Android app update 8 February 2020 - v1.7.43-22
No you could see the “done” button is greyed out which means you cannot set . 5 set point.
And to FYI, not every modern thermostat has the ability to set .5 degree Celsius, mine from the get go does not, i could only set integer degrees.
The dark mode is nice and some of the other changes improve the UI however…
I still have issues the the remotes being pointless. The UI just shows a vertical list of buttons that say STANDBY. What’s the point if you can’t touch the button and have it do something? :wink:
I still have to find the physical remote in a room and press a button.
My bad, I thought the 25-30 years old Eastern European hightech was a standard in 2020.
Ah didn’t notice you’re in Europe. That’s another region and, I don’t know specific regarding industry standards, but I would’ve guessed it would deviate based on different countries and jurisdictions.
Anyway this is going out of topic
It seems that some of my button/remote devices can now be pressed from the app, but others can not. Progress in the right direction at least.
It is still a bug…
Set point, yes, and all the points I mentioned above
What about the History, how far can you scroll down? I can see a limit of 2 hours only, if refreshed by pulling down, the list duplicates itself. :thinking:
I think it’s not based on how many days it can display but how many entries. Some of my devices i can only see up to yesterday, but others I can see through a few days back.
For temperature sensors it can easily fill up and dump older entries.
I also noticed the refresh-mess-up issue
@Brad_ST, would you mind to log a bug report for the history refresh issue?
@Brad_ST don’t forget mines too, thanks!
https://community.smartthings.com/t/android-app-update-8-february-2020-v1-7-43-22/186215/33?u=pauly
And
https://community.smartthings.com/t/android-app-update-8-february-2020-v1-7-43-22/186215/34?u=pauly
I now understand @johnconstantelo 's angst when he is not getting the updates. Is hard to be patient when everyone talks about the new release and you don’t get the update LOL
I think I was the first one to get the update & when i posted asking for other opinions i couldn’t believe no one got it. Now this post has lit up.
I do wish the made the dark theme built into the app because I dont have android 10.
Still can’t load the Smartthings Connect app on my Samsung Tab 8 with Android 9. Wow can’t believe it.
Anybody else notice that controls for a lot of devices went missing after the app update, but they come back if the DTH is changed to something else and then changed back? Similar to the stale DTH issue, except happening with stock DTH’s too, not just custom ones. Had this happen with some bulbs using the stock Zigbee RBGW Bulb DTH and some z-wave switches using a custom DTH. After app update they all just had a single tile labeled “Status” which said “Connected”. After refreshing the DTH’s in the IDE they showed the new GUI with controls.
Yes i noticed after (android) app update i could only see Status “Connected” for all sensors but after i deleted App Cache controls/params became visible
(btw histogram issues i noticed custom DTH Xiaomis have more data than only one value but they are somehow clogged to the left side of the graph in very narrow space)
Same with the corresponding iOS update. All my speaker devices simply have “Connected” and nothing else now.
and yet the “stale DH” issue still isn’t fixed. Who wants to change the device type on 20 devices when you make one small change to the DH?
My sonos speakers show the track, the play buttons and allows me to chose from my favorite Sonos stations.
My fabriq speakers show only the off/on button
