Aeotec Smart Home Hub 2/Aeotec Smart Home Hub/2018/2015 Model Hub Firmware Release Notes - 0.58.10
We will begin rolling out Samsung SmartThings Hub firmware version 0.58.10 starting on September 22, 2025. This will be a phased rollout, so that we can keep a close eye on any issues that arise, so your hub may not be updated immediately. Once downloaded, your Hub will briefly go offline as it reboots and applies the update; most customers will experience less than one minute of downtime. We will update the status page when the release is complete.
Hub Target:
  • Samsung SmartThings Hub 2015 (Hub v2)
  • Samsung SmartThings Hub 2018 (Hub v3)
  • Aeotec Smart Home Hub
  • Aeotec Smart Home Hub 2
Release Period: September 22nd, 2025 - October 1st, 2025
Note that this release will be spread out over the course of multiple weeks, so you may not see your Hub update on the first day of the release period. This release period is an estimate, so the rate of hubs updated and final completion date may vary slightly within the timeframe. Please check the status page for more up to date information on this release.
Release Notes
General
  • Thread stack upgrade to Thread 1.4, with support for:
    • Thread Credentials Sharing
    • TREL (Thread Radio Encapsulation Link), allowing Thread devices to communicate over IP networks, improving reliability
    • Public internet connectivity for Thread devices (NAT64)
      • This feature is enabled by default and can be turned off in the Thread section of your hub details in the Advanced User Web Interface
  • Thread Unification - In addition to the Thread Credentials Sharing feature, users can also now use the SmartThings app to unify the Hub’s Thread network with nearby Thread networks by utilizing the network credentials already stored in the mobile OS
    • These options and ability the to reset the Thread network can be found in the ā€œManage Thread networkā€ menu in SmartThings app versions 1.8.37 (Android) / 1.7.37 (iOS) or higher
  • Reduce ā€œpopcorningā€ when controlling Zigbee multi-gang (2, 3, etc.) light switches and outlets with local rules
  • Added support for 3rd party Matter HRAP (Home Routers and Access Points) device types:
    • Network Infrastructure Manager (NIM)
    • Thread Border Router (TBR)
  • Fix for Matter devices where other connected services were not being displayed in the Share with Other Services screen
Edge Drivers
  • Change device init lifecycles to be sent from the system instead of being generated artificially within the driver
    • This allows us better control over the order of lifecycle events and to be more consistent
    • This could break driver integration tests, depending on how they are configured; however, most common cases should remain unaffected
  • Expand event generation support outside of drivers to include colorTemperature, colorControl, powerMeter, and temperatureMeasurement capabilities
  • Fix the issue causing specific Zigbee messages (ZDO profile) to use generic byte strings instead of parsing fields
Thread improvements are so welcome! Matter over Thread devices now display the connection path too in the app (1.8.37 in Android at least), like they did in Zigbee.
Any thread improvements are definitely welcome. I really want to be able to remove my hub group.
Interesting. I don’t have 1.8.37 but I’m not seeing anything in the Heath Diagnostics API where I’d rather expected it to be.
It’s in the device profile and does not appear in previous app versions:
The Thread management options are in Hub device - Settings menu - Manage Thread network. It also displays if there are other TBRs connected to the same network, in my case a IKEA DIRIGERA which displays as OpenThread.
Edit: I hit the Leave button by mistake thinking it would leave the configuration menu, not enough coffee yet and I’m not used to the tablet UI :rofl: , at least there’s a pop-up to confirm because it is to leave the Thread network and generate a new one. Reminds me of those posts of ā€œI removed the hub by mistakeā€. Maybe ā€œReset hub networkā€ would have been better.
NAT64 is a killer feature for Thread devices like the Nuki Smart Lock Ultra. It lets IPv6-only Thread devices talk to IPv4 internet services, enabling seamless cloud access, remote control, firmware updates and app features without extra hardware like a Nuki Bridge.
Is there any option to disable it or control which devices can connect to the Internet?
Reminding you my message from previous hub updates:
Two problems are still missing:
  1. increase the transition of oflline time, so we won’t receive false offline states from zigbee devices that works on battery, that didn’t report status within 2 hours. I prefer 10 hours.
  2. Bring back HTML in custom capabilities edge driver to app as requested by @w35l3y here:[Feature Request] Allowing HTML in Custom Capabilities
App update (not hub).
  1. Please allow to choose language of the app. So, mobile phone can be 1st language and app will be other language.
  2. Please add ability to see mesh connections also in Z-Wave devices (already exist in Zigbee devices)
dang, my ST Station isn’t on 58.X yet
Cool. I’m really glad to see Samsung Thread Unification. I finally expanded my currently Thread network, instead of creating a new one. Awesome!
I’m expanding my old Apple Home network, since I have some HomePods and Apple TVs.
I’ve been waiting ages for the ability to have multiple hubs in the same thread network without using a hub group. Somehow I either overlooked or had forgotten that if you remove a hub from a hubgroup it remains on the thread network it was using in the group, so there was no need to wait for either the firmware update or the app.
I was hoping the ā€˜Thread network name’ on the ā€˜Thread network’ page would be clickable to allow the name to be changed to something a little more meaningful.
Great and welcome change, when will this be avilable on smartthings hubs that are embaded in new samsung tvs? those have thread boarder routers too
@mocelet if you don’t want your Matter devices to have access to the NAT64 feature you can turn this feature off in the Advanced User Web Interface. If you select your hub and scroll down to the Thread section of the UI there should be a ā€œNAT64 Translationā€ tile with the option to disable it. If you want it disabled across your entire Thread network you will need to disable this feature on all your Border Routers since they each individually offer the feature because of how Thread works.
The team added a quick note of this in the main release notes as well.
Thanks @Michael_ST , I see the option now!
I have 2 x hub 2’s on my network (one is a spare which I plug in when I’m aware of an update). One updated to 58.10 and rebooted without incident. The other became offline and after an hour and half I figured it was time to reboot, and the hub came back online updated with 58.10.
It was lucky that I was able to monitor it at home and take action.
I feel sorry for those who may be away during the update and their hubs don’t come back online automatically.
Will it work with TV hubs?
Don’t have 58.10 and app update yet
I’ve never been at home when a firmware update happened - no issues so far.
NAT64 works as expected! My Nuki Ultra lock (Matter/Thread) automatically connected to the Nuki cloud, remote access works and I could even run a firmware update while away.
Today both of my two v2 hubs have updated to fw 58.10. This update must have freed up memory. Both hubs have gone from driver memories of ā€œSoft limitā€ to ā€œOkā€.
TV and other built-in hubs are on a different firmware schedule. The current 58.10 firmware only applies to stand alone hubs:
How much TV hubs tend to lag behind?
Sorry, I do not know the answer. ST has never posted any announcements for when they will update firmware on built-in hubs.
