I have been using the Nest Manager for a while now and I decided to update it. Since updating, nothing related to it seems to be working. When I turn up the temp it does nothing. The temp uv humidity and luminance reading do not change. I updated the smartapp and device handlers. The Nest Manager says that it is version 5.5.5. Did I miss something? Any help would be appreciated.
E_Sch
(Eric)
November 5, 2018, 8:55pm
2
It would be good to see IDE log messages, or error messages if you go into NM in the ST mobile app.
I don’t know where you upgraded from / to. I assume you have your own nest developer account information?
You can also turn on remote diagnostics, and share that URL with us as a private message if you want us to take a look.
yvesracine
(Yves Racine)
November 5, 2018, 9:08pm
3
There is also other alternatives for your Nest products:
A contribution fee is required due to the amount of work for the design, development, and testing of the devices (equivalent of a few cups of coffee).
The installation steps have been updated to reflect the fact that the installation can now proceed under the new SmartThings mobile app.
To download the SmartThings code, go to www.ecomatiqhomes.com/store
_ For all Nest users regardless if you have a Nest or Google account, my code can expose all your Nest Tstats, Protects, and Sensors under your Nest primary account (except the ones from a partner program such as with an utility).
Automation variables available for your scenarios
[MyNextTstatAutomation]
[Screenshot_2021-10-31-08-29-06-660_com.samsung.android.oneconnect]
MyNextTstat In Fahrenheit with motion/presence according to y…
OK I tried to turn down the heat with the Classic app and here is the logs that showed up.
But the nest thermostat did not register the changes. It still remains on 70. Also the Nest Weather does not update to current conditions.
I have more logs as to where the NM is trying to update but having some issues.
