###This SmartApp and Device Handlers are Outdated
Please follow the link below to the newest version:
https://community.smartthings.com/t/release-nst-manager-v5-0/?source_topic_id=50907###This SmartApp and Device Handlers are Outdated
https://community.smartthings.com/t/release-nst-manager-v5-0/?source_topic_id=50907It seems as if the versions between the groovy code and the JSON are inconsistent. After updating to the latest version (via Github in the IDE) I seem to have v2.3.5 but I’m being told that 2.5 is available (which according to Github 2.3.5 is the latest…)
Thanks for catching Andreas… I have updated the code
Thanks for the latest update, However when I upgraded I now get that my fan is not supported.
Can you send me a Screenshot please?
Damn it… That’s because of the android client bugs. I completely forgot about that. Do you have an ipod or ipad you can use to do the initial setup?
No only Android
Okay It took a while but I was eventually able to choose my location. And the complete uninstall and reinstall fixed the fan
I’m sorry i have tickets in to support but completely forgot about the issue.
At line 262 of the manager code if you change submitOnChange: true from/to submitOnChange: falseit will allow you to move passed that. It will require you to go back once after selecting the location to refresh the page
I’ve updated but keep getting notified that there is an update.
After the update I can’t change the temp or the fan mode. What should I do?
I am having the same issue. iOS. Logs dont reveal much. Tried using my cooling temp:
coolingSetpointUp()…
Did you guys open the manager app and press done?
Looking through the exception data I’m seeing a ton of not authorized meaning that person’s token has been revoked. I just can’t tell who because it only collects the exception message. So please verify that your install is functional
Yes, I can confirm it’s installed, working properly from a token perspective. I get accurate updates.
Well if there is an error than it will likely generate an error in the thermostat logs or the manager app logs
Nothing in logs but this:
15377292-9778-40f3-be60-bcdb100d6859 9:55:08 AM: trace coolingSetpointUp()…
I hate to ask but did you update the device handlers?
