Device Type Handlers: dead?
Are custom device type Handlers DTHs dead?
I was using one for the Enerwave Ceiling Mounted Zwave Motion Sensor. After successfully adding them back to ST hub v2, I’m having trouble with the DTH. It shows the icon as if it has motion nonstop for one thing. Just trying to narrow down my troubleshooting.
Thank you. Can you clarify: so existing DTHs may continue to work for a bit, but new ones will require the new coding. Is that right?
ST is currently in the process of migrating devices from groovy device handlers to Edge drivers. The current time frame is Q1 2023 for it to be completed.
