(New Release) Edge Driver Z-Wave Switch Mc with more Fibaro Devices:
At the request of a user who wanted to use Fibaro devices that were not in the stock driver:
- Dimmer-2 FGD-212
- Relay Switch FGS-212
- Double Relay Switch FGS-222
- Roller Shutter 2 (FGR-222)
- Roller Shutter 3 (FGR-223)
- Wall Plug β type E/F (FGWPE-102 | FGWPF-102) ProductType: 0602
- Wall Plug β type E/F (FGWPE-102 | FGWPF-102) ProductType: 0600
- Smart Module (FGS-214)
- Fibaro RGBW Controller FGRGBWM-441 (driver Z-Wave Bulb Mc)
I have added them to the stock beta driver Z-Wave Switch, creating 3 new profiles with their main preferences.
Dimmer-2 FGD-212
This driver has all devices of smartThings stock beta driver and the three new Fibaro devices.
Tested, they work well and I want to share them in case someone also needs them for these devices that are not in the stock driver and some, like the relays, are old and do not have official DTH either.
Link to the shared channel
SmartThings. Add a little smartness to your things
I added Mc so that the name of the stock driver differs
βββββββββββββββ¬βββββββββββββββββββββββββββββββββββββββ
β Name β Z-Wave Switch Mc β
β Version β 2022-02-11T17:38:39.435083 β
βββββββββββββββ΄βββββββββββββββββββββββββββββββββββββββ
I donβt know if someone from Fibaro will be working on updating their devices that are not in the stock Beta Edge drivers.
Just to tell you that now with Edge drivers it is very easy for you to provide a good service to your many smartThings customers.
Updating them and adding parameter settings in preferences is a matter of investing very little time, almost everything is done in the default libraries and stock drivers.
The cost of the certifications of course, is another matter
- FIBARO ROLLER SHUTTER 2 (FGR-222)
I have added them to the stock beta driver Z-Wave Window Treatment, creating new profile with their main preferences.
After installation need perform a calibration, parameter 29 set to 1, for works as Roller blind (with positioning).
The option Venetian Blind is not added :
Reading the fibaro documentation I think it only works with fibaro zwave commands, configuration parameter 3, value 1 and in its own hub.
(If not and Iβm wrong, this option could be added just like the Fibaro Walli).
This is the version of the driver, which includes all the devices of the stock beta driver and the Fibaro FGR-222
β Name β Z-Wave Window Treatment Mc β
β Version β 2022-02-13T17:31:33.394807 β
I have added Mc to the name to differentiate it from the stock driver
