We will begin rolling out Samsung SmartThings Hub firmware version 0.45.9 starting Monday, October 17. Once downloaded, your Hub will briefly go offline as it reboots and applies the update; most customers will experience less than one minute of downtime. We will update the status page when the release is complete.
Hub Target:
Samsung SmartThings Hub 2015 (Hub v2)
Samsung SmartThings Hub 2018 (Hub v3)
Aeotec Smart Home Hub
Release Date: 17 October 2022 ~ 21 October 2022
Note that this release may be spread out over a week, so you may not see your Hub update the first day of the release period.
Release Notes
General
Fixed an issue driving high system CPU when the Drivers were nearly the hard memory limit, resulting in frequent disconnects, high latency, and other issues.
Fixed a bug that was preventing Driver Live Logging from being viewed by the Location members.
Upgraded the Zigbee Stack for the SmartThings Hub 2018 and the Aeotec Smart Home Hub. There is no new functionality added.
ââŠan update later this month will turn Samsungâs standalone SmartThings hubs into controllers for ⊠Matter. The v2 hub will control Matter devices over Wi-Fi and ethernet, while the current hub and SmartThings dongle will also act as Thread border routers⊠While the upgraded hubs will still support Zigbee and Z-Wave, they wonât be Matter bridges, at least not anytime soon ⊠SmartThings users will be able to continue to use those devices connected to a SmartThings hub, but existing Zigbee and Z-Wave devices wonât be exposed to Matter.â
So, for the v2 hub:
Can I add Matter devices and control them through Smartthings app and hub? I think the answer is yes if they are WiFi or ethernet devices? What about Zigbee or Z-Wave Matter devices (if there is such a thing).
What is a âMatter bridgeâ and what does it mean that this wonât happen soon? Can I control both Matter and existing devices from the Smarttings app? Can I use Sharptools to write rules that say, âif a Matter sensor does X then do Y with my existing Z-wave switch?â
Suppose I add Matter devices that communicate with Thread. Do I need a Thread border router for these to work. Where do I get one? Once I add this, can I control all of those through the Smartthings app? Can I write Sharptools rules around them all?
What is different with the v3 hub? If I wanted to upgrade to the v3 hub, what would that entail?
Copying my reply to you from the SharpTools community
You can bring matter devices into the SmartThings ecosystem and use them in apps like SharpTools, but SmartThings is not going to output its native Zwave and Zigbee devices to other Matter hubs.
So I think answers to your bullets are yes, bridge=output, v3 hub has thread but not v2, and I wouldnât upgrade unless you specifically need Thread since theres no migration tool
This link and this other link describes some of the differences, but the ones most people care about:
V2 has ethernet only. V3 is WiFi and ethernet
V2 supports 32 zigbee devices, V3 supports 64. Iâm not sure if thatâs true anymore with zigbee stack upgrades. And that may be âdirectâ not thru zigbee routing devices.
V2 has twice the flash and ram that the V3 does. Some of us are concerned about Edge memory usage being more constrained on the V3.
V2 has battery backup, V3 does not. Personally I never saw the point other than just a place for batteries to leak. If power is out, hardwired devices are dead, and youâd need a UPS for the rest of the home networking components (router, switches, etc) anyway so just put the hub on one too.
There is no migration tool to move zwave and zigbee devices from one hub to another. Youâd have to re-pair/include each of them and recreate their routines.
Thread isnât a big deal to upgrade. If you have one Echo 4th gen, an AppleTV4k2, Nest Hub or any other thread hub, just one of those would connect your thread devices to IP networks which your ST hub could access with just ethernet or wifi of its own.
My wifi mesh hub starting broadcasting its DHCP to the WAN uplink port last Wednesday. Nothing changed in my configuration (as this is in a remote location). Would a firmware update have been released recently that might have caused this? The service provider has disconnected my service temporarily and the network is offline until I can figure out why itâs broadcasting to the WAN. Not sure how I can even get a fix update, since I have no connectivity.
Help! I dont use a hub, just a few samsung cameras and the smart things app. As of last night, all of my video recordings now have an exclamation mark and cannot be viewed, also my previous recordings cannot be viewed either, but do not have the exclamation
yeah, Matter edge drivers were moved in 6 days ago. It seems the backend is prepared, hub firmware is rolling out, so now weâre jsut lacking the UI in the mobile app for itâŠand actual matter devices to add.
