When I select “light filtering roller shades” I don’t have any option for material. Basically every material has this red “blocked” sign so I can not actually pick material and therefore I can not make an order.
Heh, I see they updated the web site, but not the way I’d like it to be updated.
Now I clearly see that I don’t have an option for solar shade that is 93". The max I can select now is 91"
Hey Neal, I was having a look at your website and had a question before pulling the trigger and placing my order: what is the difference between the FashionPleat and the EvenPleat? Both in 1 inch size?
The main difference between them is that the even pleat has small ladders on the back of the pleats ensuring the pleats open and close evenly. Fashion pleat doesn’t have these so when opening the pleat will seem to be uneven until it’s fully open or closed.
Neal When I try to add my new blinds to smart things, they come up as a zwave switch not a dimmer. I am new to this whole technology. How can I change this to a dimmer or what am I missing? All help is appreciated.
I subsequently saw your post above about how to change to dimmer switch which I did but my blinds are still not moving at all. Any ideas? I tried dimmer switch and zwave dimmer switch generic but neither one worked.
I have been able to automate my blinds but one of them doesn’t respond. I have played with it but it won’t respond on the automation. I can get it to respond as a single device but not with all my other blinds. Any thoughts? I am wondering if there is something wrong with that Blind but it does respond as a single just not in automation with the others. I tried resetting and reassign and exchanging the battery pack but nothing has worked. Any ideas are appreciated.
If it responds as a thing but not in an automation it might just be an issue on ST’s side. Can you check with their support? Usually its a problem with the motor only if it doesn’t respond in ST at all. One more thing to check is if you have duplicate devices in ST, I know it’s happened to me before since exclude didn’t work properly the first time.
Okay. Thank you. Do you have a video on how to exclude? I just went into the website and removed it and then reset it but maybe I need to do something else?
