Turns out there is a bug in the default Z-Wave device handler in the stock Z-Wave Edge driver that was causing code names to be reset to the default periodically. @philh30 has released an updated beta Edge driver of his Z-Wave Lock Edge driver that supplies the proper codeName upon unlock and also prevents the periodic resetting of the lock code names to the defaults. I’ve been using it for around a week now and getting solid results. I’ve now set up Rules in Sharptools that evaluates the $context.event.data.codeName variable and performs per user actions based on who unlocked the door.
The updated beta version of his lock driver is in the same channel as the original.
