Hi Guys,
I have Fibaro Dimmer switches (V1) controlling the lights on the stairs but I am having issues when using the physical wall switch.
It seems that if I go to use the switch (momentary) it doesn’t always work and needs me to keep the button pressed to almost wake the device and then I get on/off/dim control as normal.
I have tried installed the device handlers in webcore as it is simply down as a “z-wave dimmer” but I can only see V2 in the directory. I have tried uploading this and see all the parameters but I then lose control of the switch.
Any ideas?
