Below is a list of device types that have already been migrated to our new Lua Edge drivers. We will mark new entries to this list with BOLD TEXT to make it clear which entities are new from week to week.
You can confirm if your device is using a Lua Edge driver by checking out the steps here. If your device has been migrated and you feel it is no longer working as expected, please reach out to our customer support team by selecting “Contact Us” from the Menu (☰) in the SmartThings app. Test
Note: Your device type may be on the list and still not have migrated. That does not mean your device will not be migrated, it may just be done at a later time. We will have an announcement posted later addressing devices that fall into this category.
| Device Types | |
| ZigBee Sound Sensor | Qubino Dimmer |
| Zigbee Power Meter | Dawon Z-Wave Smart Plug |
| Zigbee Range Extender | Ecolink Zigbee Water/Freeze Sensor |
| Springs Window Fashions Remote | Z-Wave Switch Battery |
| SmartSense Temp/Humidity Sensor | NYCE Motion Sensor |
| GE Link Bulb | eZEX Temp & Humidity Sensor |
| ZigBee RGB Bulb | Z-Wave Basic Window Shade |
| Z-Wave Water Sensor | Eaton Accessory Dimmer |
| Z-Wave Motion Sensor | DM2500ZB Sinope Dimmer |
| Z-Wave Mouse Trap | SW2500ZB Sinope Switch |
| Cree Bulb | Orvibo Gas Detector |
| Ikea Motion Sensor | Zooz Power Strip |
| SmartSense Button | RM3250ZB Sinope Load Controller |
| Z-Wave Range Extender | Zigbee Plugin Motion Sensor |
| SmartSense Open/Closed Sensor | Zigbee Metering Plug Power Consumption Report |
| Z-Wave Metering Switch | Qubino 3 Phase Meter |
| Z-Wave Garage Door Opener | NYCE Open/Closed Sensor |
| Zigbee Metering Plug | CentraLite Thermostat |
| Z-Wave Switch Secure | CT100 Thermostat |
| ZigBee Switch Power | ZigBee Dimmer |
| ZigBee Dimmer Power | ZigBee Lock Without Codes |
| Z-Wave Metering Dimmer | Inovelli 2-Channel Smart Plug |
| Zigbee Motion detector | Fibaro Single Switch 2 ZW5 |
| Orvibo Contact Sensor | TH1123ZB-TH1124ZB Sinope Thermostat |
| Z-Wave Water Valve | ZigBee Dimmer with Motion Sensor |
| ZLL RGB Bulb | Zen Thermostat |
| Tyco Door/Window sensor | Z-Wave Thermostat |
| SmartSense Moisture Sensor | Z-Wave Battery Thermostat |
| ZigBee Switch | Fibaro Walli Dimmer Switch |
| Z-Wave Relay | ZLL RGBW Bulb |
| SmartSense Multi | ZigBee Valve |
| Keen Home Smart Vent | Aeon Outlet |
| SmartPower Dimming Outlet | Home Energy Meter |
| Nortek Water Leak Sensor | EcoNet Vent |
| Orvibo Moisture Sensor | Open/Closed Sensor |
| Z-Wave Motion/Light Sensor | TH1500ZB Sinope Thermostat |
| Aeon Home Energy Meter | Fidure Thermostat |
| Zigbee Motion/Temp/Humidity Sensor | TH1300ZB Sinope Thermostat |
| Dimmer Switch | TH1400ZB Sinope Thermostat |
| SmartPower Outlet | Samsung Smart Doorlock |
| Zigbee Smoke Sensor | eZEX smart electric switch |
| Spruce Sensor | Z-Wave Remote |
| Fibaro RGBW Controller | Z-Wave Switch |
| Aeon SmartStrip | Z-Wave Switch Generic |
| Z-Wave Water/Temp/Humidity Sensor | Z-Wave Dimmer Switch Generic |
| ZigBee White Color Temperature Bulb |
Arrival Sensor HA
| Aeon Siren |
Z-Wave Plus Door/Window Sensor
| SmartAlert Siren |
Z-Wave Lock Without Codes
| Fortrezz Water Valve |
Everspring Flood Sensor
| Z-Wave Sound Sensor |
Z-Wave Plus Motion/Temp Sensor
| Fibaro Door/Window Sensor |
Fibaro Flood Sensor
| Fibaro Door/Window Sensor ZW5 |
Zooz 4-in-1 sensor
| Z-Wave Door/Temp Sensor |
Fibaro Flood Sensor ZW5
| Danalock |
Z-Wave Motion/Temp/Light Sensor
| Everspring Illuminance Sensor |
Leaksmart Water Sensor
| Everspring ST814 |
Fibaro Door/Window Sensor 2
| Z-Wave Basic Heat Alarm |
SmartSense Moisture
| Zigbee CO Sensor |
ZigBee Battery Accessory Dimmer
| Secure Dimmer |
Z-Wave Mold Detector
| EZmultiPli | Z-Wave Button |
| Ozom Smart Siren |
Z-Wave Water/Temp/Light Sensor
| GatorSystem HomeWatcher | Motion Detector |
| Aeon Illuminator Module |
Z-Wave Temp/Light Sensor
| Z-Wave Metering Switch Secure |
Fibaro CO Sensor ZW5
| Temperature Sensor |
Aeon LED Bulb 6 Multi-White
| SmartPower Outlet V1 |
Z-Wave Motion Light
| Z-Wave Virtual Momentary Contact Switch |
Ecolink Water/Freeze Sensor
| SmartSense Multi Sensor |
Eaton Anyplace Switch
| SmartSense Motion Sensor |
Aeon Multisensor
| Z-Wave Door/Window Sensor |
Fibaro Motion Sensor
| Z-Wave Smoke Alarm |
Z-Wave Basic Smoke Alarm
| ZLL Dimmer Bulb | ZigBee Lock |
| Springs Window Fashions Shade |
ZigBee RGBW Bulb
| ZigBee Window Shade |
Qubino Flush Thermostat
| ZigBee Window Shade Battery |
Stelpro Ki Thermostat
| Z-Wave Window Shade |
Fibaro Smoke Sensor
| Z-Wave Lock |
Glentronics Connection Module
| Z-Wave Fan Controller |
Fibaro Motion Sensor ZW5
| Z-Wave Siren |
Fibaro Door/Window Sensor ZW5 with Temperature
| Zigbee Siren |
Aeon Multisensor Gen5
| AXIS Gear ST |
Danfoss LC13 Thermostat
| iblinds Z-Wave |
Stelpro Maestro Thermostat
| ZigBee Accessory Dimmer |
Stelpro Ki ZigBee Thermostat
| Fibaro Walli Roller Shutter |
VA4200WZ-VA4200ZB Sinope Valve
| Fibaro Walli Roller Shutter Driver |
Aeotec Doorbell Siren 6
| MimoLite Garage Door Controller |
HomeSeer Multisensor
| ZLL White Color Temperature Bulb 5000K |
Leviton RC Series Thermostat
| Fibaro Dimmer 2 ZW5 | Light Sensor |
| ZigBee Lock |
Eaton 5-Scene Keypad
| ZLL White Color Temperature Bulb | Z-Wave Device |
| Wemo Light Switch | Z-Wave Radiator Thermostat |
| LAN Wemo Switch | Philio Multiple Sound Siren |
| LAN Wemo Motion | Ecolink Wireless Siren |
| LAN Wemo Light Switch | Zigbee Thermostat |
| Z-Wave Dual Switch | Z-Wave Binary Switch Endpoint Siren |
| Zooz Double Switch ZEN30 | Qubino Flush Shutter |
| Qubino Flush 2 Relay | LAN Bose SoundTouch |
| Fibaro Walli Double Switch | LAN Bose SoundTouch No Notification |
| Fibaro Double Switch 2 ZW5 | LAN SamsungAudio |
| Fibaro Wall Plug US ZW5 | Z-Wave Multi Metering Switch |
| ZigBee Multi Switch | Zigbee Non-Holdable Button |
| ZigBee Multi Switch Power | Zigbee Button |
| ZigBee Metering Dimmer | Qubino Flush 2 Relay |
| Aeon Multisensor 6 | Zigbee Multi Switch |
| Fibaro Heat Controller | wl4200s wl4200 sinope water leak sensor |
