Hub Firmware Release Notes - 18.18
You’re right, the local handler for Z-Wave switches isn’t populating the physical/digital field. We actually intended to deprecate and remove that functionality before this release, but that fell through the cracks. I apologize for the communication failure.
The reason we’re not continuing to support the physical/digital field is that it only works on a subset of switch devices, and even then it’s basically just a hack for most of those. For example, on most switches it doesn’t work through repeaters. We’ve also had issues with false positives.
For now, you’ll have to use a custom DTH to continue to get that functionality. I’m hopeful we can replace it with a capability like Button that more precisely represents the device’s behavior, but I don’t know what kind of priority that will have.
Fair enough, thank you for the informative answer. Although changes like these can tend to be annoying, being able to roll your own custom DTH and SmartApps are a testament to the flexibility and extensibility of the SmartThings platform. Keep up the good work ST!
Can you please point me to where I can find the prior version of these DTHs (that continue to report the physical/digital field, prior to yesterdays rollout) ?
Do the latest versions in the SmartThingsPublic github repo accurately report the physical / digital field? They seem to be (in glancing at the code), but I just want to be sure:
Z-Wave Switch:
Z-Wave Relay:
@duncan, do I read correctly that local support for Z-Wave switches is being removed? That meaning Smart Lights automations switching security lighting using Z-Wave switches will fail to execute in the absence of internet connectivity to the ST cloud? :thinking:
Boy, I sure hope not…
With my Iris motion sensors, I had to click ‘Check now’ in the device portion of the IDE (where it shows the firmware level) before it eventually showed that a firmware update was available. I notice that of the 5 Iris motion sensors I have, one does continue to report its original 67% battery level that it had before the update; the other four went to 100%. Odd.
And now, 24+ hours later, a bit after posting a message on here, suddenly my triggers start working again… Seems like quite a coincidence…
Those should work.
I created a new DTH for my switches by just using one of the Z-Wave Switch templates (From Template, then selected the 2nd Z-Wave Switch) … and now I have the interactions back in the logs, after I updated my GE switches to use the newly created DTH. Of course, now execution location is now in the cloud.
So you changed core api functionality without even mentioning it in the release notes?
Nope, not at all. The code supporting these switches (and other locally running devices) is different, but we only plan to expand the set of devices that are supported locally over time – expect to see several more devices supported locally with subsequent hub releases (including 19.x).
Like in hub v3 or rather v2 running on future firmware?
Future firmware releases.
I believe you mean 19.x not .19… correct?
Thanks for the clarification, Paul! This is one of those times I’m happy I was wrong :yum:
And new locally supported devices are always welcome!
If you look at the firmware version in app or the IDE you’ll see 000.018.00021. So technically 000.019.x is the next major firmware version.
Hmm, you’re on 18.20 which is the beta so you didn’t get an update yesterday. If you reach out to support we can help you out.
I’m really looking forward to running custom DH and SmartApps on local :slight_smile:
That’s encouraging. How about custom device handlers and smart apps as well? Can you see these being migrated to local control?
Has anyone had problems with a z-wave repair since the backend update?
When I try to run it, after 1 second it shows as finished (twice) and nothing else
I’ve tried running it both through the ios app and the ide
I’ll do that this morning. I think it’s an issue with Hue_B_Smart. I’m still trying to debug it on my end before I bother you guys. :slight_smile:
Any chance the update killed the double tap smart app?
It will depend on which device type handler you are using. See post 527 above.
