The new version of this device handler can be found in the first post of the Aeon Labs Aeotec Doorbell Topic.
Anybody try this yet? I will give it a try on one of the doorbells I have today to see whatās what.
The documentation and described abilities looks great!
Iām testing this DH and so far itās working great. Thanks to @krlaframboise.
I still need to setup a SmartApp to use the new āBeepā command
Thanks, are you using the Android mobile app. I was doing a lot of testing in the Android mobile app and all the buttons stopped working once, but after closing out of that screen and re-opening it, everything seemed to work fine. With the reliability of ST lately Iām not sure if it had anything to do with the Device Type.
[quote=āRudiP, post:3, topic:36586ā]
[/quote]Iāve never seen anything use the āToneā compatibility before, but I figured if there was a specific track I used often, I could use beep() in Rule Machine instead of having to remember playTrack(25).
Yep, Iām using the Android mobile app and sometimes it getās stuck. I also just close and reopen the app.
Iām also planning to add the beep() call to some of my Rule Machine rules that I currently donāt play a message and I just want a low volume confirmation sound.
[quote=āRudiP, post:5, topic:36586ā]
[/quote]I just released version 1.1 which should fix this problem, but please let me know if it continues to happen. Thanks
Iāve just tested the new version and itās working great so far. Thanks.
Iām glad to hear it, Iām just hoping it works OK on iPhone because I donāt have one to test with.
Just so everyone knows, the first post in this topic will always have the most recent version of the device handler and its documentation.
Iāve updated the documentation to include screenshots and added links to the important information section that provide additional information and instructions.
Iāve added the capabilities Beacon, Polling, and Refresh to version 1.2. I know they really donāt fit with a doorbell, but I wanted a way to get notified when my internet goes down or I lose power.
These capabilities allowed me to setup a SmartApp that calls the poll method at set intervals (ST doesnāt automatically). It subscribes to the presence attribute from the Beacon capability and sends me SMS and Push messages within a couple of minutes from when I lose or regain power and/or internet.
I just released version 1.3 which replaces the Beacon capability with the Presence Sensor capability. The Beacon capability caused problems with the the Android Mobile appās presence detection and it wasnāt very useful because I couldnāt find any SmartApps that used it.
So the presence Sensor shows present when there is power and away when there isnāt?
I have not tried this DH yet, as I took a hiatus of sorts from making changes to ST to focus on completing some other tasks that needed my attention - and even the small changes in ST can often drag me inā¦
I am looking forward to the promising functionality here. One concern i have is I am currently using the other DH which disables the device showing active when I send custom playtrack commands to it and I am not entirely clear how that works with this DH.
[quote=āJH1, post:11, topic:36586, full:trueā]
So the presence Sensor shows present when there is power and away when there isnāt?[/quote]
ST doesnāt automatically call the poll method so unless you schedule something to call it, it wonāt automatically change the presence. I originally used the Beacon Capability since it had the same attributes as the Presence Sensor Capability, but didnāt make the device show up like a presence sensor. The Android app didnāt like the Beacon Capability and kept giving me random presence related errors which is why I changed it.
Do you think Iād be better off getting rid of the Presence Sensor Capability and adding an attribute called something like āConnectionStatusā that has the states āOnlineā and āOfflineā? I think there is only one other person actually using this DH so I doubt getting rid of that capability would cause any problems.
[/quote]Iām not sure what you mean by āshowing activeā, but this is how the features work:
If youāre using the device as an Alarm or Switch, the on and alarm events will only be raised when the siren, strobe, both, or on commands are called. Those actions also cause the deviceās status to change to āalarmā.
If youāre using the device as a button, the button pushed event will only be raised if the physical doorbell button is pushed or the pushButton command is called. Those actions also cause the deviceās status to change to ābellā.
The play and playTrack commands change the deviceās status to āplayā.
The beep command change the deviceās status to ābeepā.
Regardless of how the track started playing, it will set the state and status of the device to āoffā as soon as it finishes.
Here is what I am doing.
Say someone rings the doorbell with the button. I use rule machine to monitor that doorbell, and when itās status shows āonā - a seperate doorbell will also ring and I will be sent a text message. If doing playtrack or other actions to that doobell results in the cascade or a text to myself, that would be a problem.
I am not sure I follow about the presence or beacon. Are you trying to use the device to determine if your power has been cut / restored? I like the idea but not sure i follow exactly how you are doing that.
Sorry I have tinkered with this yet. I hope to soon.
[quote=āJH1, post:13, topic:36586ā]
I use rule machine to monitor that doorbell, and when itās status shows āonā - a seperate doorbell will also ring and I will be sent a text message. [/quote]It sounds like youāre currently checking for the āonā state of the Switch capability in Rule Machine. If you use this DH you will need to use the ābutton one pushedā state of the Button capability instead.
With this DH, it will only show āonā when one of the following commands is called: siren, strobe, both, or on. I thought it made more sense to have the Button capability associated with pushing the doorbell button and the Alarm capability associated with turning the device on.
I looked at my code and I could easily change that functionality so Iām going to add a preference that allows you to choose which commands (doorbell, beep, play/playTrack, siren/strobe/both) trigger the āonā state and Iāll default it to siren/strobe/both. Once Iāve made that change, you can change the settings to ādoorbellā and you wonāt have to change any of your existing rules.
I just noticed that the āButtonā capability is available in Rule Machine as a trigger, but not a condition and thatās the main reason Iām adding this functionality in the next version.
[quote=āJH1, post:13, topic:36586ā]I am not sure I follow about the presence or beacon. Are you trying to
use the device to determine if your power has been cut / restored? I like the idea but not sure i follow exactly how you are doing that.[/quote] Yes, thatās what Iām doing and it works fine, but I donāt think this is what the Presence Sensor is intended for and it causes the device to get listed in the āfamilyā screen of the mobile app so Iām considering removing that capability in the next version.
Can you make it an optional config?
[quote=āJH1, post:15, topic:36586ā]
[/quote]If the device has the Presence Sensor capability, smart things automatically treats it as a presence Sensor so Iām pretty sure thereās no way to make that optional.
If I remove that capability, Iāll add an attribute that can be used to determine if itās online. Rule Machine allows you to add custom commands, but Iām not sure if it allows you to use custom attributes in rules. If it doesnāt, than that feature wonāt be very helpful.
What do you think I should do?
Edit: I just went through the Rule Machine Feature Request page and custom attributes are not going to be implemented so the custom attribute wonāt be useful.
[quote=āKeithJW, post:418, topic:28889ā]
I tried setting up the Rule you suggested with no results
[/quote]Does the rule get triggered if you press the physical doorbell button?
I configured button one, but it showed up as beep, playing track 5, which beep is set to, but the speaker played the doorbell sound, track 3.
ā¦Although maybe a door was opened, because I tried it again and nothing showed up.
Oh fair enough. Iāll have to play around with it.
