Color coordinater and lock codes?
ST app has a service called Smart Lock Guest Access that allows you to change codes on your Schlage lock. Unfortunately, it is having an issue this morning and is not working :frowning: Also, if your locks have already migrated to the stock Z-Wave lock driver, I would recommend installing and switching to the Z-Lock Edge driver from @philh30 which is more full featured than the stock driver. If it hasn’t switched over from DTH, you will have to exclude/include your lock to switch it over.
Sharptools is an option for vacation/away lighting. If you have Alexa, some folks have been using virtual switches/contact sensors to trigger Alexa to turn on Guard mode to manage lighting when they are away.
