Cick the blue link: March 8, 2017 - New Product Announcement
I have been a part of the smartthings community for only about three months, and I’ve seen a lot of interesting ideas and devices. I would like to introduce one that we have been working on and seems to fill in a need for some people:
Full Disclaimer: We are dealers of Graber products, all our products are made to order at custom sizes and options.
Video with SmartThings v2 hub:
Controlling Multiple Shades (Solar Shade on the left and Cellular Shade on the right)
Graber’s virtual cord shades utilize Z-Wave+ to operate. This means it can be directly integrated with Samsung’s SmartThings and other home automation systems. In SmartThings, it works as a dimmer switch so using Smart Lighting it should be able to run locally.
Motorization is manufactured by Somfy, but the system is designed by Graber (Springs Window Fashions)
If you are in the United States, please go to https://www.zebrablinds.com/smart-homes/smart-motorized-electric-shades
If you are in Canada, please go to https://www.zebrablinds.ca/smart-homes/smart-motorized-electric-shades-canada
Types of shades available with Z-wave Motors:
- Cellular Shades
- Pleated Shades
- Natural Shades
- Roller Shades
- Dual Roller/Solar Shades (one shade in front, and an indpendent shade in the back)
- Roman Shades
- Solar Shades
- Sheer/Zebra Sheer Shades (BRAND NEW LAUNCH ON MARCH 8, 2017)
Ordering Dual Roller/Solar Shades: We do accept orders for dual shades with the z-wave motors, however it is a custom quote for the time being. If you need them please email us on our site, or PM me here for a quote. Dual shades are basically two roller shades in the same casing, one in the front and the other in the back. They are available either with no valance, or a large cassette valance only.
If you have any questions, please get in touch, will be more than happy to help. I’ll be putting up additional videos soon showing the inclusion and exclusion process.
Coupons can be found here (updated on Oct 24, 2017): Graber Virtual Cord Shades: Z-Wave+ (Coupons)
Adding & Removing from SmartThings (or other Z-Wave HA systems)
Adding the shades to SmartThings: https://www.youtube.com/watch?v=8mTF8uF7jnE&feature=youtu.be
Removing the shades from SmartThings: https://www.youtube.com/watch?v=omuZdQ9gNFE&feature=youtu.be
Installing the Shades on a window
General installation and other info: https://youtu.be/7M7tYf3KGd4
Unboxing & Installing Roller/Solar Shades on a window: https://www.youtube.com/watch?v=BcVVGHDOfKA
General how to videos
Replacing Batteries: https://www.youtube.com/watch?v=r1pOjMVThP8
Note: When replacing batteries make sure the battery is installed with the correct polarity on both sides. Please pay attention to the symbols on the battery case (special thanks to @ashutosh1982 for pointing this out)
Trouble Shooting
Oh no! I have connected my shades to smartthings but now it won’t go up and down by more than 3 inches. What do I do?
Ans: https://www.youtube.com/watch?v=PtuimePrstE -
Oh no! My shade is possessed! Pressing up makes it go down and pressing down makes it go up, What do I do?
Ans: https://www.youtube.com/watch?v=akyaRLQfrjQ&feature=youtu.be -
The shades pair as a regular switch and not a dimmer switch. What do I do?
Ans: Z-Wave + integrated blinds/shades: Custom Graber Virtual Cord Shades -
I need to completely reset my shade and start over, what do I do?
Ans: To reset the shade, press and hold the button on the headrail. The button will flash green and eventually flash red. Once it cycles through all the colors and stops, the shade is reset. To double check simply tap the button and the shade will only move around 3 inches up or down.
Notes to consider: When resetting the shade, its recommended to have the shade in a halfway open/close position vs fully open or fully closed; this makes things a lot easier to trouble shoot. Also when resetting a shade, you will have to repair the remote to the shade and set the upper and lower limits again.
Frequently Asked Questions:
What is the difference between a roller & solar shade?
Check the following: Z-Wave + integrated blinds/shades: Custom Graber Virtual Cord Shades & Z-Wave + integrated blinds/shades: Custom Graber Virtual Cord Shades -
What is the difference between Even and Fashion Pleat shades?
Check the following: Z-Wave + integrated blinds/shades: Custom Graber Virtual Cord Shades -
What are the available power options?
Ans: Battery (8 or 16 AA 1.5V batteries, depending on a single or dual battery case, battery power recommended for 10 shades or less), DC Transformer (plugs into any wall outlet), or a 10 Motor power supply that you can use for custom wiring in your home. -
Can I use my own wiring for power?
Ans: You can while using the following multi motor power supply: https://drive.google.com/file/d/0B62Iui2hJtitcHhITzRVWEtJb1U/view?usp=sharing
Only the specs for the 12v power supply is relevant. The other’s do not apply to the z-wave shades. The power supply can power normal somfy motors or the z-wave motors. For the z-wave motors each multi motor unit can power up to 10 roller/solar, natural and roman shades and up to 8 cellular or pleated shades. -
Can I connect these to Amazon’s Echo or Google Home?
Ans: Yes, you can. Connect your Echo or Google Home to ST and enable access in ST for Echo or Google Home to control them. They work exactly like a dimmer switch, so turn on/off and set a specific percentage level.
Compatible DH and SmartApps: All Credit goes to @whoismoses for his wonderful work!
- ST-Z-Wave-Somfy-Remote: Lets you use your z-wave virtual cord remote as/like a 2 button minimote. You can use it to trigger things, routines, CoRE pistons, etc.
- ST-Z-Wave-Shade: Shows additional information such as current battery levels and has preset open positions and one customizable preset.
- Shady - Group your shades & blinds and control as a single device
Once again, all credit for the DH and SmartApps go to @whoismoses who did an amazing job with them. I had no role in their creation and am simply listing them here (with permission) so it’s easier to find.
SmartThings User Feedback/Reviews:
- Z-Wave + integrated blinds/shades: Custom Graber Virtual Cord Shades
- Z-Wave + integrated blinds/shades: Custom Graber Virtual Cord Shades (includes a video)
- Graber Virtual Cord Shades: Z-Wave+ (Coupons)
once again these are made to order so manufacturing will take 3 - 7 days and it ships through Fedex.
