What's going on with Wemo switches? Working fine for 3yrs (April 2019)
Anyone else have Wemo switches?
I have a few Wemo switches and they are not working properly with SmartThings now.
I’ve had them for about 3 yrs and they randomly just start causing problems.
I can turn them on with a big lag but then they will still register as the switch being off when they actually turned on in the ST app. Can’t turn them off once they are on though. I’ve been having to use the Wemo app which works fine with all the Wemo switches.
I am thinking it started when the switches received a firmware update.
I’m having the same problem, which started last night after I installed the latest firmware. I can still control the devices, but they no longer report their status to SmartThings correctly. There was another firmware update today, but the issue remains.
Same issue here:
Seeing the exact same issue with my wemo switches. I can turn them on but the status never updates and then I am unable to turn them off. This has broke all of my home automation related to those switches.
It seems like the mobile app is having issues and that the Smartthings hub is having no problem communicating with devices. If I go into the Smarthings IDE (http://account.smartthings.com) and go to my devices I can see all of my WeMo switches. If I click into the switch it shows the correct status even though my phone app is wrong. I am also having issues with the phone app telling me it can’t control my Hue lights even though Alexa can via the Smartthings skill. I do not have any other skill enabled (hue or otherwise) and the Smartthings IDE is showing that there is no issues communicating with the Hue Bridge.
The WeMo integration is cloud to cloud. The hub doesn’t have anything to do with it. You could even unplug the hub and still have it work.
But definitely, yes, the app could be the culprit.
Make sure you report any problems of this type to support. First line support may not be able to help much, but the more people who report the problem, the sooner they will assign engineering resources to look into it.
https://support.smartthings.com/hc/en-us
I am pretty confident the issues are with the new mobile app. I opened up the classic app. Said I was a new user. It detected my Samsung Account and logged me in. I see all of my devices. I can control all of them (WeMo and Hue). The WeMo shows the correct state and the Hue lights are turning on and off correctly. I might try to uninstall the new app and reinstall to see if that fixes the issue.
Update: After reinstalling the mobile app the WeMo devices are showing the status correctly and the hue lights are working. Not sure what got messed up with the app, but I think I am back working.
Man they still have not fixed this?
Getting annoying now.
So do we need to get rid of our Wemo switches since they no longer work with ST after the firmware update?
Mine are still working fine. Maybe i haven’t gotten the firmware update though. I was planning on changing them though and even have the Leviton Z-Wave switches ready to install…just haven’t done it yet.
Upgraded three WeMo Insight switches to 11273.PVT (latest) and all stopped sending event change callback information when triggered locally OR wattage exceeds the defined threshold. They now only respond to direct polling. This is really unfortunate because I had updated the Juan Risso driver written way back in 2015 to act as a contact switch when the device reached a defined wattage for home automation reasons/requirements.
Has anyone had any luck with WeMo discussing the event callback LAN protocol they originally supported? From my initial basic checks direct communication with echo units are also no longer working.
Seems similar to Harmony Hubs ditching the local API functionality thinking it was not utilized. The only reason I put up with these bulky buggy things is they had event driven triggers which I haven’t found in Zwave or Zigbee devices concerning wattage. They are TCP/IP junk without immediate events!
Anyone have information on resolution for this issue? It’s still an issue for me, and I’m not certain if this is something we should be addressing with Wemo or with Smartthings.
Neither seems to be doing anything about it. Wondering if I should replace my wemo switches now…
Been going on for about a month now.
WeMo and SmartThings never did officially claim to support each other. I got tired of the Wemo firmware updates, mysterious reboots, poor 2.4G performance, and endless security problems and replaced them last week with Samsung SmartThings Outlet [GP-U999SJVLDAA] Smart Plugs which obviously work better with SmartThings. Boxed up seven WeMo Minis and three WeMo Insites and stuffed them all in storage.
I did update the zigbee driver to have a contact sensor event on watt usage and if anyone wants is here: SmartPower Outlet II
As you say. Here’s the reply I got from wemo:
Thanks for reaching out to us. Our Wemo devices are only compatible with the following 3rd party integration:
-IFTTT
-Google Home
-HomeKit
-Siri
-Nest Thermostat
We’ll take note of your feedback and relay it to the team so they can hear your thoughts regarding this matter.
For what it’s worth, things started working again about 36 hours ago.
I feel like I’m the only person with wemo switches with updated firmware lol
I did the same thing about a month ago, i gave up on the Wemo Switches and gave them all away, I will never buy another Wemo product. Not worth the hassle.
Wemo switches with updated firmware still do not work with Smartthings.
Same problem here with both of my WEMO switches. Appears the timing is the same as others report re firmware updates during the last few days.
Save yourself the frustration and use something else - anything else. I moved to the Samsung Zigbee Outlet and things just work like IoT should work. Wish I could go back in time and warn myself. WeMo was a cool starter device and maybe a good idea if the firmware quality was better.
Surprisingly my IP network has been more stable with fewer IP devices too. I don’t know if it was the WeMo devices or the POS modem the cable company installed but in NYC the 2.4G WiFi band is taxed hard with interference and jumps around if allowed. WeMo, Harmony Hubs and Amazon Fire HD 8s (on 5G running ActionTiles) appear to have a tough time following frequency changes. I had to lock the modem to a set channel on both frequencies to get them to behave reasonably and so 2.4G would leave my Zigbee channel alone.
