Integration of Z-Wave Danfoss Thermostat
Hi Team
Could some one please enlighten me regarding z-wave and the ST hub.
My quest was to find out, if it is possible to control/work with a Danfoss Thermostat (LC-13 - Z-Wave - Radiator Thermostats & Control Valves – Vesternet ) from the ST hub.
The Thermostat is using the z-ware protocol.
I can see from the ‘supported’ list of devices that it looks like it is not supported.
But It says that the ST hub is using the z-Wave protocol.
So, next step was to get in contact with Danfoss, and I have been in dialogue with the person that is in charge of developing integration between the Thermostat and the z-ware protocol. His comments where, that if the HUB/portal is implemented according to the specifications, then the ‘hub’ would automatically when it is paired to a device, get all the functions and values. And if the HUB knows what a ‘Thermostat’ is - that it is not a AC, then it should work. :wink:
But he doubts that it will work.
Currently, the Danfoss Thermostat works fine with these z-Waves ‘hubs’: Devolo, Fabaro, Zipato, Razberry (Raspberry pi).
So how much work will it take to get it working ?
Guess Danfoss is big in Thermostats here in Europe.
/Joern
Are you pairing this with a US version of the hub? If so, it won’t work since it is using European frequencies as per their website.
The plan is to use the UK version of the HUB and the European version of the Thermostat… all on the 868 frequency…
/Joern
Great! Shoot an email to support and ask about it. Also, someone on the boards here might be able to code a custom device type if necessary. My guesses that the hub will see it, but it might see it incorrectly. Did you buy it yet? If so, you could always return it.
I’m quite interested in this since a friend of ours just purchased her first house (here in the States) and it is radiator. I would love to help her with a “Nest-like” solution to control all the radiators.
hi there, any news on this?
Any news? Would the Danfoss Radiator Thermostat LC-13 work with ST?
Same issue here. I have Danfoss Living Connect Thermostat in my home. They work fine with Openhab on Rasberry Pi but they do not pair with Smartthings Hub.
Any news?
@Cedric - I’m considering getting this product. Is the issue that it won’t be included at all with ST or just that after inclusion it is not possible to control?
@AdamV - it is included in my Z-Wave network but:
  • I don’t see any data about it, like the temperature
  • I cannot configure it, like set the temperature
Ok I’ve ordered one.
From my understanding - this device doesn’t send data back about temperature anyway, it only receives and sets the temperature. Sounds like we just gotta figure out what z-wave command it will accept for a temperature set and then we can still automate it using smartthings ( I hope ). I’ll let you know how I get on.
@AdamV I don’t think there will be a major issue to do so as it worked with Openhab on my raspberry pi. Just need to figure how to to develop it for Smartthings.
Let me know how it goes :slight_smile:
Ok will do.
Also - whilst I’m at it… can you let me know why you use Smartthings if you have OpenHAB working? from my understanding, OpenHAB is a much better and flexible solution for HA - the only reason I don’t use it myself is that I don’t have the technical skills required… otherwise I would definitely.
For sure, openhab is more flexible… But honestly I have not been very convinced by it.
Right this is by no means finished - and heavily based on the stock z wave thermostat. I won’t get around to finishing this properly for a few months because my radiators probably wont be installed until end of Jan. However I’ve turned the thing on and got it communicating - it worked badly with the stock z-wave thermostat device handler, all I have done is tidy up the controls so that its easier to use and add the necessary Z-wave code to handle the battery information. Also it does appear to send back the temperature data, but only on a poll - which is fine.
There is still a tonne more work to make it absolutely perfect. If someone needs to have that done before end of Jan feel free to improve on this:
 *  Copyright 2015 AdamV
 *  Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
 *  in compliance with the License. You may obtain a copy of the License at:
 *      http://www.apache.org/licenses/LICENSE-2.0
 *  Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
 *  on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
 *  for the specific language governing permissions and limitations under the License.
metadata {
	definition (name: "Living Connect Radiator Thermostat", namespace: "Danfoss", author: "AdamV") {
		capability "Actuator"
		capability "Temperature Measurement"
		capability "Relative Humidity Measurement"
		capability "Thermostat"
		capability "Configuration"
		capability "Polling"
		capability "Sensor"
capability "Battery"
		attribute "thermostatFanState", "string"
		command "switchMode"
		command "switchFanMode"
command "quickSetCool"
command "quickSetHeat"
	fingerprint deviceId: "0x0804"
	fingerprint inClusters: "0x80,0x46,0x81,0x72, 0x8F, 0x75, 0x43, 0x86, 0x84, 0xEF, 0x46, 0x81, 0x8F"
	// simulator metadata
	simulator {
		status "off"			: "command: 4003, payload: 00"
		status "heat"			: "command: 4003, payload: 01"
		status "cool"			: "command: 4003, payload: 02"
		status "auto"			: "command: 4003, payload: 03"
		status "emergencyHeat"	: "command: 4003, payload: 04"
		status "fanAuto"		: "command: 4403, payload: 00"
		status "fanOn"			: "command: 4403, payload: 01"
		status "fanCirculate"	: "command: 4403, payload: 06"
		status "heat 60"        : "command: 4303, payload: 01 09 3C"
		status "heat 68"        : "command: 4303, payload: 01 09 44"
		status "heat 72"        : "command: 4303, payload: 01 09 48"
		status "cool 72"        : "command: 4303, payload: 02 09 48"
		status "cool 76"        : "command: 4303, payload: 02 09 4C"
		status "cool 80"        : "command: 4303, payload: 02 09 50"
		status "temp 58"        : "command: 3105, payload: 01 2A 02 44"
		status "temp 62"        : "command: 3105, payload: 01 2A 02 6C"
		status "temp 70"        : "command: 3105, payload: 01 2A 02 BC"
		status "temp 74"        : "command: 3105, payload: 01 2A 02 E4"
		status "temp 78"        : "command: 3105, payload: 01 2A 03 0C"
		status "temp 82"        : "command: 3105, payload: 01 2A 03 34"
		status "idle"			: "command: 4203, payload: 00"
		status "heating"		: "command: 4203, payload: 01"
		status "cooling"		: "command: 4203, payload: 02"
		status "fan only"		: "command: 4203, payload: 03"
		status "pending heat"	: "command: 4203, payload: 04"
		status "pending cool"	: "command: 4203, payload: 05"
		status "vent economizer": "command: 4203, payload: 06"
		// reply messages
		reply "2502": "command: 2503, payload: FF"
	tiles (scale: 2){
	multiAttributeTile(name:"heatingSetpoint", type: "thermostat", width: 6, height: 4, canChangeIcon: true){
			tileAttribute ("device.heatingSetpoint", key: "PRIMARY_CONTROL") {
   		         attributeState("heat", unit:"C", label:'${currentValue}°',
        backgroundColors:[
            [value: 0, color: "#153591"],
            [value: 7, color: "#1e9cbb"],
            [value: 15, color: "#90d2a7"],
            [value: 23, color: "#44b621"],
            [value: 29, color: "#f1d801"],
            [value: 35, color: "#d04e00"],
            [value: 36, color: "#bc2323"]
			tileAttribute("device.heatingSetpoint", key: "VALUE_CONTROL") {
				attributeState "heat", action:"quickSetHeat"
		valueTile("temperature", "device.temperature", width: 2, height: 2) {
			state("temperature", label:'${currentValue}°',
				backgroundColors:[
					[value: 31, color: "#153591"],
					[value: 44, color: "#1e9cbb"],
					[value: 59, color: "#90d2a7"],
					[value: 74, color: "#44b621"],
					[value: 84, color: "#f1d801"],
					[value: 95, color: "#d04e00"],
					[value: 96, color: "#bc2323"]
/*		standardTile("fanMode", "device.thermostatFanMode", inactiveLabel: false, decoration: "flat") {
			state "fanAuto", label:'${name}', action:"switchFanMode"
			state "fanOn", label:'${name}', action:"switchFanMode"
			state "fanCirculate", label:'${name}', action:"switchFanMode"
valueTile("battery", "device.battery", inactiveLabel: false, decoration: "flat", width: 2, height: 2) {
 	tileAttribute ("device.battery", key: "PRIMARY_CONTROL"){
                state "battery", label:'${currentValue}% battery', unit:""
		controlTile("heatSliderControl", "device.heatingSetpoint", "slider", height: 2, width: 6, inactiveLabel: false) {
			state "setHeatingSetpoint", action:"quickSetHeat", backgroundColor:"#d04e00"
//		valueTile("heatingSetpoint", "device.heatingSetpoint", inactiveLabel: false, decoration: "flat") {
//			state "heat", label:'${currentValue}° heat', backgroundColor:"#ffffff"
//		controlTile("coolSliderControl", "device.coolingSetpoint", "slider", height: 1, width: 2, inactiveLabel: false) {
//			state "setCoolingSetpoint", action:"quickSetCool", backgroundColor: "#1e9cbb"
//		valueTile("coolingSetpoint", "device.coolingSetpoint", inactiveLabel: false, decoration: "flat") {
//			state "cool", label:'${currentValue}° cool', backgroundColor:"#ffffff"
		standardTile("refresh", "device.thermostatMode", inactiveLabel: false, decoration: "flat") {
			state "default", action:"polling.poll", icon:"st.secondary.refresh"
		standardTile("configure", "device.configure", inactiveLabel: false, decoration: "flat") {
			state "configure", label:'', action:"configuration.configure", icon:"st.secondary.configure"
		main "heatingSetpoint"
		details(["heatingSetpoint", "heatSliderControl", "battery", , "refresh", "configure", "temperature", "mode", "fanMode", "coolSliderControl", "coolingSetpoint"])
def parse(String description)
	def map = createEvent(zwaveEvent(zwave.parse(description, [0x42:1, 0x43:2, 0x31: 3])))
	if (!map) {
		return null
	def result = [map]
	if (map.isStateChange && map.name in ["heatingSetpoint","coolingSetpoint","thermostatMode"]) {
		def map2 = [
			unit: getTemperatureScale()
		if (map.name == "thermostatMode") {
			state.lastTriedMode = map.value
			if (map.value == "cool") {
				map2.value = device.latestValue("coolingSetpoint")
				log.info "THERMOSTAT, latest cooling setpoint = ${map2.value}"
			else {
				map2.value = device.latestValue("heatingSetpoint")
				log.info "THERMOSTAT, latest heating setpoint = ${map2.value}"
		else {
			def mode = device.latestValue("thermostatMode")
			log.info "THERMOSTAT, latest mode = ${mode}"
			if ((map.name == "heatingSetpoint" && mode == "heat") || (map.name == "coolingSetpoint" && mode == "cool")) {
				map2.value = map.value
				map2.unit = map.unit
		if (map2.value != null) {
			log.debug "THERMOSTAT, adding setpoint event: $map"
			result << createEvent(map2)
	} else if (map.name == "thermostatFanMode" && map.isStateChange) {
		state.lastTriedFanMode = map.value
	log.debug "Parse returned $result"
	result
// Event Generation
def zwaveEvent(physicalgraph.zwave.commands.thermostatsetpointv2.ThermostatSetpointReport cmd)
	def cmdScale = cmd.scale == 1 ? "F" : "C"
	def map = [:]
	map.value = convertTemperatureIfNeeded(cmd.scaledValue, cmdScale, cmd.precision)
	map.unit = getTemperatureScale()
	map.displayed = false
	switch (cmd.setpointType) {
		case 1:
			map.name = "heatingSetpoint"
			break;
		case 2:
			map.name = "coolingSetpoint"
			break;
		default:
			return [:]
	// So we can respond with same format
	state.size = cmd.size
	state.scale = cmd.scale
	state.precision = cmd.precision
	map
def zwaveEvent(physicalgraph.zwave.commands.sensormultilevelv3.SensorMultilevelReport cmd)
	def map = [:]
	if (cmd.sensorType == 1) {
		map.value = convertTemperatureIfNeeded(cmd.scaledSensorValue, cmd.scale == 1 ? "F" : "C", cmd.precision)
		map.name = "temperature"
	} else if (cmd.sensorType == 5) {
		map.value = cmd.scaledSensorValue
		map.unit = "%"
		map.name = "humidity"
	map
def zwaveEvent(physicalgraph.zwave.commands.thermostatoperatingstatev1.ThermostatOperatingStateReport cmd)
	def map = [:]
	switch (cmd.operatingState) {
		case physicalgraph.zwave.commands.thermostatoperatingstatev1.ThermostatOperatingStateReport.OPERATING_STATE_IDLE:
			map.value = "idle"
			break
		case physicalgraph.zwave.commands.thermostatoperatingstatev1.ThermostatOperatingStateReport.OPERATING_STATE_HEATING:
			map.value = "heating"
			break
		case physicalgraph.zwave.commands.thermostatoperatingstatev1.ThermostatOperatingStateReport.OPERATING_STATE_COOLING:
			map.value = "cooling"
			break
		case physicalgraph.zwave.commands.thermostatoperatingstatev1.ThermostatOperatingStateReport.OPERATING_STATE_FAN_ONLY:
			map.value = "fan only"
			break
		case physicalgraph.zwave.commands.thermostatoperatingstatev1.ThermostatOperatingStateReport.OPERATING_STATE_PENDING_HEAT:
			map.value = "pending heat"
			break
		case physicalgraph.zwave.commands.thermostatoperatingstatev1.ThermostatOperatingStateReport.OPERATING_STATE_PENDING_COOL:
			map.value = "pending cool"
			break
		case physicalgraph.zwave.commands.thermostatoperatingstatev1.ThermostatOperatingStateReport.OPERATING_STATE_VENT_ECONOMIZER:
			map.value = "vent economizer"
			break
	map.name = "thermostatOperatingState"
	map
def zwaveEvent(physicalgraph.zwave.commands.thermostatfanstatev1.ThermostatFanStateReport cmd) {
	def map = [name: "thermostatFanState", unit: ""]
	switch (cmd.fanOperatingState) {
		case 0:
			map.value = "idle"
			break
		case 1:
			map.value = "running"
			break
		case 2:
			map.value = "running high"
			break
	map
def zwaveEvent(physicalgraph.zwave.commands.batteryv1.BatteryReport cmd) {
def map = [ name: "battery", unit: "%" ]
if (cmd.batteryLevel == 0xFF) {  // Special value for low battery alert
        map.value = 1
        map.descriptionText = "${device.displayName} has a low battery"
        map.isStateChange = true
} else {
        map.value = cmd.batteryLevel
        log.debug ("Battery: $cmd.batteryLevel")
// Store time of last battery update so we don't ask every wakeup, see WakeUpNotification handler
state.lastbatt = new Date().time
createEvent(map)
def zwaveEvent(physicalgraph.zwave.commands.thermostatmodev2.ThermostatModeReport cmd) {
	def map = [:]
	switch (cmd.mode) {
		case physicalgraph.zwave.commands.thermostatmodev2.ThermostatModeReport.MODE_OFF:
			map.value = "off"
			break
		case physicalgraph.zwave.commands.thermostatmodev2.ThermostatModeReport.MODE_HEAT:
			map.value = "heat"
			break
		case physicalgraph.zwave.commands.thermostatmodev2.ThermostatModeReport.MODE_AUXILIARY_HEAT:
			map.value = "emergency heat"
			break
		case physicalgraph.zwave.commands.thermostatmodev2.ThermostatModeReport.MODE_COOL:
			map.value = "cool"
			break
		case physicalgraph.zwave.commands.thermostatmodev2.ThermostatModeReport.MODE_AUTO:
			map.value = "auto"
			break
	map.name = "thermostatMode"
	map
def zwaveEvent(physicalgraph.zwave.commands.thermostatfanmodev3.ThermostatFanModeReport cmd) {
	def map = [:]
	switch (cmd.fanMode) {
		case physicalgraph.zwave.commands.thermostatfanmodev3.ThermostatFanModeReport.FAN_MODE_AUTO_LOW:
			map.value = "fanAuto"
			break
		case physicalgraph.zwave.commands.thermostatfanmodev3.ThermostatFanModeReport.FAN_MODE_LOW:
			map.value = "fanOn"
			break
		case physicalgraph.zwave.commands.thermostatfanmodev3.ThermostatFanModeReport.FAN_MODE_CIRCULATION:
			map.value = "fanCirculate"
			break
	map.name = "thermostatFanMode"
	map
def zwaveEvent(physicalgraph.zwave.commands.thermostatmodev2.ThermostatModeSupportedReport cmd) {
	def supportedModes = ""
	if(cmd.off) { supportedModes += "off " }
	if(cmd.heat) { supportedModes += "heat " }
	if(cmd.auxiliaryemergencyHeat) { supportedModes += "emergency heat " }
	if(cmd.cool) { supportedModes += "cool " }
	if(cmd.auto) { supportedModes += "auto " }
	state.supportedModes = supportedModes
def zwaveEvent(physicalgraph.zwave.commands.thermostatfanmodev3.ThermostatFanModeSupportedReport cmd) {
	def supportedFanModes = ""
	if(cmd.auto) { supportedFanModes += "fanAuto " }
	if(cmd.low) { supportedFanModes += "fanOn " }
	if(cmd.circulation) { supportedFanModes += "fanCirculate " }
	state.supportedFanModes = supportedFanModes
def zwaveEvent(physicalgraph.zwave.commands.basicv1.BasicReport cmd) {
	log.debug "Zwave event received: $cmd"
	log.warn "Unexpected zwave command $cmd"
// Command Implementations
def poll() {
	delayBetween([
		zwave.sensorMultilevelV3.sensorMultilevelGet().format(), // current temperature
		zwave.thermostatSetpointV1.thermostatSetpointGet(setpointType: 1).format(),
		zwave.thermostatSetpointV1.thermostatSetpointGet(setpointType: 2).format(),
		zwave.thermostatModeV2.thermostatModeGet().format(),
		zwave.thermostatFanModeV3.thermostatFanModeGet().format(),
		zwave.thermostatOperatingStateV1.thermostatOperatingStateGet().format()
	], 2300)
def quickSetHeat(degrees) {
	setHeatingSetpoint(degrees, 1000)
log.debug(“Degrees at quicksetheat: $degrees”)
def setHeatingSetpoint(degrees, delay = 30000) {
	setHeatingSetpoint(degrees.toDouble(), delay)
log.debug("Degrees at setheatpoint: $degrees")
def setHeatingSetpoint(Double degrees, Integer delay = 30000) {
	log.trace "setHeatingSetpoint($degrees, $delay)"
	def deviceScale = state.scale ?: 1
	def deviceScaleString = deviceScale == 2 ? "C" : "F"
def locationScale = getTemperatureScale()
def p = (state.precision == null) ? 1 : state.precision
def convertedDegrees
if (locationScale == “C” && deviceScaleString == “F”) {
convertedDegrees = celsiusToFahrenheit(degrees)
} else if (locationScale == “F” && deviceScaleString == “C”) {
convertedDegrees = fahrenheitToCelsius(degrees)
} else {
convertedDegrees = degrees
	delayBetween([
		zwave.thermostatSetpointV1.thermostatSetpointSet(setpointType: 1, scale: deviceScale, precision: p, scaledValue: convertedDegrees).format(),
	], delay)
def quickSetCool(degrees) {
	setCoolingSetpoint(degrees, 1000)
def setCoolingSetpoint(degrees, delay = 30000) {
	setCoolingSetpoint(degrees.toDouble(), delay)
def setCoolingSetpoint(Double degrees, Integer delay = 30000) {
log.trace "setCoolingSetpoint($degrees, $delay)"
def deviceScaleString = deviceScale == 2 ? “C” : "F"
} else {
	delayBetween([
		zwave.thermostatSetpointV1.thermostatSetpointSet(setpointType: 2, scale: deviceScale, precision: p,  scaledValue: convertedDegrees).format(),
	], delay)
def configure() {
	delayBetween([
		zwave.thermostatModeV2.thermostatModeSupportedGet().format(),
		zwave.thermostatFanModeV3.thermostatFanModeSupportedGet().format(),
		zwave.associationV1.associationSet(groupingIdentifier:1, nodeId:[zwaveHubNodeId]).format()
	], 2300)
def modes() {
	["off", "heat", "cool", "auto", "emergency heat"]
def switchMode() {
	def currentMode = device.currentState("thermostatMode")?.value
	def lastTriedMode = state.lastTriedMode ?: currentMode ?: "off"
	def supportedModes = getDataByName("supportedModes")
	def modeOrder = modes()
	def next = { modeOrder[modeOrder.indexOf(it) + 1] ?: modeOrder[0] }
	def nextMode = next(lastTriedMode)
	if (supportedModes?.contains(currentMode)) {
		while (!supportedModes.contains(nextMode) && nextMode != "off") {
			nextMode = next(nextMode)
	state.lastTriedMode = nextMode
	delayBetween([
		zwave.thermostatModeV2.thermostatModeSet(mode: modeMap[nextMode]).format(),
	], 1000)
def switchToMode(nextMode) {
	if(supportedModes && !supportedModes.contains(nextMode)) log.warn "thermostat mode '$nextMode' is not supported"
	if (nextMode in modes()) {
		"$nextMode"()
	} else {
		log.debug("no mode method '$nextMode'")
def switchFanMode() {
	def currentMode = device.currentState("thermostatFanMode")?.value
	def lastTriedMode = state.lastTriedFanMode ?: currentMode ?: "off"
	def supportedModes = getDataByName("supportedFanModes") ?: "fanAuto fanOn"
	def modeOrder = ["fanAuto", "fanCirculate", "fanOn"]
	while (!supportedModes?.contains(nextMode) && nextMode != "fanAuto") {
	switchToFanMode(nextMode)
def switchToFanMode(nextMode) {
	def supportedFanModes = getDataByName("supportedFanModes")
	if(supportedFanModes && !supportedFanModes.contains(nextMode)) log.warn "thermostat mode '$nextMode' is not supported"
	def returnCommand
	if (nextMode == "fanAuto") {
		returnCommand = fanAuto()
	} else if (nextMode == "fanOn") {
		returnCommand = fanOn()
	} else if (nextMode == "fanCirculate") {
		returnCommand = fanCirculate()
	} else {
		log.debug("no fan mode '$nextMode'")
	if(returnCommand) state.lastTriedFanMode = nextMode
	returnCommand
def getDataByName(String name) {
	state[name] ?: device.getDataValue(name)
def getModeMap() { [
	"off": 0,
	"heat": 1,
	"cool": 2,
	"auto": 3,
	"emergency heat": 4
def setThermostatMode(String value) {
	delayBetween([
		zwave.thermostatModeV2.thermostatModeSet(mode: modeMap[value]).format(),
	], standardDelay)
def getFanModeMap() { [
	"auto": 0,
	"on": 1,
	"circulate": 6
def setThermostatFanMode(String value) {
	delayBetween([
		zwave.thermostatFanModeV3.thermostatFanModeSet(fanMode: fanModeMap[value]).format(),
	], standardDelay)
def off() {
	delayBetween([
		zwave.thermostatModeV2.thermostatModeSet(mode: 0).format(),
	], standardDelay)
def heat() {
	delayBetween([
		zwave.thermostatModeV2.thermostatModeSet(mode: 1).format(),
	], standardDelay)
def emergencyHeat() {
	delayBetween([
		zwave.thermostatModeV2.thermostatModeSet(mode: 4).format(),
	], standardDelay)
def cool() {
	delayBetween([
		zwave.thermostatModeV2.thermostatModeSet(mode: 2).format(),
	], standardDelay)
def auto() {
	delayBetween([
		zwave.thermostatModeV2.thermostatModeSet(mode: 3).format(),
	], standardDelay)
def fanOn() {
	delayBetween([
		zwave.thermostatFanModeV3.thermostatFanModeSet(fanMode: 1).format(),
	], standardDelay)
def fanAuto() {
	delayBetween([
		zwave.thermostatFanModeV3.thermostatFanModeSet(fanMode: 0).format(),
	], standardDelay)
def fanCirculate() {
	delayBetween([
		zwave.thermostatFanModeV3.thermostatFanModeSet(fanMode: 6).format(),
	], standardDelay)
private getStandardDelay() {
	1000
I’m not at home but I will test it when I get home on 21-Dec :slight_smile: Thanks for your hard work!!!
Would you be able to save your project on Github?
Any advance on this guys?
Looking at these too.
Good to know someone else is working on these valves, I have been playing with them for a while but hadn’t even got as far as you by the looks of it.
The problem I had was that I was only able to get the valve to change value when awake. (ie press a button then send the command from ST).
If the device is not awake the slider looks like it is working but does nothing to the device, and when you exit and go back into the device the slider is back where it was before you moved it.
my understanding is you have to que the commands and get the device handler to respond to a wakeupnotification event. However my groovy coding is not up to the task.
Hi, also playing with the LC-13 and I see the same.
Have tried various stock thermostat implementations from ST and Github and can get what funkyd101 describes.
My annoying problem is the valve regularly goes into an E5 error (thermostat not receiving expected replies from the control system. Check the z-wave controller is certified …)
The TRV was bought new this week (software 1.01, SDK 4.55).
does anyone have any ideas?
Gary
I just installed @AdamV 's device type and this is the result…
As you can see, no temperature readings appear…
Ideas?
@danielccm Yes, it’s because the multiAttributeTile section is using “thermostat” for type: and you are using an Android device. If you change type: to “generic” it will start working. You’ll only be able to use the slider to control the temperature. Apparently this new feature (type: thermostat) works with iOS, but not Android for now.
