Philio Door/Temp/Luinance Device Type
I’ve started messing with the device handler… lol!
I’m trying to use this app:
:cyclone:2. “Bright when dark and/or bright after sunset.” By Arnaud. Turn on lights when there’s movement and the room is dark and/or between sunset and sunrise. Then turn off after X minutes when the brightness of the room is above the illuminance threshhold OR turn off after X minutes of inactivity on the motion sensor. Requires a smart switch/bulb and a motion sensor. Can also use an optional lux sensor.
(found the description at List of all Officially Published Apps from the MORE category of Smart Setup in the Mobile App [deprecated])
it only accepts motion sensors… not contact sensors… if I knew where the app’s code is, I’d change it to suit my needs! lol! any ideas?
