Yes, I was try it. I went back to the original drive, it’s more stable. I’m waiting to see if it will migrate automatically. also because otherwise I would find two devices, because the one in the LAN continues to appear even if I delete it. also because otherwise I would find two devices, because the one in the LAN continues to appear even if I delete it
Possibly this Edge driver will work on your lock?
That along with the suggested SLGA work together.
Hope that helps.
Has anyone seen any more automatic migration of devices recently?
I’ve had no new migrations since before Christmas. March keeps marching on…
I have a number of Zooz ZEN27 and ZEN26 devices. About 2/3 of them have been auto-migrated, still have 8 to be done. Also have 4 GE/Jasco ZigBee devices not migrated although a couple have been.
Nothing for ~3-4 weeks for me. Out of 31 devices remaining:
ZEN25 (counts for 4 devices)
ZEN20 x2 (5 each)
Various Zooz ZW switch x4
Kwikset Zigbee lock
GE/Jasco Z-wave dimmers x2
Honeywell/Jasco Z-wave fan control
ST Presence Sensor
Z-wave outlet x2 - Monoprice 15654
Z-wave outlet x2 - Dome DMOF1
Z-wave dimming outlet - Centralite
Sylvania button
Xiaomi leak sensor x2
I could be mistaken, but I believe that centralite only made Zigbee devices. No z-wave. ![]()
My guess is they probably are not doing any conversion while there are hub FW updates going on. But yes, still slow going. I am sure they convert a block then assess, rinse, repeat.
I think they slowed down because of the fiasco when they automagicaly jacked up everyone’s locks.
You’re right, I was mixing these up with another. Definitely ZigBee.
Some recent OTA firmware discussion here
Has the date for completion of the migration changed yet?
Last I heard, it was the end of Q1. Q1 ends in 3 weeks.
" Q1 of 2023
· Complete 1st Party DTH migrations
· Shutdown Graph IDE"
Like many, I still have some devices to go. Mostly, locks and vents and I need those to be stable so I do not want to move then on my own if locks are still a mess. I manually moved most of my devices to edge drivers, months ago.
I got six blinds updated. The only change since December. 75% of my devices still to be migrated with 3 weeks to go.
My locks migrated to edge drivers yesterday.
One a schlage
One a yale
Lutron caseta the last holdout
Lutron Caseta is a cloud to cloud integration at the time of this writing. It won’t need to migrate and it won’t use an Edge Driver. It’s a “linked service.”
Thank you JD helpful as always.
Why do only one or two automations have the local check ?
I’m down to 16 Z-wave devices—all switches, dimmers, and fan controls. That’s an easily manageable number if I was inclined to migrate manually, but now I’m just curious to see how it all plays out. ![]()
So got a smart plug that was migrated yesterday and stopped working properly
Smart plug v6 by Aeon
I can’t control the on or off from the app
Tried a couple of installed drivers on my hub (aeontec, smartthings, mc)
Noting seem to work
I had another similar plug that was still on the DTH (that was still working), I excluded it and pair it again to the hub. Doesn’t work anymore
Seem a pretty basic migration, is there a way to see if there is an error somewhere ?
Use the Aeotec Edge driver and run a zwave repair before and after.
You may also have to exclude them and pair them again.
Does anyone happen to know if SmartThings will/still support updating (non-Hub) device firmware? My ST v2 HUB hasn’t always been particularly consistent/reliable in that regard depending upon the device, but I was hoping to trigger firmware updates for same-model devices to hopefully get them all running the same firmware. (Before you say ‘you don’t need to’, yes, I know… but my question stands.) Thank you =)
That’s what I did ![]()
Will try the z-wave repair to see
