I am having some issues with setting up a Samsung SmartThings Hub v2 2015 STH-ETH-250
Basically it has no firmware but is connecting fine to the SmartThings app it also is not factory resetting the yellow light never blinks or turns solid.
In the Samsung SmartThings IDE when going into the hub the firmware is blank.
Any help would be great!
Edit: Basically this is all coming up because I needed to connect a ZWave Lock and the SmartThings hub is not even finding it or acting like it’s trying.
in addition to @jkp 's post above, we had performed a factory reset a while back but were a bit too impatient on the lights changing color, so we had jumped the gun and reset again. The solution was to assure it was connected via LAN and that we gave it more time to cycle through the various stages.
Hi thanks for help! Yes I tried removing batteries and then doing the factory reset but I had the same results. After plugging in the power while holding down the tiny red button on the back the first light that comes up is a solid blue then after a while it goes red then the lights disappear entirely I have held it down past that for easily 60+ seconds and it just cycles through those same colors.
Sorry that is the same thing the tiny pinhole next to the power that you have to use a close pin to reach. I have tried a couple different methods of factory resetting but none produce that yellow light. Nothing online that I have seen have shown a similar situation of it not showing any firmware so I’m concerned about that
You may want to contact ST support about missing info in the Advanced Web App.
The missing yellow or blinking yellow has been reported by a few users in past few weeks. I haven’t seen anything about a resolution. Is it an app issue or back end issue is unknown.
If you don’t get it resolved and you recently purchased it… you may want to consider returning it and getting your money back.
That clears up a few things. Probably safe to say you will be unable to use that hub but contact ST support first. The reason is… ST made a change in either 2017/18 (forget the exact year) where they sent out a firmware that adjusted hub boot up and also pointed the hubs to a new server that hubs reach out to for firmware updates. If your hub never received that one firmware update…. It has no way to contact the new server and the old one is no longer available at this point. Yikes!
That actually makes sense that is why I was concerned about the no firmware and no real logic happening in the hub. I will contact ST support and let everyone know if they were able to help!
if you are going to stay with the ST platform… I would recommend the Aeotec Smart Home Hub for $130 at Amazon. There is another vendor that offers it for around the same price. As I was pointing out to someone else… don’t get the ST v3 hub as the price will likely be $200 or higher if going through Amazon Marketplace. The Aeotec and ST v3 hub are basically the same hub but with a different branding.
The ST Station is not an option has it does not have a z-wave radio.
With Prime Dy set to arrive in July, it “might” be possible to get it at a lower price. That is you are willing to wait for 2 months at the time of this post.
Just curious if you got any further with possibly getting this to work? Wish I saw this thread earlier, but am in a similar boat. Wonder if old v2 hubs are just lemons at this point if they didn’t receive the update.
I did. I have the same issue where I can’t do the factory reset to get the yellow light. I supposedly have a ticket open with them, but doubt anything will result from it if this issue wasn’t previously resolved.
