Evolve LSM-15 double tap
Two separate questions. In reverse order:
  1. the patent only applies to physical devices, not virtual.
  2. the Big Switch smartapp (in the Convenience section of MORE in Smart Setup in the ST mobile app) lets you slave any switch (virtual or physical) to another. It will turn off Switch B after Switch A turns off (assuming both are smart switches). It’s just a question of how long the lag is.
If both switches are physical and support direct association, you can slave one to the other with the Minimote. (One time setup.) after they are associated, this allows the master to tell the aux to turn on/off without having to go back to the hub first. Very fast. But means the hub may not know the status changed for awhile.
