I tried installing your driver for xiaomi blinds before and I couldn’t use it, but today it worked! I guess you added the E1 fingerprint, so really BIG THANKS!!! It does not refresh and the close function and setting the level to 0% don’t work but the rest does, so I can just use 1% and I don’t really care that much about refreshing as long as it carries out the commands, so it is really a big relieve.
I don’t have a zigbee Thermostat driver, I have added some device fingerprints, which use standard zigbe 3.0 clusters, to the stock Zigbee Thermostat driver, which also uses the default libraries for zigbee 3.0
As far as I know, Aqara E1 does not use standard clusters for some functions.
I’m sorry, but I’m not going to do the work for aqara.
I try to adapt how I can the devices that worked in groovy so as not to leave users without their devices in the edge transition and another is to want to buy devices, which are known to have no edge driver or do not use standard clusters and are more difficult and laborious to adapt.
There are standard zigbee devices on the market, see stock driver fingerprints, or ask Aqara to make a driver
They did work in groovy, still do but I’m guessing it will soon be gone!
But yeah, it’s very annoying that their devices don’t just work with SmartThings. If I can’t find anything to get them to work, I will just bin them😂
Yeah they are. I bought 2 a while back as the eurotronic ones were a bit messy prior to moving it to their own edge driver. Now they work flawlessly to be fair. Just didn’t fancy throwing £100 in the bin. I do like their products but really can’t be bothered having multiple zigbee hubs! Thank you anyway
Just the standard zigbee thermostat. Its not fantastic but I can get the temperature and set the heating temperature. This in turn, opens or closes the valve. Thank you for looking into this.
Added ti this driver version
This profile is the most similar to the DTH zigbee thermostat.
I see that the battery does not work, it shows 0% and I have added the xiaomi battery utilities in case it was sending the battery information through the cluster 0x0000 instead of 0x0001
Name Zigbee Thermostat Mc
Version 2023-03-10T15:18:41.656772008
- id: "Aqara-E1/lumi.airrtc.agl001"
deviceLabel: Aqara-E1 Thermostat
manufacturer: LUMI
model: lumi.airrtc.agl001
deviceProfileName: base-thermostat-battery-fanless
Hey guys, just wanted to clarify that the purpose of this driver is to foster a community of developers interested in Aqara devices. I might not be able to help with customer support, especially for drives that I have not personally used.
Let’s work together to create something great
