Hmm interesting, I ordered one Red and 2 Whites, and only my Red one has arrived. - I spoke to Steve @ Fibaro who said they hadn’t had any stock of White Buttons in the UK yet :S
Better give him a call on Monday again!
I stopped at 4 clicks because that’s all that is supported using the standard button controller smartapp, also, i only really needed single and double click for my use case, (a button next to my bed to run routines like ‘night mode’ or ‘morning’/‘home’ etc
It also recognises holds and releases as seperate commands, I tried to get that to work, but the button always got stuck in the ‘HELD’ mode. - I think the expecation is that there is a seperate command for ‘HELD RELEASED’ but I couldn’t work out how to reliably get that to work.
The other issue is around the ‘wake up’ command, (which happens when you quadruple click the button) - It was throwing an error for a while, which i basically got it to ignore. - Not even sure what the wake up command should do, so I abandoned that.
