z-Wave command: {args={user_identifier=1}, cmd_class="USER_CODE", cmd_id="GET", dst_channels={}, encap="AUTO", payload="\x01", src_channel=0, version=1}
2023-01-17T17:01:43.488920209+00:00 TRACE Z-Wave Lock PH v1.00  Z-Wave command(3951a4c3) queued for radio transmission: CC:User Code, CID:0x02
2023-01-17T17:01:43.494989980+00:00 INFO Z-Wave Lock PH v1.00  <ZwaveDevice: 95130d4e-f4ee-4c39-b624-ad6013361692 [38] (Laundry Room Door Lock)> sending Z-Wave command: {args={parameter_number=3}, cmd_class="CONFIGURATION", cmd_id="GET", dst_channels={}, encap="AUTO", payload="\x03", src_channel=0, version=1}
2023-01-17T17:01:43.509768605+00:00 TRACE Z-Wave Lock PH v1.00  Z-Wave command(6fbca9a1) queued for radio transmission: CC:Configuration, CID:0x05
2023-01-17T17:01:43.515291022+00:00 INFO Z-Wave Lock PH v1.00  <ZwaveDevice: 95130d4e-f4ee-4c39-b624-ad6013361692 [38] (Laundry Room Door Lock)> sending Z-Wave command: {args={parameter_number=4}, cmd_class="CONFIGURATION", cmd_id="GET", dst_channels={}, encap="AUTO", payload="\x04", src_channel=0, version=1}
2023-01-17T17:01:43.527186230+00:00 TRACE Z-Wave Lock PH v1.00  Z-Wave command(e70644fb) queued for radio transmission: CC:Configuration, CID:0x05
2023-01-17T17:01:43.533585022+00:00 INFO Z-Wave Lock PH v1.00  <ZwaveDevice: 95130d4e-f4ee-4c39-b624-ad6013361692 [38] (Laundry Room Door Lock)> sending Z-Wave command: {args={parameter_number=5}, cmd_class="CONFIGURATION", cmd_id="GET", dst_channels={}, encap="AUTO", payload="\x05", src_channel=0, version=1}
2023-01-17T17:01:43.546255397+00:00 TRACE Z-Wave Lock PH v1.00  Z-Wave command(d1efccf4) queued for radio transmission: CC:Configuration, CID:0x05
2023-01-17T17:01:43.552910772+00:00 INFO Z-Wave Lock PH v1.00  <ZwaveDevice: 95130d4e-f4ee-4c39-b624-ad6013361692 [38] (Laundry Room Door Lock)> sending Z-Wave command: {args={parameter_number=7}, cmd_class="CONFIGURATION", cmd_id="GET", dst_channels={}, encap="AUTO", payload="\x07", src_channel=0, version=1}
2023-01-17T17:01:43.563350605+00:00 TRACE Z-Wave Lock PH v1.00  Z-Wave command(c0752a82) queued for radio transmission: CC:Configuration, CID:0x05
2023-01-17T17:01:43.570470251+00:00 INFO Z-Wave Lock PH v1.00  <ZwaveDevice: 95130d4e-f4ee-4c39-b624-ad6013361692 [38] (Laundry Room Door Lock)> sending Z-Wave command: {args={parameter_number=8}, cmd_class="CONFIGURATION", cmd_id="GET", dst_channels={}, encap="AUTO", payload="\x08", src_channel=0, version=1}
2023-01-17T17:01:43.580669855+00:00 TRACE Z-Wave Lock PH v1.00  Z-Wave command(18ae5c53) queued for radio transmission: CC:Configuration, CID:0x05
2023-01-17T17:01:43.586396980+00:00 INFO Z-Wave Lock PH v1.00  <ZwaveDevice: 95130d4e-f4ee-4c39-b624-ad6013361692 [38] (Laundry Room Door Lock)> sending Z-Wave command: {args={parameter_number=9}, cmd_class="CONFIGURATION", cmd_id="GET", dst_channels={}, encap="AUTO", payload="\x09", src_channel=0, version=1}
2023-01-17T17:01:43.598592751+00:00 TRACE Z-Wave Lock PH v1.00  Z-Wave command(92c8fb42) queued for radio transmission: CC:Configuration, CID:0x05
2023-01-17T17:01:43.607121001+00:00 INFO Z-Wave Lock PH v1.00  <ZwaveDevice: 95130d4e-f4ee-4c39-b624-ad6013361692 [38] (Laundry Room Door Lock)> sending Z-Wave command: {args={parameter_number=10}, cmd_class="CONFIGURATION", cmd_id="GET", dst_channels={}, encap="AUTO", payload="\x0A", src_channel=0, version=1}
2023-01-17T17:01:43.618383730+00:00 TRACE Z-Wave Lock PH v1.00  Z-Wave command(561430ed) queued for radio transmission: CC:Configuration, CID:0x05
2023-01-17T17:01:43.626354730+00:00 INFO Z-Wave Lock PH v1.00  <ZwaveDevice: 95130d4e-f4ee-4c39-b624-ad6013361692 [38] (Laundry Room Door Lock)> sending Z-Wave command: {args={parameter_number=11}, cmd_class="CONFIGURATION", cmd_id="GET", dst_channels={}, encap="AUTO", payload="\x0B", src_channel=0, version=1}
2023-01-17T17:01:43.638567917+00:00 TRACE Z-Wave Lock PH v1.00  Z-Wave command(ada0c349) queued for radio transmission: CC:Configuration, CID:0x05
2023-01-17T17:01:43.645987542+00:00 INFO Z-Wave Lock PH v1.00  <ZwaveDevice: 95130d4e-f4ee-4c39-b624-ad6013361692 [38] (Laundry Room Door Lock)> sending Z-Wave command: {args={parameter_number=15}, cmd_class="CONFIGURATION", cmd_id="GET", dst_channels={}, encap="AUTO", payload="\x0F", src_channel=0, version=1}
2023-01-17T17:01:43.657091459+00:00 TRACE Z-Wave Lock PH v1.00  Z-Wave command(feca0892) queued for radio transmission: CC:Configuration, CID:0x05
2023-01-17T17:01:43.661690084+00:00 DEBUG Z-Wave Lock PH v1.00  Laundry Room Door Lock device thread event handled
2023-01-17T17:01:44.484393083+00:00 TRACE Z-Wave Lock PH v1.00  Z-Wave command(d4db733a) transmit status: TRANSMIT_COMPLETE_OK
2023-01-17T17:01:45.165023166+00:00 TRACE Z-Wave Lock PH v1.00  Received event with handler unnamed
2023-01-17T17:01:45.177768812+00:00 INFO Z-Wave Lock PH v1.00  <ZwaveDevice: 95130d4e-f4ee-4c39-b624-ad6013361692 [38] (Laundry Room Door Lock)> received Z-Wave command: {args={door_condition=0, door_lock_mode="DOOR_SECURED", inside_door_handles_mode=0, lock_timeout_minutes=254, lock_timeout_seconds=254, outside_door_handles_mode=0}, cmd_class="DOOR_LOCK", cmd_id="OPERATION_REPORT", dst_channels={}, encap="S0", payload="\xFF\x00\x00\xFE\xFE", src_channel=0, version=1}
2023-01-17T17:01:45.194205374+00:00 TRACE Z-Wave Lock PH v1.00  Found ZwaveDispatcher handler in zwave_lock
2023-01-17T17:01:45.199320291+00:00 INFO Z-Wave Lock PH v1.00  <ZwaveDevice: 95130d4e-f4ee-4c39-b624-ad6013361692 [38] (Laundry Room Door Lock)> emitting event: {"attribute_id":"lock","capability_id":"lock","component_id":"main","state":{"value":"locked"}}
2023-01-17T17:01:45.276004353+00:00 DEBUG Z-Wave Lock PH v1.00  Laundry Room Door Lock device thread event handled
2023-01-17T17:01:46.365570269+00:00 TRACE Z-Wave Lock PH v1.00  Z-Wave command(5e989e5e) transmit status: TRANSMIT_COMPLETE_OK
2023-01-17T17:01:46.734734352+00:00 TRACE Z-Wave Lock PH v1.00  Z-Wave command(49cea732) transmit status: TRANSMIT_COMPLETE_OK
2023-01-17T17:01:46.774005019+00:00 TRACE Z-Wave Lock PH v1.00  Received event with handler unnamed
2023-01-17T17:01:46.786147352+00:00 INFO Z-Wave Lock PH v1.00  <ZwaveDevice: 95130d4e-f4ee-4c39-b624-ad6013361692 [38] (Laundry Room Door Lock)> received Z-Wave command: {args={user_code="**********", user_id_status="ENABLED_GRANT_ACCESS", user_identifier=1}, cmd_class="USER_CODE", cmd_id="REPORT", dst_channels={}, encap="S0", payload="\x01\x01\x2A\x2A\x2A\x2A\x2A\x2A\x2A\x2A\x2A\x2A", src_channel=0, version=1}
2023-01-17T17:01:46.810670102+00:00 TRACE Z-Wave Lock PH v1.00  Found ZwaveDispatcher handler in zwave_lock -> Schlage Lock
2023-01-17T17:01:46.816184519+00:00 INFO Z-Wave Lock PH v1.00  <ZwaveDevice: 95130d4e-f4ee-4c39-b624-ad6013361692 [38] (Laundry Room Door Lock)> emitting event: {"attribute_id":"lockCodes","capability_id":"lockCodes","component_id":"main","state":{"value":"{}"}}
2023-01-17T17:01:46.899563685+00:00 INFO Z-Wave Lock PH v1.00  <ZwaveDevice: 95130d4e-f4ee-4c39-b624-ad6013361692 [38] (Laundry Room Door Lock)> emitting event: {"attribute_id":"codeChanged","capability_id":"lockCodes","component_id":"main","state":{"data":{"codeName":"Code 1"},"value":"1 set"},"state_change":true}
2023-01-17T17:01:47.004913539+00:00 INFO Z-Wave Lock PH v1.00  <ZwaveDevice: 95130d4e-f4ee-4c39-b624-ad6013361692 [38] (Laundry Room Door Lock)> sending Z-Wave command: {args={user_identifier=2}, cmd_class="USER_CODE", cmd_id="GET", dst_channels={}, encap="AUTO", payload="\x02", src_channel=0, version=1}
2023-01-17T17:01:47.020749081+00:00 TRACE Z-Wave Lock PH v1.00  Z-Wave command(78fb9ebf) queued for radio transmission: CC:User Code, CID:0x02
2023-01-17T17:01:47.026760310+00:00 DEBUG Z-Wave Lock PH v1.00  Laundry Room Door Lock device thread event handled
2023-01-17T17:01:47.087694102+00:00 TRACE Z-Wave Lock PH v1.00  Z-Wave command(fa3ff929) transmit status: TRANSMIT_COMPLETE_OK
2023-01-17T17:01:47.112432935+00:00 TRACE Z-Wave Lock PH v1.00  Received event with handler unnamed
2023-01-17T17:01:47.122142310+00:00 INFO Z-Wave Lock PH v1.00  <ZwaveDevice: 95130d4e-f4ee-4c39-b624-ad6013361692 [38] (Laundry Room Door Lock)> received Z-Wave command: {args={configuration_value=-1, parameter_number=3, size=1}, cmd_class="CONFIGURATION", cmd_id="REPORT", dst_channels={}, encap="S0", payload="\x03\x01\xFF", src_channel=0, version=1}
2023-01-17T17:01:47.138168039+00:00 TRACE Z-Wave Lock PH v1.00  Found ZwaveDispatcher handler in zwave_lock -> Schlage Lock -> Schlage BE469
2023-01-17T17:01:47.146214310+00:00 INFO Z-Wave Lock PH v1.00  <ZwaveDevice: 95130d4e-f4ee-4c39-b624-ad6013361692 [38] (Laundry Room Door Lock)> emitting event: {"attribute_id":"keypadBeep","capability_id":"platinummassive43262.keypadBeep","component_id":"settings","state":{"value":"beep"}}
2023-01-17T17:01:47.230868289+00:00 DEBUG Z-Wave Lock PH v1.00  Laundry Room Door Lock device thread event handled
2023-01-17T17:01:49.064566579+00:00 TRACE Z-Wave Lock PH v1.00  Z-Wave command(8f2d93c6) transmit status: TRANSMIT_COMPLETE_OK
2023-01-17T17:01:49.264754350+00:00 TRACE Z-Wave Lock PH v1.00  Z-Wave command(aaaeb1f4) transmit status: TRANSMIT_COMPLETE_OK
2023-01-17T17:01:49.425331454+00:00 TRACE Z-Wave Lock PH v1.00  Z-Wave command(e4bc9871) transmit status: TRANSMIT_COMPLETE_OK
2023-01-17T17:01:50.848724327+00:00 TRACE Z-Wave Lock PH v1.00  Z-Wave command(2c9e0e13) transmit status: TRANSMIT_COMPLETE_OK
2023-01-17T17:01:51.024819181+00:00 TRACE Z-Wave Lock PH v1.00  Z-Wave command(1d3603ec) transmit status: TRANSMIT_COMPLETE_OK
2023-01-17T17:01:51.224585160+00:00 TRACE Z-Wave Lock PH v1.00  Z-Wave command(caaf32af) transmit status: TRANSMIT_COMPLETE_OK
2023-01-17T17:01:51.425670785+00:00 TRACE Z-Wave Lock PH v1.00  Z-Wave command(72b17655) transmit status: TRANSMIT_COMPLETE_OK
2023-01-17T17:01:51.625768389+00:00 TRACE Z-Wave Lock PH v1.00  Z-Wave command(00bc8525) transmit status: TRANSMIT_COMPLETE_OK
2023-01-17T17:01:51.796487201+00:00 TRACE Z-Wave Lock PH v1.00  Z-Wave command(3951a4c3) transmit status: TRANSMIT_COMPLETE_OK
2023-01-17T17:01:52.026606326+00:00 TRACE Z-Wave Lock PH v1.00  Z-Wave command(6fbca9a1) transmit status: TRANSMIT_COMPLETE_OK
2023-01-17T17:01:52.236819472+00:00 TRACE Z-Wave Lock PH v1.00  Z-Wave command(e70644fb) transmit status: TRANSMIT_COMPLETE_OK
2023-01-17T17:01:52.424911638+00:00 TRACE Z-Wave Lock PH v1.00  Z-Wave command(d1efccf4) transmit status: TRANSMIT_COMPLETE_OK
2023-01-17T17:01:52.624619721+00:00 TRACE Z-Wave Lock PH v1.00  Z-Wave command(c0752a82) transmit status: TRANSMIT_COMPLETE_OK
2023-01-17T17:01:52.787062867+00:00 TRACE Z-Wave Lock PH v1.00  Z-Wave command(18ae5c53) transmit status: TRANSMIT_COMPLETE_OK
2023-01-17T17:01:52.924911679+00:00 TRACE Z-Wave Lock PH v1.00  Z-Wave command(92c8fb42) transmit status: TRANSMIT_COMPLETE_OK
2023-01-17T17:01:53.124615867+00:00 TRACE Z-Wave Lock PH v1.00  Z-Wave command(561430ed) transmit status: TRANSMIT_COMPLETE_OK
2023-01-17T17:01:53.324802492+00:00 TRACE Z-Wave Lock PH v1.00  Z-Wave command(ada0c349) transmit status: TRANSMIT_COMPLETE_OK
2023-01-17T17:01:53.524659346+00:00 TRACE Z-Wave Lock PH v1.00  Z-Wave command(feca0892) transmit status: TRANSMIT_COMPLETE_OK
2023-01-17T17:01:53.727567387+00:00 TRACE Z-Wave Lock PH v1.00  Z-Wave command(78fb9ebf) transmit status: TRANSMIT_COMPLETE_OK
@h0ckeysk8er Phil had me swipe down in the Device Card. Seems like I did it 5-10 times (waiting a few minutes between each refresh) and it finally refreshed.
Thanks. I’ve done it hundreds of times over the last few days with no change.
Alarm is device function that can only be activated and deactivated on the lock by trying to get in, etc. I am not talking about enabling/disabling in the driver app. If alarm goes off, you have to push Schlage button to stop it. You can’t do this from the app
The Alarm mode is displayed and can be modified in the device tile. It’s working fine on one of my locks but not the other.
Try creating and running a scene that changes alarm mode. That should prompt the lock to send back the new value just for that one. Your logs show the driver querying everything when you trigger refresh but the lock is only responding to the first configuration get. Do you have a beaming repeater near the lock?
Unless something has changed, the settings menu is read-only to the driver, so whatever’s happening is an app issue.
Using the Routine to set the value did the trick.
Any way to hunt down why the setting might not stay disabled?
Do you have another device with a different version of the app that you can try?
Hmm…let me try it from an iOS device and get back to you.
Confirmed same behavior on iOS ST app.
Have you entered a code length for the other setting? I’ve had issues in the past with ST not liking fields that weren’t required and were left null. Make sure you use your current code length or it’ll blow out all of your codes. And maybe wait to test that until they get SLGA fixed…
Yeah, I’m afraid to try it even with SLGA working.
I made the mistake of trying out the alpha of the new lock manager from Erik Thayer not realizing it would blow out all my codes and reject changes from SLGA :-/
I am not talking about enabling/disabling within the driver, I know that can be turned on and off and that sensitivity can be adjusted.
I am saying that alarm can be only triggered on actual physical device, on the deadbolt, by trying to force entry, and stopped by pushing Shlage button on iside.
BTW not all schalge deadbolts came with Alarm option. Some of them don’t have it
Yes, I understand. My issue was with the attribute not populating properly. Once I set it via a routine, it fixed the problem.
There are some deadbolts without Alarm function (468). They look exactly like one with Alarm (469). I’ll look around to find list of those without.
