Custom Device Handler Zwave Thermostat
Hello All,
I have this Zwave Device and I want to build a custom zwave handler for it. The generic Zwave thermostat one doesn’t worrk properly.
Could someone push me in the right direction?
At least get On/Off to work?
What model MCO? If the MCO thermo is using the right capabilities, the default ST DH should work. You should also look at Live Logs while using the thermostat to see what errors or other messages it’s sending.
Here’s a link to my code you can experiment with:
https://raw.githubusercontent.com/constjs/jcdevhandlers/master/devicetypes/jscgs350/my-zwave-thermostat.src/my-zwave-thermostat.groovy
I’m not ensuring this will work for you, but at least you have some code to work with besides the default.
Hey,
Thanks for your help.
I’ve gotten the cooling and on off to work properly now. And the temperature as well.
The only thing I have yet to figure out is the FanState. I can see the correct value, running, running medium and running high in a value tile. But I don’t know how to set it.
Any ideas? Three buttons that could set Fan State as low, medium or high would be perfect. i tried ThermostatFanStateSet , but it gives me groovy.lang.MissingMethodException: No signature of method:
Hi @giovanni645,
I didn’t see your post until just now. So I can get notified of your reply, can you click on "Reply " from my message instead of the blue button titled Reply? That will notify me, and you. :wink:
This shouldn’t be too bad to figure out, but I need to know what exactly the thermostat sends to SmartThings. I’d like you to do something me that will help.
Please look at your live logs and bring up the device in the app and tap on refresh. You’ll see your device name show up in live logs, so click on it so all you see are messages from the thermostat.
Now on the physical thermostat, select each fan value. That will show up in live logs and look like this:
See that line with thermostatFanMode in it? I need to know what those values are. You can see from my example that it says “fanCirculate”.
Can you capture that for me? I can help you, but I have to be away for a few days. I’m also going see what spec document MCO might have to help.
Hi @johnconstantelo
Here’s a screenshot.
The thermostat first started at medium speed fan, then moved onto high, and then moved onto low. I did this manually on the thermostat to give you an idea of what all the states look like that I’m trying to control.
The spec document from MCOHome only states the command classes it supports:
Ok, this is good. Can you also tell me what model you have?
I’m assuming your thermostat has 4 fan options. The 3 you mentioned above and Auto?
I’m in an airport to the moment, so my replies will be delayed.
I have the FC8-EU
It has low, medium, high and auto.
No worries, I’m experimenting with the FanMode right now. Let’s see what happens.
standardTile(“fanLow”, “device.thermostatFanMode”, inactiveLabel: false, decoration: “flat”) {
state “Low”, label:’${name}’, action:“fanLow”
    standardTile("fanMedium", "device.thermostatFanMode", inactiveLabel: false, decoration: "flat") {
		state "Medium", label:'${name}', action:"fanMedium"
    standardTile("fanHigh", "device.thermostatFanMode", inactiveLabel: false, decoration: "flat") {
		state "High", label:'${name}', action:"fanHigh"
     valueTile("fanState", "device.thermostatFanState", inactiveLabel: false, decoration: "flat") {
		state 'running', label:'LOW'
		state '', label:'MEDIUM'
		state 'running high', label:'HIGH'
def fanLow() {
delayBetween([
zwave.thermostatFanModeV3.thermostatFanModeSet(fanMode: 1).format(),
zwave.thermostatFanModeV3.thermostatFanModeGet().format()
], standardDelay)
def fanMedium() {
delayBetween([
zwave.thermostatFanModeV3.thermostatFanModeSet(fanMode: 5).format(),
], standardDelay)
def fanHigh() {
delayBetween([
zwave.thermostatFanModeV3.thermostatFanModeSet(fanMode: 3).format(),
], standardDelay)
Made these changes and now it’s working great!
Thank you so much for your support and safe travels!
You’re very welcome, and thanks!
@giovanni645: i am just about to order one of these for my home. Have an FCU at home with only cooling valve and 3 fan speed.
Whats your feedback on the device and compatibility with smartthings hub?
Can you please share the custom DH you used for the thermostat?
Would you recommend the product?
Thanks in advance.
@johnconstantelo
Can you let me know if this works properly? Im just waiting to see if this will work to order and install in my place. If ok can you please share the DTH used?
Thanks.
I’ve been using my DTH for the last few years without a problem. If you have a similar thermostat as the original poster of this thread, then making similar changes would be easy. You could remove the code needed for heating, and then defining your 3 fan modes.
My code could work for you as-is, but I’m sure it would need modified for your model to be fully useful through ST.
The link to my DTH is in post #2
@johnconstantelo
Thanks. Ordered them and waiting for them to get here.
The latest one that is working for me is here:
 *  Copyright 2015 SmartThings
 *  Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
 *  in compliance with the License. You may obtain a copy of the License at:
 *      http://www.apache.org/licenses/LICENSE-2.0
 *  Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
 *  on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
 *  for the specific language governing permissions and limitations under the License.
metadata {
	definition (name: "Z-Wave MCOHome Thermostat", namespace: "smartthings", author: "SmartThings") {
		capability "Actuator"
		capability "Temperature Measurement"
		capability "Relative Humidity Measurement"
		capability "Thermostat"
		capability "Configuration"
		capability "Polling"
		capability "Sensor"
		attribute "thermostatFanState", "string"
		command "switchMode"
		command "switchFanMode"
        command "quickSetCool"
        command "quickSetHeat"
        command "setThermostatFanMode"
        command "cool"
        command "off"
        command "fanLow"
        command "fanMedium"
        command "fanHigh"
		fingerprint deviceId: "0x08"
		fingerprint inClusters: "0x43,0x40,0x44,0x45,0x31"
	// simulator metadata
	simulator {
		status "off"			: "command: 4003, payload: 00"
		status "heat"			: "command: 4003, payload: 01"
		status "cool"			: "command: 4003, payload: 02"
		status "auto"			: "command: 4003, payload: 03"
		status "emergencyHeat"	: "command: 4003, payload: 04"
		status "fanAuto"		: "command: 4403, payload: 00"
		status "fanOn"			: "command: 4403, payload: 01"
		status "fanCirculate"	: "command: 4403, payload: 06"
		status "heat 60"        : "command: 4303, payload: 01 09 3C"
		status "heat 68"        : "command: 4303, payload: 01 09 44"
		status "heat 72"        : "command: 4303, payload: 01 09 48"
		status "cool 72"        : "command: 4303, payload: 02 09 48"
		status "cool 76"        : "command: 4303, payload: 02 09 4C"
		status "cool 80"        : "command: 4303, payload: 02 09 50"
		status "temp 58"        : "command: 3105, payload: 01 2A 02 44"
		status "temp 62"        : "command: 3105, payload: 01 2A 02 6C"
		status "temp 70"        : "command: 3105, payload: 01 2A 02 BC"
		status "temp 74"        : "command: 3105, payload: 01 2A 02 E4"
		status "temp 78"        : "command: 3105, payload: 01 2A 03 0C"
		status "temp 82"        : "command: 3105, payload: 01 2A 03 34"
		status "idle"			: "command: 4203, payload: 00"
		status "heating"		: "command: 4203, payload: 01"
		status "cooling"		: "command: 4203, payload: 02"
		status "fan only"		: "command: 4203, payload: 03"
		status "pending heat"	: "command: 4203, payload: 04"
		status "pending cool"	: "command: 4203, payload: 05"
		status "vent economizer": "command: 4203, payload: 06"
		// reply messages
		reply "2502": "command: 2503, payload: FF"
	tiles {
		valueTile("temperature", "device.temperature", width: 2, height: 2) {
			state("temperature", label:'${currentValue}°',
				backgroundColors:[
					[value: 31, color: "#153591"],
					[value: 44, color: "#1e9cbb"],
					[value: 59, color: "#90d2a7"],
					[value: 74, color: "#44b621"],
					[value: 84, color: "#f1d801"],
					[value: 95, color: "#d04e00"],
					[value: 96, color: "#bc2323"]
		valueTile("mode", "device.thermostatMode", inactiveLabel: false, decoration: "flat") {
        state "cool", label:'Cooling', backgroundColor:"#ffffff"
        state "off", label:'Off'
        /*standardTile("mode", "device.thermostatMode", inactiveLabel: false, decoration: "flat") {
			state "off", label:'${name}', action:"switchMode", nextState:"to_heat"
			state "heat", label:'${name}', action:"switchMode", nextState:"to_cool"
			state "cool", label:'${name}', action:"switchMode", nextState:"..."
			state "auto", label:'${name}', action:"switchMode", nextState:"..."
			state "emergency heat", label:'${name}', action:"switchMode", nextState:"..."
			state "to_heat", label: "heat", action:"switchMode", nextState:"to_cool"
			state "to_cool", label: "cool", action:"switchMode", nextState:"..."
			state "...", label: "...", action:"off", nextState:"off"
		standardTile("fanLow", "device.thermostatFanMode", inactiveLabel: false, decoration: "flat") {
			state "Low", label:'${name}', action:"fanLow"
    standardTile("off", "device.thermostatMode", inactiveLabel: false, decoration: "flat") {
			state "off", label:'${name}', action:"off"
        standardTile("cool", "device.thermostatMode", inactiveLabel: false, decoration: "flat") {
			state "cool", label:'${name}', action:"cool"
		controlTile("heatSliderControl", "device.heatingSetpoint", "slider", height: 1, width: 2, inactiveLabel: false) {
			state "setHeatingSetpoint", action:"quickSetHeat", backgroundColor:"#d04e00"
		valueTile("heatingSetpoint", "device.heatingSetpoint", inactiveLabel: false, decoration: "flat") {
			state "heat", label:'${currentValue}° heat', backgroundColor:"#ffffff"
		controlTile("coolSliderControl", "device.coolingSetpoint", "slider", height: 1, width: 2, inactiveLabel: false) {
			state "setCoolingSetpoint", action:"quickSetCool", backgroundColor: "#1e9cbb"
		valueTile("coolingSetpoint", "device.coolingSetpoint", inactiveLabel: false, decoration: "flat") {
			state "cool", label:'${currentValue}° cool', backgroundColor:"#ffffff"
		standardTile("refresh", "device.thermostatMode", inactiveLabel: false, decoration: "flat") {
			state "default", action:"polling.poll", icon:"st.secondary.refresh"
		standardTile("configure", "device.configure", inactiveLabel: false, decoration: "flat") {
			state "configure", label:'', action:"configuration.configure", icon:"st.secondary.configure"
		main "temperature"
		details(["temperature", "mode", "fanState", "fanLow", "fanMedium", "fanHigh","off", "cool", "coolSliderControl", "coolingSetpoint", "refresh", "configure"])
def parse(String description)
	def map = createEvent(zwaveEvent(zwave.parse(description, [0x42:1, 0x43:2, 0x31: 3])))
	if (!map) {
		return null
	def result = [map]
	if (map.isStateChange && map.name in ["heatingSetpoint","coolingSetpoint","thermostatMode"]) {
		def map2 = [
			unit: getTemperatureScale()
		if (map.name == "thermostatMode") {
			state.lastTriedMode = map.value
			if (map.value == "cool") {
				map2.value = device.latestValue("coolingSetpoint")
				log.info "THERMOSTAT, latest cooling setpoint = ${map2.value}"
			else {
				map2.value = device.latestValue("heatingSetpoint")
				log.info "THERMOSTAT, latest heating setpoint = ${map2.value}"
		else {
			def mode = device.latestValue("thermostatMode")
			log.info "THERMOSTAT, latest mode = ${mode}"
			if ((map.name == "heatingSetpoint" && mode == "heat") || (map.name == "coolingSetpoint" && mode == "cool")) {
				map2.value = map.value
				map2.unit = map.unit
		if (map2.value != null) {
			log.debug "THERMOSTAT, adding setpoint event: $map"
			result << createEvent(map2)
	} else if (map.name == "thermostatFanMode" && map.isStateChange) {
		state.lastTriedFanMode = map.value
	log.debug "Parse returned $result"
	result
// Event Generation
def zwaveEvent(physicalgraph.zwave.commands.thermostatsetpointv2.ThermostatSetpointReport cmd)
	def cmdScale = cmd.scale == 1 ? "F" : "C"
	def map = [:]
	map.value = convertTemperatureIfNeeded(cmd.scaledValue, cmdScale, cmd.precision)
	map.unit = getTemperatureScale()
	map.displayed = false
	switch (cmd.setpointType) {
		case 1:
			map.name = "heatingSetpoint"
			break;
		case 2:
			map.name = "coolingSetpoint"
			break;
		default:
			return [:]
	// So we can respond with same format
	state.size = cmd.size
	state.scale = cmd.scale
	state.precision = cmd.precision
	map
def zwaveEvent(physicalgraph.zwave.commands.sensormultilevelv3.SensorMultilevelReport cmd)
	def map = [:]
	if (cmd.sensorType == 1) {
		map.value = convertTemperatureIfNeeded(cmd.scaledSensorValue, cmd.scale == 1 ? "F" : "C", cmd.precision)
		map.name = "temperature"
	} else if (cmd.sensorType == 5) {
		map.value = cmd.scaledSensorValue
		map.unit = "%"
		map.name = "humidity"
	map
def zwaveEvent(physicalgraph.zwave.commands.thermostatoperatingstatev1.ThermostatOperatingStateReport cmd)
	def map = [:]
	switch (cmd.operatingState) {
		case physicalgraph.zwave.commands.thermostatoperatingstatev1.ThermostatOperatingStateReport.OPERATING_STATE_IDLE:
			map.value = "idle"
			break
		case physicalgraph.zwave.commands.thermostatoperatingstatev1.ThermostatOperatingStateReport.OPERATING_STATE_HEATING:
			map.value = "heating"
			break
		case physicalgraph.zwave.commands.thermostatoperatingstatev1.ThermostatOperatingStateReport.OPERATING_STATE_COOLING:
			map.value = "cooling"
			break
		case physicalgraph.zwave.commands.thermostatoperatingstatev1.ThermostatOperatingStateReport.OPERATING_STATE_FAN_ONLY:
			map.value = "fan only"
			break
		case physicalgraph.zwave.commands.thermostatoperatingstatev1.ThermostatOperatingStateReport.OPERATING_STATE_PENDING_HEAT:
			map.value = "pending heat"
			break
		case physicalgraph.zwave.commands.thermostatoperatingstatev1.ThermostatOperatingStateReport.OPERATING_STATE_PENDING_COOL:
			map.value = "pending cool"
			break
		case physicalgraph.zwave.commands.thermostatoperatingstatev1.ThermostatOperatingStateReport.OPERATING_STATE_VENT_ECONOMIZER:
			map.value = "vent economizer"
			break
	map.name = "thermostatOperatingState"
	map
def zwaveEvent(physicalgraph.zwave.commands.thermostatfanstatev1.ThermostatFanStateReport cmd) {
	def map = [name: "thermostatFanState", unit: ""]
	switch (cmd.fanOperatingState) {
		case 0:
			map.value = "idle"
			break
		case 1:
			map.value = "running"
			break
		case 2:
			map.value = "running high"
			break
	map
def zwaveEvent(physicalgraph.zwave.commands.thermostatmodev2.ThermostatModeReport cmd) {
	def map = [:]
	switch (cmd.mode) {
		case physicalgraph.zwave.commands.thermostatmodev2.ThermostatModeReport.MODE_OFF:
			map.value = "off"
			break
		case physicalgraph.zwave.commands.thermostatmodev2.ThermostatModeReport.MODE_HEAT:
			map.value = "heat"
			break
		case physicalgraph.zwave.commands.thermostatmodev2.ThermostatModeReport.MODE_AUXILIARY_HEAT:
			map.value = "emergency heat"
			break
		case physicalgraph.zwave.commands.thermostatmodev2.ThermostatModeReport.MODE_COOL:
			map.value = "cool"
			break
		case physicalgraph.zwave.commands.thermostatmodev2.ThermostatModeReport.MODE_AUTO:
			map.value = "auto"
			break
	map.name = "thermostatMode"
	map
def zwaveEvent(physicalgraph.zwave.commands.thermostatfanmodev3.ThermostatFanModeReport cmd) {
	def map = [:]
	switch (cmd.fanMode) {
		case physicalgraph.zwave.commands.thermostatfanmodev3.ThermostatFanModeReport.FAN_MODE_AUTO_LOW:
			map.value = "fanAuto"
			break
		case physicalgraph.zwave.commands.thermostatfanmodev3.ThermostatFanModeReport.FAN_MODE_LOW:
			map.value = "fanOn"
			break
		case physicalgraph.zwave.commands.thermostatfanmodev3.ThermostatFanModeReport.FAN_MODE_CIRCULATION:
			map.value = "fanCirculate"
			break
	map.name = "thermostatFanMode"
	map
def zwaveEvent(physicalgraph.zwave.commands.thermostatmodev2.ThermostatModeSupportedReport cmd) {
	def supportedModes = ""
	if(cmd.off) { supportedModes += "off " }
	if(cmd.heat) { supportedModes += "heat " }
	if(cmd.auxiliaryemergencyHeat) { supportedModes += "emergency heat " }
	if(cmd.cool) { supportedModes += "cool " }
	if(cmd.auto) { supportedModes += "auto " }
	state.supportedModes = supportedModes
def zwaveEvent(physicalgraph.zwave.commands.thermostatfanmodev3.ThermostatFanModeSupportedReport cmd) {
	def supportedFanModes = ""
	if(cmd.auto) { supportedFanModes += "fanAuto " }
	if(cmd.low) { supportedFanModes += "fanOn " }
	if(cmd.circulation) { supportedFanModes += "fanCirculate " }
	state.supportedFanModes = supportedFanModes
def zwaveEvent(physicalgraph.zwave.commands.basicv1.BasicReport cmd) {
	log.debug "Zwave event received: $cmd"
	log.warn "Unexpected zwave command $cmd"
// Command Implementations
def poll() {
	delayBetween([
		zwave.sensorMultilevelV3.sensorMultilevelGet().format(), // current temperature
		zwave.thermostatSetpointV1.thermostatSetpointGet(setpointType: 1).format(),
		zwave.thermostatSetpointV1.thermostatSetpointGet(setpointType: 2).format(),
		zwave.thermostatModeV2.thermostatModeGet().format(),
		zwave.thermostatFanModeV3.thermostatFanModeGet().format(),
		zwave.thermostatOperatingStateV1.thermostatOperatingStateGet().format()
	], 2300)
def quickSetHeat(degrees) {
	setHeatingSetpoint(degrees, 1000)
def setHeatingSetpoint(degrees, delay = 30000) {
	setHeatingSetpoint(degrees.toDouble(), delay)
def setHeatingSetpoint(Double degrees, Integer delay = 30000) {
	log.trace "setHeatingSetpoint($degrees, $delay)"
	def deviceScale = state.scale ?: 1
	def deviceScaleString = deviceScale == 2 ? "C" : "F"
    def locationScale = getTemperatureScale()
	def p = (state.precision == null) ? 1 : state.precision
    def convertedDegrees
    if (locationScale == "C" && deviceScaleString == "F") {
    	convertedDegrees = celsiusToFahrenheit(degrees)
    } else if (locationScale == "F" && deviceScaleString == "C") {
    	convertedDegrees = fahrenheitToCelsius(degrees)
    } else {
    	convertedDegrees = degrees
	delayBetween([
		zwave.thermostatSetpointV1.thermostatSetpointSet(setpointType: 1, scale: deviceScale, precision: p, scaledValue: convertedDegrees).format(),
	], delay)
def quickSetCool(degrees) {
	setCoolingSetpoint(degrees, 1000)
def setCoolingSetpoint(degrees, delay = 30000) {
	setCoolingSetpoint(degrees.toDouble(), delay)
def setCoolingSetpoint(Double degrees, Integer delay = 30000) {
    log.trace "setCoolingSetpoint($degrees, $delay)"
    } else {
	delayBetween([
		zwave.thermostatSetpointV1.thermostatSetpointSet(setpointType: 2, scale: deviceScale, precision: p,  scaledValue: degrees).format(),
	], delay)
def configure() {
	delayBetween([
		zwave.thermostatModeV2.thermostatModeSupportedGet().format(),
		zwave.thermostatFanModeV3.thermostatFanModeSupportedGet().format(),
		zwave.associationV1.associationSet(groupingIdentifier:1, nodeId:[zwaveHubNodeId]).format()
	], 2300)
def modes() {
	["off", "heat", "cool", "auto", "emergency heat"]
def switchMode() {
	def currentMode = device.currentState("thermostatMode")?.value
	def lastTriedMode = state.lastTriedMode ?: currentMode ?: "off"
	def supportedModes = getDataByName("supportedModes")
	def modeOrder = modes()
	def next = { modeOrder[modeOrder.indexOf(it) + 1] ?: modeOrder[0] }
	def nextMode = next(lastTriedMode)
	if (supportedModes?.contains(currentMode)) {
		while (!supportedModes.contains(nextMode) && nextMode != "off") {
			nextMode = next(nextMode)
	state.lastTriedMode = nextMode
	delayBetween([
		zwave.thermostatModeV2.thermostatModeSet(mode: modeMap[nextMode]).format(),
	], 1000)
def switchToMode(nextMode) {
	if(supportedModes && !supportedModes.contains(nextMode)) log.warn "thermostat mode '$nextMode' is not supported"
	if (nextMode in modes()) {
		"$nextMode"()
	} else {
		log.debug("no mode method '$nextMode'")
def switchFanMode() {
	def currentMode = device.currentState("thermostatFanMode")?.value
	def lastTriedMode = state.lastTriedFanMode ?: currentMode ?: "off"
	def supportedModes = getDataByName("supportedFanModes") ?: "fanAuto fanOn"
	def modeOrder = ["fanAuto", "fanCirculate", "fanOn"]
	while (!supportedModes?.contains(nextMode) && nextMode != "fanAuto") {
	switchToFanMode(nextMode)
def switchToFanMode(nextMode) {
	def supportedFanModes = getDataByName("supportedFanModes")
	if(supportedFanModes && !supportedFanModes.contains(nextMode)) log.warn "thermostat mode '$nextMode' is not supported"
	def returnCommand
	if (nextMode == "fanAuto") {
		returnCommand = fanAuto()
	} else if (nextMode == "fanOn") {
		returnCommand = fanOn()
	} else if (nextMode == "fanCirculate") {
		returnCommand = fanCirculate()
	} else {
		log.debug("no fan mode '$nextMode'")
	if(returnCommand) state.lastTriedFanMode = nextMode
	returnCommand
def getDataByName(String name) {
	state[name] ?: device.getDataValue(name)
def getModeMap() { [
	"off": 0,
	"heat": 1,
	"cool": 2,
	"auto": 3,
	"emergency heat": 4
def setThermostatMode(String value) {
	delayBetween([
		zwave.thermostatModeV2.thermostatModeSet(mode: modeMap[value]).format(),
	], standardDelay)
def getFanModeMap() { [
	"auto": 0,
	"on": 1,
	"circulate": 6
def setThermostatFanMode(String value) {
	delayBetween([
		zwave.thermostatFanModeV3.thermostatFanModeSet(fanMode: fanModeMap[value]).format(),
	], standardDelay)
def off() {
	delayBetween([
		zwave.thermostatModeV2.thermostatModeSet(mode: 0).format(),
	], standardDelay)
def heat() {
	delayBetween([
		zwave.thermostatModeV2.thermostatModeSet(mode: 1).format(),
	], standardDelay)
def emergencyHeat() {
	delayBetween([
		zwave.thermostatModeV2.thermostatModeSet(mode: 4).format(),
	], standardDelay)
def cool() {
	delayBetween([
		zwave.thermostatModeV2.thermostatModeSet(mode: 2).format(),
	], standardDelay)
def auto() {
	delayBetween([
		zwave.thermostatModeV2.thermostatModeSet(mode: 3).format(),
	], standardDelay)
def fanLow() {
	delayBetween([
	], standardDelay)
def fanMedium() {
	delayBetween([
	], standardDelay)
def fanHigh() {
	delayBetween([
	], standardDelay)
private getStandardDelay() {
	1000
I tried:
zwave.thermostatFanModeV3.thermostatFanModeSet(fanMode: 0)
to trigger the Auto fan speed mode but it doesn’t trigger anything,
is the MCO Home thermostat capable of sending this command? I can trigger it manually from the thermostat itself but I want to implement it in the code.
This seems to be the only thing not working for me to make this device perfect.
I’m using the 2 pipe one (cooling only with 3 speeds)
One more thing that’s bothering me, is there a library or some list somewhere that indicates that:
0 is auto
1 is low
3 is high
5 is medium?
Where do I find these numbers from??
Thanks @johnconstantelo
Hello Giovanni, this is Nunzio, I suppose that you are an Italian developer like me.
My e-mail is renzetti@fv-impianti.it
Would you please send me an e-mail?
I would like to ask to you about Z-Wave MCO Home fan coil thermostat and SmartThings “real life” experience.
Thank you
@giovanni645 any luck with this device handler and the new st app? Mine doesnt work.
