The following is current as of Sept 9, 2015. This is a list of the officially approved SmartApps that are available for installation through the SmartThings mobile app under the SmartApps tab. In each category, you will find a combination of community contributed & SmartThings developed SmartApps.
To install any of these, open the mobile app, select the Marketplace icon (
), and select the SmartApps tab.
SmartThings Recommends
Smart Lights by SmartThings
Control and automate Lights and Switches.
Safety & Security
Notify Me When by SmartThings
Receive notifications when anything happens in your home. -
Enhanced Auto Lock Door by Arnaud
Automatically locks a specific door after X minutes when closed and unlocks it when open after X seconds. -
Severe Weather Alert by SmartThings
Get a push notification when severe weather is in your area. -
Smart Alarm by geko@statusbits.com
A multi-zone virtual alarm panel, featuring customizable security zones. Setting of an alarm can activate sirens, turn on light switches, push notification and text message. Alarm is armed and disarmed simply by setting SmartThings location ‘mode’. -
Safe Watch by brian@bevey.org
Watch a series of sensors for any anomalies for securing a safe. -
Pushover Notify Me When by jim@concipio-solutions.com
Adds Pushover service to the ‘Notify Me When’ SmartApp -
Ready For Rain by brian@bevey.org
Warn if doors or windows are open when inclement weather is approaching. -
CO2 Vent by Brian Steere
Turn on a switch when CO2 levels are too high -
Dry the Wetspot by Scottin Pollock
Turns switch on and off based on moisture sensor input. -
Lock It At A Specific Time by Erik Thayer
Make sure a door is locked at a specific time. Option to add door contact sensor to only lock if closed. -
Jawbone Panic Button by Juan Risso
Holding the button on the Jawbone UP will send a text massage alerting someone of a potential emergency. -
Secure Night: Lock Up by SmartThings
Have your doors lock when you fall asleep
Lights & Switches
Control and automate Lights and Switches. -
Gentle Wake Up by SmartThings
Dim your lights up slowly, allowing you to wake up more naturally. -
Double Tap by SmartThings
Turn on or off any number of switches when an existing switch is tapped twice in a row. -
Switch Activates Home Phrase by Michael Struck
Ties a Hello, Home phrase to a switch’s state. Perfect for use with IFTTT. -
Switch Changes Mode by Michael Struck
Ties a mode to a switch’s state. Perfect for use with IFTTT. -
Alfred Workflow by SmartThings
Turn your SmartThings-powered lights and switches on/off directly from your Mac by launching the Alfred Workflow and entering “ST On” and “ST Off.” -
Mood Cube by SmartThings
Smart Home Ventilation by Michael Struck
Allows for setting up various schedule scenarios for turning on and off home ventilation switches. -
Color Coordinator by Michael Struck
Ties multiple colored lights to one specific light’s settings -
Vacation Lighting Director by Tim Slagle
Randomly turn on/off lights to simulate the appearance of a occupied home while you are away. -
Lighting Director by Time Slagle & Michael Struck
Control up to 4 sets (scenarios) of lights based on motion, door contacts and illuminance levels. -
Hall Light: Welcome Home by brian@bevey.org
Turn on the hall light if someone comes home (presence) and the door opens. -
Smart Light Timer by listpope@cox.net
Turns on a switch for X minutes, then turns it off. Unless, the switch is already on, in which case it stays on. If the switch is toggled while the timer is running, the timer is canceled. -
Lights Off with No Motion and Presence by Bruce Adelsman
Turn lights off when no motion and presence is detected for a set period of time. -
My Light Toggle by Jesse Silverberg
Toggle lights on/off with a motion sensor -
Turn Off With Motion by Kristopher Kubicki
Turns off a device if there is motion -
Monitor on Sense by Rachel Steele
Turn on Monitor when vibration is sensed -
Let There Be Dark! by Dooglave
Turn your lights off when a Contact Sensor is opened and turn them back on when it is closed, ONLY if the Lights were previouly on -
Bright When Dark And/Or Bright After Sunset by Arnaud
Turn ON light(s) and/or dimmer(s) when there’s movement and the room is dark with illuminance threshold and/or between sunset and surise. Then turn OFF after X minute(s) when the brightness of the room is above the illuminance threshold or turn OFF after X minute(s) when there is no movement. -
Comfort Sleep by SmartThings
When you get in bed, have your lights dim & have them turn off when you fall asleep.
Climate Control
Virtual Thermostat by SmartThings
Control a space heater or window air conditioner in conjunction with any temperature sensor, like a SmartSense Multi. -
Keep Me Cozy by SmartThings
Changes your thermostat settings automatically in response to a mode change. Often used with Bon Voyage, Rise and Shine, and other Mode Magic SmartApps to automatically keep you comfortable while you’re present and save you energy and money while you are away. -
Keep Me Cozy II by SmartThings
Works the same as Keep Me Cozy, but enables you to pick an alternative temperature sensor in a separate space from the thermostat. Focuses on making you comfortable where you are spending your time rather than where the thermostat is located. -
It’s Too Cold by SmartThings
Monitor the temperature and when it drops below your setting get a text and/or turn on a heater or additional appliance. -
Smart Humidifier by Sheikh Dawood
Turn on/off humidifier based on relative humidity from a sensor. -
Humidity Alert! by Brian Critchlow
Notify me when the humidity rises above or falls below the given threshold. It will turn on a switch when it rises above the first threshold and off when it falls below the second threshold. -
Thermostat Mode Director by Tim Slagle
Changes mode of your thermostat based on the temperature range of a specified temperature sensor and shuts off the thermostat if any windows/doors are open. -
Weather Underground PWS Connect by Andrew Mager
Connect your SmartSense Temp/Humidity sensor to your Weather Underground Personal Weather Station. -
Netatmo Connect by Brian Steere
Connect your netamo to display your local weather conditions and use it as a temp/humidity sensor. -
Whole House Fan by Brian Steere
Toggle a whole house fan (switch) when: Outside is cooler than inside, Inside is above x temp, Thermostat is off
Health & Fitness
Medicine Reminder by SmartThings
Set up a reminder so that if you forget to take your medicine (determined by whether a cabinet or drawer has been opened) by specified time you get a notification or text message. -
Sleepy Time by SmartThings
Use Jawbone sleep mode events to automatically execute Hello, Home phrases. Automatially put the house to bed or wake it up in the morning by pushing the button on your UP. -
Step Notifier by SmartThings
Use a step tracker device to track daily step goals and trigger various device actions when your goals are met!
Energy Management
Energy Alerts by SmartThings
Get notified if you’re using too much energy -
Energy Saver by SmartThings
Turn things off if you’re using too much energy -
Something Left Open by jim@concipio-solutions.com
Alerts you when a contact sensor has been left open for a specified number of minutes. Alerts are in the form of a user-defined message that is provided as a push notification to the user’s mobile device. Additional optional notifications can be sent by: (1) SMS message, (2) BEEPing a device, and/or (3) Pushover notification (http://pushover.net/). This is great for monitoring refrigerators, freezers, gates, doors, and windows. Save energy or keep your family and pets secure with this SmartApp. -
Thermostat Auto Off by dianoga7@3dgo.net
Automatically turn off thermostat when windows/doors open. Turn it back on when everything is closed up. -
Thermostat Window Check by brian@bevey.org
If your heating or cooling system come on, it gives you notice if there are any windows or doors left open, preventing the system from working optimally. -
Wattvision Manager by SmartThings
Monitor your whole-house energy use by connecting to your Wattvision account. -
Smart Windows by Eric Gideon
Compares two temperatures – indoor vs outdoor, for example – then sends an alert if windows are open (or closed!). If you don’t use an external temperature device, your zipcode will be used instead.
Presence & Modes
Working From Home by George Sudarkoff
If after a particular time of day a certain person is still at home, trigger a ‘Working From Home’ action. -
Smart Turn It On by sidjohn1@gmail.com
Turns on selected device(s) at a set time on selected days of the week only if a selected person is present and turns off selected device(s) after a set time. -
Routine Director by Tim Slagle
Monitor a set of presence sensors and activate routines based on whether your home is empty or occupied. Each presence status change will check against the current ‘sun state’ to run routines based on occupancy and whether the sun is up or down. -
Nobody Home by brian@bevey.org
When everyone leaves, change mode. If at least one person home, switch mode based on sun position. -
Shabbat and Holiday Modes by danielbarak@live.com
Changes the mode at candle lighting and back after havdalah. Uses the HebCal.com API to look for days that are shabbat or chag and pull real time candle lighting and havdalah times to change modes automatically
Music & Sounds
Sonos Control by SmartThings
Play or pause your Sonos when certain actions take place in your home. -
Sonos Mood Music by SmartThings
Plays a selected song or station. -
Sonos Notify with Sound by SmartThings
Play a sound or custom message through your Sonos when the mode changes or other events occur. -
Sonos Weather Forecast by SmartThings
Play a weather report through your Sonos when the mode changes or other events occur -
Talking Alarm Clock by Michael Struck
Control up to 4 waking schedules using a Sonos speaker as an alarm. -
ObyThing Music SmartApp by obycode
Use this free SmartApp in conjunction with the ObyThing Music app for your Mac to control and automate music and more with iTunes and SmartThings.
Social
Carpool Notifier by SmartThings
Send notifications to your carpooling buddies when you arrive to pick them up. If the person you are picking up is home, and has been for 5 minutes or more, they will get a notification when you arrive. -
Life360 (Connect) by SmartThings
Connect your Life360 account, and use the arrival or departure of people in your Life360 Circles at your home, to automatically trigger lights, locks, and much more. -
SquareHub by SquareHub
Connect your SmartThings devices with your SquareHub account to receive notifications right in your family feed!
More
Button Controller by SmartThings
Control devices with buttons like the Aeon Labs Minimote -
Photo Burst When… by SmartThings
Take a burst of photos and send a push notification when… -
Laundry Monitor by SmartThings
Sends a message and (optionally) turns on or blinks a light to indicate that laundry is done. -
Mail Arrived by SmartThings
Send a text when mail arrives in your mailbox using a SmartSense Multi on your mailbox door. Note: battery life may be impacted in cold climates. -
Has Barkley Been Fed? by SmartThings
Set up a schedule to be reminded to feed your pet. By placing a SmartSense Multi sensor on your pet food dispenser, you can receive a reminder if your pet has not been fed at the appropriate time. -
Coffee After Shower by Hans Wustrack
This app is designed simply to turn on your coffee machine while you are taking a shower. -
Door Knocker by brian@bevey.org
Alert if door is knocked, but not opened. -
Multi-Channel Control by SmartThings
Control individual endpoints of a multi-channel Z-Wave device as separate devices -
Logitech Harmony Trigger by SmartThings
Trigger Logitech Harmony Activities when certain actions take place in your home. -
Jenkins Notifier by aj.reitz@gmail.com
Turn off and on devices based on the state that your Jenkins Build is in. -
SAMI by Samsung Strategy and Innovation Center
Connect SAMI devices to SmartThings and reciprocally
More info about SAMI (AKA OpenCloud) can be found here
TO FIND ADDITIONAL COMMUNITY-CREATED SMARTAPPS
Unlike the list above, the following will require custom code installation through the IDE and are not officially supported, but the community will usually be happy to answer any questions in the appropriate topics.
https://community.smartthings.com/c/projects-stories/created-smart-apps
Thanks again!
