Heiman Smoke Detector z-wave plus 868.42MHz (HS1SA-Z)
I tested this product with Smartthings and works great. Firstly it is recognized as Door sensor. I changed the Device Type in the API to Z-Wave Smoke Alarm and works perfect.
The states sent are:
battery: 100 %
smoke: clear
checkInterval: 7320
alarmState: clear
In the log (Recently) appear the battery checks and the alarm state, for example, if you press the button on the smoke detector, the events are fired.
In Smart Home Monitor appear good as Smoke detector.
Happy with the purchase.
https://es.aliexpress.com/item/Wireless-z-wave-alliance-protocol-smart-anti-fire-smoke-detector-CE-ROSH-approved-z-wave/32815418807.html
Note that there are zwave and zigbee versions. Tested has been zwave version.
Now waiting for the Xiaomi Mijia Honeywell Fire Alarm Detector Zigbee to test it.
Yes I found a : Z-Wave Basic Smoke Alarm, I will test that.
But tell me - have you also tried the humidity / temperature sensor ( HS1HT-Z ) from Heiman ?
I cant find any device type for this ( Z-Wave ) have you ?
Sorry Toch. I did not purchased the humidity / temperature sensor from Heiman.
From Heiman I purchased a key fob but all tries does not work!
Smart Remote Controller HS1RC-M
It is a zigbee remote for activate / deactivate the alarm but it does not work. I try the next Device Handlers but does not work with this remote:
tierneykev : Securifi Key Fob
tierneykev : SwanOne Fob
mitchpond : Iris Smart Fob
I receive today the Siren Alarm NEO Coolcam Z-wave and works great! (no plug, only batteries :smiley: )
I receive the Honeywell Smoke detectors and works great too!
For anyone who also got a Xiaomi Honeywell Smoke Detector, there is a beta DH available here [RELEASE] Xiaomi Honeywell Zigbee Smoke Detector (Beta)
Hello!
I also bought a HEIMAN smoke sensor, which immediately connected with the smartthings hub.
I changed the Device Type to Z-Wave Smoke Alarm, but the sensor always becomes offline after about 4 hours.
What could be wrong?
I bought it here:
https://www.aliexpress.com/item/HEIMAN-Independent-Wifi-Smoke-Detector-Smart-Home-Version-85dB-Wrieless-Smoke-fire-alarm-Sensor-Battery-Standby/32866421469.html?spm= a2g0s.9042311.0.0.a4644c4dloYiFl
Hi did you found a solution for that? My sensors do the same thing, the check time is too long and they get offline at times.
When the sensor was “offline” I tested it with smoke and I immediately received a notification on the phone - a fire. So, I think the sensor goes into sleep, but when it detects smoke, it immediately connects to the hub.
i just purchase 4 of them i currently install them .
fist i try zwave basic smoke alarm handler but i saw an insane internal time
so i change it to Zwave smoke alarm (although it hasn’t Co2 sensor) with much more reasonable internal time 7320 sec
but in both cases i have a problem .
after i test them they don’t return to ‘‘clear’’ condition … why ?
i’m not waiting enough ?
i think that it needs reset every time ? ?? am i correct ?
Were you able to figure this out? I have the exact same problem and have yet to find a solution. Thanks!
Reset the sensor. Makes sense after all…
Use the Zwave smoke alarm device handler
Hi folks, I’ve just installed one of these and was hoping to connect it to my other smoke alarms (currently have a frient Heat Alarm and planning to add some others) to set off all the sirens at once. I can get the Heiman to activate the frient but not the other way around.
Has anyone had any luck with this?
