I have 17 unconverted “devices” out of 64 total. Five of my 17 are Sonos speaker groups.
Nothing has been migrated since about mid-December. There are 5 weeks to go before the most recently published target date.
I have hope!
I have hope!
Couple device here that still haven’t migrated: I have 6 Zwave locks (all are Kwikset 916 and 912) and a Fortrezz water valve that still have migrated along with a zooz controller that I use for z-wave firmware upgrades. Beyond that a Zwave outlet is also still a straggler. The other one is the Weather device integration- that one isn’t as critical since they neutered compatibility with cloud based thermostats and the old thermostat control app in 2021.
That said, 100+ others have migrated. Only one’s I had issues with are the GE Fan controller that I had to move to philh30’s driver to get Alexa integration working with them again philh30s Jasco drive to get my GE motion sensor light switch working again.
I’ve still got some lingering problems with IKEA dial style battery operated dimmers not working quite right (they will dim and brighten but it is intermittent how they respond and I can’t get them to actually turn the light off anymore).
Got excited when the Zwave blinds came over a week or two ago. But nothing since then. Still have almost 100 devices to move over. 29 out of 126 or 23% complete. At that rate, about 3 devices/ day would need to transfer to meet their current deadline. Although I’m guessing the low hanging fruit got done first.
This is probably the issue you are having with your dimmers:
I looked at that and mine is a different scenario.
I use the ikea rotary dial dimmers to control a bulb using the smart lighting mirror function… basically providing my with a physical butting approach to dealing with a smart bulb.
So I’m my case those ikea dimmer and the mirror function are just not working well.
Another week over and again, no additional conversions to Edge by ST for me.
I had a whole bunch of lights converted this week. The main device I haven’t had migrated left is my Z-Wave Lock. Maybe that’s a good thing as I’ve heard some horror stories.
28 days until the end of Groovy
28 days until full migration
Pick a device, and change its drivers
28 days until the end of Groovy ![]()
All 6 of my Schlage locks got transitioned a couple days ago, kept routines and codes. I have Eaton switch that has not been moved yet.
Michael
The automated transition has been admittedly slower than I anticipated. There are periods of apparent inactivity, and then - boom -, a swath of devices transition to Edge. Probably seems to occur in binges to me b/c I’ve standardize on specific models for lightbulbs, sensors, locks, etc. Maybe some of you are in that same boat?
I have about 42 devices in all. As of this morning, only 8 devices remain on DTH. Those 8 devices actually represent only 3 unique device types. After months of ongoing anxiety thinking I may need to ditch ST, it’s looking like I’ll ultimately be able to keep ST and hopefully retain full prior functionality.
Here are some positive experiences that I wanted to share:
My only real remaining worry are the Z-Wave Plus Door/Window Sensors throughout my home. They’re officially Monoprice-brand model 24259, which I’ve realized is just a rebranded Hank HKZW-DWS01. There are at least 2-3 unanswered posts from other owners of these sensors alluding similar concerns I have. Not sure if I’m going to be left with a batch of “THING” devices, but these are pretty critical to a number of automation/alerts and my security setup. So ![]()
The other 4 devices are some super cheap G10 RGBW’s. Two “ZLL RGBW Bulb” zigbees (Maker: Gledopto, Model: GL-S-007Z, Raw: 0B C05E 0210 02 07 0000 0003 0004 0005 0006 0008 0300 00) and two “ZigBee RGBW Bulb” (Maker: _TZ3210_rcggc0ys, Model: TS0505B, Raw: 01 0104 010D 01 09 0003 0004 0005 0006 1000 0008 0300 EF00 0000 02 0019 000A). I think @Mariano_Colmenarejo 's beta driver had at least one of these covered… so I’m hoping that ST ultimately bakes those device identifiers into their official driver.
Anywho… just wanted to share my experience, in case it helps balance some of the anxiety any of you might be feeling right now. =) Cheers
HELP!! While not a complete stooge when it comes to this stuff…i am not a developer etc……was using Rboys app….for my Schlage lock and user control…which i have lost when groovy was no longer groovy……anyone have a solution to get back my lock management…very disconcerting……
How can you tell which devices have moved to Edge and off Groovy?
You can use Smart Lock Guest Access to manage your locks/codes if it is available in your region. Just go to the Life section to add it.
A temporary solution: https://community.smartthings.com/t/seam-temporary-solution-for-managing-lock-guest-codes-jan-2023/257569 that you can check out.
Rboy had several different smartapps for locks with different features. For example, there was one specifically for people managing multiple Airbnb rentals. Which one were you using?
If a device is using an edge driver, you can go into the SmartThings app, find the device, click on the small gear icon to see its details. If it says “driver“ there, it is using an edge driver.
See the community FAQ on edge for more information:
FAQ: I have no idea what Edge is. Is that a new developer tool? (2022)
Yep, You can’t trust what it says in the IDE as far as “placeholder.” My Thermostats transitioned quite a while ago. They originally said “place holder” in IDE but then went back to saying “Z-wave Thermostat” in the IDE. They are on an Edge driver, verified through the ST app… I only mention this in case some are using the IDE to check if devices have transitioned.
It looks like the Edge Zigbee Motion Sensor driver no longer supports firmware upgrades. I put an Iris v2 motion sensor with older firmware on SmartThings and after a few days, it is still not upgraded. Darn.
It never worked for me, assuming Samsung had a compatible firmware file for my Third Reality sensors.
Ended up upgrading them via Hubitat.
Sorry, I still don’t understand if Hue and Bose (both connected in Lan) will be migrated to Edge.
There is a Bose Edge driver is the ST beta channel.
