new iOS app update today
Yep, and if you have your device in âDark Modeâ it messes up a lot of menus.
Example:
I just setup a few iOS shortcuts to change the Appearance to Light and Dark modes, and created a few iOS Automations so that when the SmartThings app is opened, it changes to Light Mode, and when SmartThings is closed, it changes back to Dark Mode. Whew.
I see the iOS app devs havenât changed their QA testing process ![]()
now thatâs a clever work around!
This release of the iOS app doesnât appear to bring anything much to the table. At least, for my use cases. Navigation on the Devices tab, like the changes reported for the Android app, make it âdifferent,â at best. I donât see any âimprovement,â but am aware weâre not all privy to the design goals/choices that drove the changes. At least Iâve not found anything broken beyond repair⌠![]()
Horrible horrible horrible. When I click an individual device to view it, all the options at the top are gone. What the heck?
Text isnât showing up in other menus as well.
That sounds like a lot of work⌠Samsung support didnât help except to say âIn this case I will take this as feedback, hopefully we will see in next update.â ![]()
I tried and when I click on the remote icon, it opens Smartthings but then. Says âunable to perform this actionâ and do nothing. So for me does not open the remote directly.
I also tried the power button and it worked like 1 time and then stopped working.
So I turned that feature off
A lot of work needs to be done on a software release.
Yes. Thatâs the reason I did the iOS shortcuts and routines mentioned above. In fact, since I use black wallpaper in SmartThings, it practically looks the same as it used to when dark mode wasnât a problem since most of the menus always displayed in light mode anyway.
I tried it too and disabled it since it obviously needs some work, but also since my Samsung HDTV always shows as Offline in SmartThings whenever itâs off anyway.
I use dark mode. They may be better without dark mode. I havenât checked. I use dark mode.
I have never used Shortcuts or Automations on my Apple devices. Thanks for the great tip! I set my iPad and iPhone up to do just as you described, Light mode when opening the SmartThings App and back to Dark mode when closing the SmartThings App. Works like a charm, thanks again!
1.7.18 is being rolled out
Dark mode appears to be fixed.
They still need to fix it on the iPad app.
thatâs odd⌠the version 1.7.18 works on my iPad.
1.7.17.15 is the version on my iPad. No updates showing available in App Store.
I
IPadios is 16.7.8 showing as up to date.
I was able to determine that the header icons work in dark mode if you know where to touch. They just do not display.
that is resolved with 1.7.18
