Post Requests for Zwave Edge Drivers Here (community-created)
Mine is also listed as a zwave switch; they work, but I set them up prior to the edge driver switch. My understanding is that once they’re programmed, the targets are “built into” the switch itself - saved in its memory or whatever. It might take someone coming up with a specific driver.
I’m looking for a Zwave thermostat driver for the Honeywell T6 Pro Thermostat. The capabilities that are missing now from the default Zwave driver are the ability to set a minimum cooling temp, a maximum heating temp, and on/off for the schedule. These abilities were available in Groovy with the @RBoy Universal Z-Wave Plus Thermostat device handler
Hi Mariano!
I have a couple of Z-wave scenario buttons (Master from Simon100. Before Edge, I used the stock DTH “Z-wave button” and it worked fine (I changed it to the Z-wave button manually in the IDE after pair-in). Now its a problem when re-pairing it.
Can you help med add a fingerprint from this device to one of your drivers?
Please read the first post in this thread.
When posting a request, you have to include the fingerprint of the device you are requesting or the community developers can’t help you.
The fingerprint consists of two fields: the manufacturer code, and the model code.
After adding the device to your smartthings account, you can see these fields in the web interface to your account at
my.smartthings.com/advanced
The fingerprint is case-sensitive, so most people just post a screenshot of the details page for the device so the developers can see the exact fingerprint.
Hi, ok, I made two screenshots of two paired-in devices, they should be identical
I am looking for an edge driver for the Zipato Multisensor Quad. It provides contact, motion, temperature, and luminance. The device name is Zipato PH-PSM02.US Quad Sensor, fingerprint 013C-0002-000C. If anyone is willing to help with this, I can provide the Zipato manual and the cobbled together DTH I was using. Thank you.
Hi have a zwave mco roller shutter switch, any help would be great, have looked for a edge driver cant find one, have also tried edge drivers with no luck,
Device Name
switch-binary
Device ID
a6142fc2-c56c-4980-8723-dcea6f9118ab
Model
C521-5103
Presentation ID
74cf66e1-ae7f-3a14-a6a8-1affef9ec321
Manufacturer Code
015F-C521-5103
I hope thats all correct, first time requesting a edge driver
thanks
Hi, would you be able to help me with a driver to please, its a MCO roller shutter switch, i have the info of it in my request post, i have also tried a heap of other drivers which havent worked, any help from you would be great, thanks
Hi @Troy_Boutsa
Install my zwave thing Mc driver to see all device data, fingerptints, endpoints and command class.
Publish device data to see if is possible add it to my driver
Hi, thanks so much for the reply, is this what you mean ?
not sure if this is better but i copy and paste it from the web interface instead of the screenshot ?
DeviceInfo:
Z-Wave Device:
DNI: 0x47
Firmware Ver: nil * Wake Up-Refresh Device
Library Ver: 3
Zw Protocol Ver: nil * Wake Up-Refresh Device
Manufacturer: 0x015F
Product Type: 0xC521
Product ID: 0x5103
End Point & Command Class: [1]: ZWAVEPLUS_INFO, ASSOCIATION, ASSOCIATION_GRP_INFO, VERSION, MANUFACTURER_SPECIFIC, DEVICE_RESET_LOCALLY, POWERLEVEL, SWITCH_BINARY, SWITCH_MULTILEVEL, CONFIGURATION, SCENE_ACTUATOR_CONF, SCENE_ACTIVATION, NOTIFICATION, METER, BASIC, FIRMWARE_UPDATE_MD
DeviceInfo:
Z-Wave Device:
DNI: 0x47
Library Ver: nil * Wake Up-Refresh Device
Product ID: 0x5103
Try installing this driver version
 Name         Z-Wave Window Treatment Mc
 Version      2023-10-11T14:53:38.244086664
- id: MCO/015F/C521/5103
    deviceLabel: MCO Windows Treatment
    manufacturerId: 0x015F
    productType: 0xC521
    productId: 0x5103
    deviceProfileName: window-treatment-power
Any driver that works with this: manuals-backend.z-wave.info/make.php?lang=en&sku=AD147-6&cert=ZC10-14080010
Also called Nexa AD-147 :slight_smile:
I think that Z-Wave Switch and Child Mc driver supports Nexa Dimmer Switch
More information about driver
I actually tried those but they didnt work, but have finally worked it out and its working great
Hi, did you ever figure this out, having exact same issue ?
Hi, Again, have another request of sorts, again any help would be great, have a qubino flush 1d zwave relay, have it in a gate attached to a magnet as a sensor, was working before edge had a groovy driver, the sensor no longer changes, to open or close, just says connected, have scoured the net, havent come up with anything
80938c56-eef9-4d37-806f-1787fec0f2d8
Activity history
TODAY
8:23 PM
DeviceInfo:
Z-Wave Device:
DNI: 0x3F
Library Ver: 3
Manufacturer: 0x0159
Product Type: 0x0002
Product ID: 0x0053
End Point & Command Class: [1]: ZWAVEPLUS_INFO, VERSION, MANUFACTURER_SPECIFIC, DEVICE_RESET_LOCALLY, POWERLEVEL, BASIC, SWITCH_ALL, SWITCH_BINARY, SENSOR_BINARY, NOTIFICATION, MULTI_CHANNEL, ASSOCIATION, MULTI_CHANNEL_ASSOCIATION, ASSOCIATION_GRP_INFO, CONFIGURATION
DeviceInfo:
Z-Wave Device:
DNI: 0x3F
Product ID: 0x0053
Hi,
What driver are you using?
If it automatically migrated from DTH to that edge controller, then it may not have been configured correctly and you will need to exclude it and pair it again.
On the other hand, I seem to remember other users who used these relays with an input for a contact sensor, I don’t know if that is their case.
Unfortunately smartthings has only migrated the official DTH code that handled a 0-10v input, and is used with the temperature capability optionally.
The open/close sensor input has not been officially migrated, I think because it was used with a custom DTH
