Post Requests for Zwave Edge Drivers Here (community-created)
Anyone able to make a driver for a zwave open/close sensor? It’s a hkzw-dws01. Tried some other drivers and it either goes offline all the time, or doesn’t work.
@Mariano_Colmenarejo would this be one that could be added to the Z-Wave Sensor and Child Thermostat Mc?
@qauck_aa - Were you able to locate a Fortrezz MIMO2+ edge driver? I have also been searching but have so far been been unsuccessful. thks
Hi there.
Is possibile have the edge driver for Vimar Thermostat? In italy a lot of people buy it, but with edge it has never works.
Really thanks
A post was merged into an existing topic: Post Requests for Zigbee Edge Drivers Here (community-created)
Were you or anyone else able to transition a GreenWave PowerNode outlet strip to Edge?
3 posts were split to a new topic: Edge driver for Monoprice Smart Plug and Repeater (27481)?
2 posts were merged into an existing topic: Edge driver for Monoprice Smart Plug and Repeater (27481)?
Anyone has the fan coil thermostat [MCO Home MH8-FC] edge drivers?
2 posts were merged into an existing topic: Post Requests for LAN Edge Drivers Here (community-created)
Request for Edge Driver for a Neo Coolcam Curtain switch.
In the last two years I could add as a switch and then change device type to z-wave window shade, now the change is not working and cannot get any device data. I’m attaching two pictures, one of them is a device still paired with the old driver.
I also need a driver for GoControl/Linear Linc LB60Z-1 bulbs. I’m surprised they don’t work with the basic drivers. It only provides the driver for a switch.
Technically under the third party Z wave specification, smart bulbs are the same device class as dimmer switches. It’s the same commandsets. So as long as the fingerprint matches, the device should work OK, although you might not like the icon.
https://products.z-wavealliance.org/products/1291
Zigbee has a separate device class for smart bulbs, but zwave never bothered with one. :thinking:
Ithis driver worked for me.https://github.com /Mariano-Github/SmartThingsEdgeDrivers/tree/main/drivers/SmartThings/zwave-switch
Sadly the fingerprint must not match the only driver that matches is a zwave switch and it does not work.
I picked up this device. I have an aeotec v3 hub, and I would like to adjust some of the settings on the device. My understanding is that in order to do so with the aeotec hub, I’d need ST Edge drivers that support it.
Is anyone aware of any compatible drivers?
Device link: https://ring.com/products/alarm-motion-detector-v2
Has anyone been able to pair Aeotec HEM gen 2 to Smartthings hub?? I have just bought one and unable to pair it. Is there edge drivers for this? I have already installed gen 5 driver but still not able to pair this devive.
Does anyone have or know of a Channel with and edge driver for a Monoprice Z-Wave door/ window contact sensor model 24259
I believe both the ST stock Edge driver and the Edge driver from @philh30 will support that sensor. You can subscribe to his channel here to install the driver to your hub.
Try Z-Wave Sensor PH
