Sweet, got it!
Great forum here
Edit:
And now it also shows under the already set automations. This is where I was looking and couldn’t find it.
Edit 2: Gonna set everything up tomorrow so I’ll give it a good testrun then.
Sweet, got it!
Great forum here
Edit:
Depending on which dimmer or light bulb you are going to use, you can use a zigbee light multifunction Mc edge driver for this same functionality.
If you want tomorrow I’ll explain it now I’m going to sleep
It works! As I’m using a dual white led strip I have to disable the “change color” option and it gives a “network error” when I change the name but as I don’t have to change it anymore it should work just fine now!
But will look into the edge madness as it’s going that way anyhow.
Can’t find anything like this. Does this still work, as the Groovy IDE has been discontinued?
tap on Menu and look in Labs if you are referring to Gentle Wakeup.
Meh, don’t have the labs… I live in Europe
Same problem here, are Labs only available in the US?
Same here (Netherlands).
You can use a Edge driver but it’s complicated because it can’t use gentle wake up next to other settings. I still have to look into it to see how I can change the settings outside of the wake up alarm.
