cpetzny
(Chris Petzny)
January 19, 2023, 4:51pm
#1
Hello,
I migrated my Fibaro FGD-211 dimmer from DTH to Edge and I now have a problem where the dimmer no longer seems to update its status when a change is made from the toggle switch it is wired to. Status changes are only reflected if I manually refresh on the device page in the app (pull down from the top of the screen on iOS).
I can turn the attached lights on and off using the app and routines run when using this approach, but without the status change being sent, the physical switch doesn’t fire off the routines.
Any clues would be much appreciated, or pointers to other threads…
Thanks!!
cpetzny:
Hello,
Thanks!!
If the stock Edge driver was installed for your device, I suggest looking at the driver from @Mariano_Colmenarejo
(New Release) Edge Driver Z-Wave Switch Mc with more Fibaro Devices:
At the request of a user who wanted to use Fibaro devices that were not in the stock driver:
Dimmer-2 FGD-212
Relay Switch FGS-212
Double Relay Switch FGS-222
Roller Shutter 2 (FGR-222)
Roller Shutter 3 (FGR-223)
Wall Plug – type E/F (FGWPE-102 | FGWPF-102) ProductType: 0602
Wall Plug – type E/F (FGWPE-102 | FGWPF-102) ProductType: 0600
Smart Module (FGS-214)
Fibaro RGBW Controller FGRGBWM-441 (driver Z-Wave Bulb Mc)
Fibaro RGBW Controller 2, model 442 (driver Z-Wave Bulb Mc)
Zooz RGBW Dimmer Zen31 (driver Z-Wave Bulb Mc)
I have added them to the stock beta driver Z-Wave Switch, creating 3 new profiles with their main preferences.
Dimmer-2 FGD-212
[image]
[image]
[image]
Relay Swit…
cpetzny
(Chris Petzny)
January 19, 2023, 8:20pm
#3
Unfortunately the fault occurs with both the stock driver and the one linked to above…
I would recommend posting in the thread for the driver at this point.
nayelyz
(Developer Support Team)
January 20, 2023, 9:30pm
#5
Hi, @cpetzny
Do you know the fingerprints for this device?
I found this match on the Z-Wave products official page:
https://products.z-wavealliance.org/products/88?selectedFrequencyId=1
And I couldn’t find a match in the Edge driver for this manufacturer, only the fingerprint for the model Fibaro FGD-212 is included (here ).
cpetzny
(Chris Petzny)
January 21, 2023, 11:21am
#6
Hello,
thanks for getting back to me. There are a number of versions of the device, these are the fingerprints:
zw:L type:1101 mfr:010F prod:0100 model:0109 ver:1.09 zwv:3.42 lib:03 cc:72,86,70,85,8E,26,27,73 ccOut:26,2B
zw:L type:1101 mfr:010F prod:0100 model:100A ver:2.02 zwv:3.52 lib:03 cc:72,86,70,85,8E,26,7A,27,73 ccOut:26,2B
zw:L type:1101 mfr:000F prod:0000 model:100A ver:0.00 zwv:0.00 lib:00 cc:72,86,70,85,8E,26,7A,27,73 ccOut:26,2B
Mine is the middle one (ver 2.02). There is also more information here: https://manuals.fibaro.com/fgd-211/
@Mariano_Colmenarejo is already working hard to get this working with his driver
Thanks,
Chris.
