Sudden issue adding door code with Smart Lock Guest Access
@rk1985 When you open the Device Card for each lock, are all of the Controls active/working (or are any of them disabled, such as “Tamper Alert”, “Alarm”, etc.) ? If so, pull down on the Device card several times to refresh it until the Controls become active.
Also, not sure I have the confidence in SmartThings properly converting everything over. All of our locks have behaved very well with @philh30 's Edge Drivers!
I would strongly recommend following the Step-By-Step in the post that @jkp referenced to assure you’re using @philh30 's Edge Drivers.
