Fibaro Switch 2 does not work
Hi,
I have a Smartthings Hub and Fibaro dimmers and switches. All the dimmers are working perfectly fine (plug’n’play), but none of the switches.
I have a Toggle Switch with spring (seems to be defined as a Momentary switch).I have changed the “SwitchType” to “Momentary switch”. The manual switch at the wall is working fine. I may also turn of the lights by the app, but it takes a lot of time and the status in the app does not update.
From the Fibaro Manual it seems like I have to change “Parameter 20 to 0”, but I cannot find out how to do so with Smartthings.
Any suggestions?
The type of switch is changed in device settings, 3-point menu, above to the right.
I think I understand that it already changed to momentary?
If it takes time to update the information in the app, it is because the dth is executed in the cloud and sometimes or days It is slow to update state. You have to press the switch again in the app to update the status.
There is an edge beta zwave switch driver in the smartthings beta channel that incorporates the fibaro switch.
This run locally on the hub. You can try to see if it works.
I tried the double switch2 fibaro, but channel 2 was not working well.
The single switch may work fine.
I found this DeviceHandler I found for FGS 213 works for me.
  • Copyright 2017 Eric Maycock
  • Licensed under the Apache License, Version 2.0 (the “License”); you may not use this file except
  • in compliance with the License. You may obtain a copy of the License at:
  •  http://www.apache.org/licenses/LICENSE-2.0
  • Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
  • on an “AS IS” BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
  • for the specific language governing permissions and limitations under the License.
  • Fibaro Single Switch 2 FGS-213
  • Author: Eric Maycock (erocm123)
metadata {
definition (name: “Fibaro Single Switch 2 FGS-213”, namespace: “erocm123”, author: “Eric Maycock”, vid:“generic-switch-power-energy”) {
capability “Sensor”
capability “Actuator”
capability “Switch”
capability “Polling”
capability “Configuration”
capability “Refresh”
capability “Energy Meter”
capability “Power Meter”
capability “Health Check”
capability “Button”
capability “Holdable Button”
command "reset"
fingerprint mfr: "010F", prod: "0403", model: "2000", deviceJoinName: "Fibaro Single Switch 2"
fingerprint mfr: "010F", prod: "0403", model: "1000", deviceJoinName: "Fibaro Single Switch 2"
fingerprint deviceId: "0x1001", inClusters:"0x5E,0x86,0x72,0x59,0x73,0x22,0x56,0x32,0x71,0x98,0x7A,0x25,0x5A,0x85,0x70,0x8E,0x60,0x75,0x5B"
simulator {
tiles(scale: 2){
multiAttributeTile(name:"switch", type: "lighting", width: 6, height: 4, canChangeIcon: true){
		tileAttribute ("device.switch", key: "PRIMARY_CONTROL") {
		   attributeState "off", label:'${name}', action:"switch.on", icon:"st.switches.switch.off", backgroundColor:"#ffffff", nextState:"turningOn"
		   attributeState "on", label:'${name}', action:"switch.off", icon:"st.switches.switch.on", backgroundColor:"#00a0dc", nextState:"turningOff"
		   attributeState "turningOff", label:'${name}', action:"switch.on", icon:"st.switches.switch.off", backgroundColor:"#ffffff", nextState:"turningOn"
		   attributeState "turningOn", label:'${name}', action:"switch.off", icon:"st.switches.switch.on", backgroundColor:"#00a0dc", nextState:"turningOff"
        tileAttribute ("statusText", key: "SECONDARY_CONTROL") {
       		attributeState "statusText", label:'${currentValue}'
valueTile("power", "device.power", decoration: "flat", width: 2, height: 2) {
		state "default", label:'${currentValue} W'
valueTile("energy", "device.energy", decoration: "flat", width: 2, height: 2) {
		state "default", label:'${currentValue} kWh'
standardTile("refresh", "device.switch", inactiveLabel: false, decoration: "flat", width: 2, height: 2) {
	state "default", label:"", action:"refresh.refresh", icon:"st.secondary.refresh"
standardTile("configure", "device.needUpdate", inactiveLabel: false, decoration: "flat", width: 2, height: 2) {
        state "NO" , label:'', action:"configuration.configure", icon:"st.secondary.configure"
        state "YES", label:'', action:"configuration.configure", icon:"https://github.com/erocm123/SmartThingsPublic/raw/master/devicetypes/erocm123/qubino-flush-1d-relay.src/configure@2x.png"
standardTile("reset", "device.energy", inactiveLabel: false, decoration: "flat", width: 2, height: 2) {
	state "default", label:'reset kWh', action:"reset"
main(["switch"])
details(["switch",
         "power","energy","reset",
         "refresh","configure"])
preferences {
input description: “Once you change values on this page, the corner of the “configuration” icon will change orange until all configuration parameters are updated.”, title: “Settings”, displayDuringSetup: false, type: “paragraph”, element: “paragraph”
generate_preferences(configuration_model())
def result =
def cmd = zwave.parse(description)
if (cmd) {
result += zwaveEvent(cmd)
//log.debug “Parsed ${cmd} to ${result.inspect()}”
} else {
log.debug “Non-parsed event: ${description}”
def statusTextmsg = ""
result.each {
    if ((it instanceof Map) == true && it.find{ it.key == "name" }?.value == "power") {
        statusTextmsg = "${it.value} W ${device.currentValue('energy')? device.currentValue('energy') : "0"} kWh"
    if ((it instanceof Map) == true && it.find{ it.key == "name" }?.value == "energy") {
        statusTextmsg = "${device.currentValue('power')? device.currentValue('power') : "0"} W ${it.value} kWh"
if (statusTextmsg != "") sendEvent(name:"statusText", value:statusTextmsg, displayed:false)
return result
def zwaveEvent(physicalgraph.zwave.commands.basicv1.BasicReport cmd)
log.debug “BasicReport $cmd”
def zwaveEvent(physicalgraph.zwave.commands.basicv1.BasicSet cmd, ep=null) {
logging(“BasicSet: $cmd : Endpoint: $ep”)
def event
if (!ep) {
event = [createEvent([name: “switch”, value: cmd.value? “on”:“off”])]
return event
def zwaveEvent(physicalgraph.zwave.commands.switchbinaryv1.SwitchBinaryReport cmd, ep=null)
logging(“SwitchBinaryReport: $cmd : Endpoint: $ep”)
def event
if (!ep) {
return event
def zwaveEvent(physicalgraph.zwave.commands.meterv3.MeterReport cmd, ep=null) {
logging(“MeterReport: $cmd : Endpoint: $ep”)
def result
def cmds =
if (cmd.scale == 0) {
result = [name: “energy”, value: cmd.scaledMeterValue, unit: “kWh”]
} else if (cmd.scale == 1) {
result = [name: “energy”, value: cmd.scaledMeterValue, unit: “kVAh”]
} else {
result = [name: “power”, value: cmd.scaledMeterValue, unit: “W”]
if (!ep) {
return createEvent(result)
def zwaveEvent(physicalgraph.zwave.commands.associationv2.AssociationReport cmd) {
log.debug “AssociationReport $cmd”
if (zwaveHubNodeId in cmd.nodeId) state.“association${cmd.groupingIdentifier}” = true
else state.“association${cmd.groupingIdentifier}” = false
log.debug “Unhandled event $cmd”
// This will capture any commands not handled by other instances of zwaveEvent
// and is recommended for development so you can see every command the device sends
return createEvent(descriptionText: “${device.displayName}: ${cmd}”)
def zwaveEvent(physicalgraph.zwave.commands.configurationv2.ConfigurationReport cmd) {
update_current_properties(cmd)
logging("${device.displayName} parameter ‘${cmd.parameterNumber}’ with a byte size of ‘${cmd.size}’ is set to ‘${cmd2Integer(cmd.configurationValue)}’")
def refresh() {
def cmds =
cmds << zwave.associationV2.associationGet(groupingIdentifier:1)
cmds << zwave.associationV2.associationGet(groupingIdentifier:2)
cmds << zwave.associationV2.associationGet(groupingIdentifier:3)
cmds << zwave.associationV2.associationGet(groupingIdentifier:4)
cmds << zwave.associationV2.associationGet(groupingIdentifier:5)
cmds << zwave.switchBinaryV1.switchBinaryGet()
cmds << zwave.meterV2.meterGet(scale: 0)
cmds << zwave.meterV2.meterGet(scale: 2)
secureSequence(cmds, 1000)
def reset() {
def cmds =
cmds << zwave.meterV2.meterReset()
def ping() {
refresh()
def zwaveEvent(physicalgraph.zwave.commands.manufacturerspecificv2.ManufacturerSpecificReport cmd) {
def msr = String.format("%04X-%04X-%04X", cmd.manufacturerId, cmd.productTypeId, cmd.productId)
log.debug “msr: $msr”
updateDataValue(“MSR”, msr)
def poll() {
refresh()
def configure() {
state.enableDebugging = settings.enableDebugging
logging(“Configuring Device For SmartThings Use”)
def cmds =
cmds = update_needed_settings()
if (cmds != []) secureSequence(cmds)
def zwaveEvent(physicalgraph.zwave.commands.centralscenev1.CentralSceneNotification cmd) {
logging(“CentralSceneNotification: $cmd”)
logging(“sceneNumber: $cmd.sceneNumber”)
logging(“sequenceNumber: $cmd.sequenceNumber”)
logging(“keyAttributes: $cmd.keyAttributes”)
buttonEvent(cmd.keyAttributes + 1, (cmd.sceneNumber == 1? "pushed" : "held"))
def buttonEvent(button, value) {
logging(“buttonEvent() Button:$button, Value:$value”)
createEvent(name: “button”, value: value, data: [buttonNumber: button], descriptionText: “$device.displayName button $button was $value”, isStateChange: true)
  • Triggered when Done button is pushed on Preference Pane
    def updated()
    logging(“updated() is being called”)
    sendEvent(name: “checkInterval”, value: 2 * 30 * 60 + 2 * 60, displayed: false, data: [protocol: “zwave”, hubHardwareId: device.hub.hardwareID])
    def cmds = update_needed_settings()
    sendEvent(name:“needUpdate”, value: device.currentValue(“needUpdate”), displayed:false, isStateChange: true)
    if (cmds != ) response(secureSequence(cmds))
def on() {
secureSequence([
zwave.basicV1.basicSet(value: 0xFF)
def off() {
secureSequence([
zwave.basicV1.basicSet(value: 0x00)
private secure(physicalgraph.zwave.Command cmd) {
zwave.securityV1.securityMessageEncapsulation().encapsulate(cmd).format()
private secureSequence(commands, delay=1500) {
delayBetween(commands.collect{ secure(it) }, delay)
private encap(cmd, endpoint) {
if (endpoint) {
zwave.multiChannelV3.multiChannelCmdEncap(destinationEndPoint:endpoint).encapsulate(cmd)
} else {
cmd
def zwaveEvent(physicalgraph.zwave.commands.securityv1.SecurityMessageEncapsulation cmd) {
def encapsulatedCommand = cmd.encapsulatedCommand([0x20: 1, 0x32: 3, 0x25: 1, 0x98: 1, 0x70: 2, 0x85: 2, 0x9B: 1, 0x90: 1, 0x73: 1, 0x30: 1, 0x28: 1, 0x2B: 1]) // can specify command class versions here like in zwave.parse
if (encapsulatedCommand) {
return zwaveEvent(encapsulatedCommand)
} else {
log.warn “Unable to extract encapsulated cmd from $cmd”
createEvent(descriptionText: cmd.toString())
def generate_preferences(configuration_model)
def configuration = parseXml(configuration_model)
configuration.Value.each
    switch(it.@type)
        case ["byte","short","four"]:
            input "${it.@index}", "number",
                title:"${it.@label}\n" + "${it.Help}",
                range: "${it.@min}..${it.@max}",
                defaultValue: "${it.@value}",
                displayDuringSetup: "${it.@displayDuringSetup}"
        break
        case "list":
            def items = []
            it.Item.each { items << ["${it.@value}":"${it.@label}"] }
            input "${it.@index}", "enum",
                displayDuringSetup: "${it.@displayDuringSetup}",
                options: items
        break
        case "decimal":
           input "${it.@index}", "decimal",
        break
        case "boolean":
           input "${it.@index}", "boolean",
                title: it.@label != "" ? "${it.@label}\n" + "${it.Help}" : "" + "${it.Help}",
        break
        case "paragraph":
           input title: "${it.@label}",
                description: "${it.Help}",
                type: "paragraph",
                element: "paragraph"
        break
def update_current_properties(cmd)
def currentProperties = state.currentProperties ?: [:]
currentProperties."${cmd.parameterNumber}" = cmd.configurationValue
if (settings."${cmd.parameterNumber}" != null)
    if (convertParam(cmd.parameterNumber, settings."${cmd.parameterNumber}") == cmd2Integer(cmd.configurationValue))
        sendEvent(name:"needUpdate", value:"NO", displayed:false, isStateChange: true)
    else
        sendEvent(name:"needUpdate", value:"YES", displayed:false, isStateChange: true)
state.currentProperties = currentProperties
def update_needed_settings()
def cmds =
def configuration = parseXml(configuration_model())
def isUpdateNeeded = "NO"
if(!state.association1){
   logging("Setting association group 1")
   cmds << zwave.associationV2.associationRemove(groupingIdentifier: 1, nodeId: [])
   cmds << zwave.associationV2.associationSet(groupingIdentifier:1, nodeId:zwaveHubNodeId)
sendEvent(name:"numberOfButtons", value:"5")
    if ("${it.@setting_type}" == "zwave"){
        if (currentProperties."${it.@index}" == null)
            isUpdateNeeded = "YES"
            logging("Current value of parameter ${it.@index} is unknown")
            cmds << zwave.configurationV1.configurationGet(parameterNumber: it.@index.toInteger())
        else if (settings."${it.@index}" != null && cmd2Integer(currentProperties."${it.@index}") != convertParam(it.@index.toInteger(), settings."${it.@index}"))
            logging("Parameter ${it.@index} will be updated to " + convertParam(it.@index.toInteger(), settings."${it.@index}"))
            def convertedConfigurationValue = convertParam(it.@index.toInteger(), settings."${it.@index}")
            cmds << zwave.configurationV1.configurationSet(configurationValue: integer2Cmd(convertedConfigurationValue, it.@byteSize.toInteger()), parameterNumber: it.@index.toInteger(), size: it.@byteSize.toInteger())
sendEvent(name:"needUpdate", value: isUpdateNeeded, displayed:false, isStateChange: true)
return cmds
def convertParam(number, value) {
def parValue
switch (number){
case 28:
parValue = (value == “true” ? 1 : 0)
parValue += (settings.“fc_2” == “true” ? 2 : 0)
parValue += (settings.“fc_3” == “true” ? 4 : 0)
parValue += (settings.“fc_4” == “true” ? 8 : 0)
break
case 29:
parValue += (settings.“sc_2” == “true” ? 2 : 0)
parValue += (settings.“sc_3” == “true” ? 4 : 0)
parValue += (settings.“sc_4” == “true” ? 8 : 0)
break
default:
parValue = value
break
return parValue.toInteger()
private def logging(message) {
if (state.enableDebugging == null || state.enableDebugging == “true”) log.debug “$message”
  • Convert 1 and 2 bytes values to integer
    def cmd2Integer(array) {
switch(array.size()) {
case 1:
array[0]
break
case 2:
((array[0] & 0xFF) << 8) | (array[1] & 0xFF)
break
case 3:
((array[0] & 0xFF) << 16) | ((array[1] & 0xFF) << 8) | (array[2] & 0xFF)
break
case 4:
((array[0] & 0xFF) << 24) | ((array[1] & 0xFF) << 16) | ((array[2] & 0xFF) << 8) | (array[3] & 0xFF)
break
def integer2Cmd(value, size) {
switch(size) {
case 1:
[value]
break
case 2:
def short value1 = value & 0xFF
def short value2 = (value >> 8) & 0xFF
[value2, value1]
break
case 3:
def short value3 = (value >> 16) & 0xFF
[value3, value2, value1]
break
case 4:
def short value4 = (value >> 24) & 0xFF
[value4, value3, value2, value1]
break
private command(physicalgraph.zwave.Command cmd) {
if (state.sec && cmd.toString() != "WakeUpIntervalGet()") {
} else {
	cmd.format()
private commands(commands, delay=1000) {
delayBetween(commands.collect{ command(it) }, delay)
def zwaveEvent(physicalgraph.zwave.commands.crc16encapv1.Crc16Encap cmd) {
def versions = [0x31: 5, 0x30: 1, 0x9C: 1, 0x70: 2, 0x85: 2]
def version = versions[cmd.commandClass as Integer]
def ccObj = version ? zwave.commandClass(cmd.commandClass, version) : zwave.commandClass(cmd.commandClass)
def encapsulatedCommand = ccObj?.command(cmd.command)?.parse(cmd.data)
def configuration_model()
The device will return to the last state before power failure.
0 - the Dimmer 2 does not save the state before a power failure, it returns to the “off” position
1 - the Dimmer 2 restores its state before power failure
Range: 0~1
Default: 1 (Previous State)
This parameter allows you to choose the operating mode for the 1st channel controlled by the S1 switch.
Range: 0~5
Default: 0 (Standard)
This parameter determines how the device in timed mode reacts to pushing the switch connected to the S1 terminal.
Range: 0~2
Default: 0 (Cancel)
This parameter allows to set time parameter used in timed modes.
Range: 0~32000 (0.1s, 1-32000s)
Default: 50
This parameter allows to set time of switching to opposite state in flashing mode.
Range: 1~32000 (0.1s-3200.0s)
Default: 5 (0.5s)
Choose between momentary and toggle switch.
Range: 0~2
Default: 2 (Toggle)
This parameter determines how the device will react to General Alarm frame.
Range: 0~3
Default: 3 (Flash)
This parameter determines how the device will react to Flood Alarm frame.
Range: 0~3
Default: 2 (OFF)
This parameter determines how the device will react to CO, CO2 or Smoke frame.
Range: 0~3
Default: 3 (Flash)
This parameter determines how the device will react to Heat Alarm frame.
Range: 0~3
Default: 1 (ON)
This parameter allows to set duration of flashing alarm mode.
Range: 1~32000 (1s-32000s)
Default: 600 (10 min)
The parameter defines the power level change that will result in a new power report being sent. The value is a percentage of the previous report.
Range: 0~100 (1-100%)
Default: 10
Parameter 51 defines a time period between consecutive reports. Timer is reset and counted from zero after each report.
Range: 0~120 (1-120s)
Default: 10
Energy level change which will result in sending a new energy report.
Range: 0~32000 (0.01-320 kWh)
Default: 100
This parameter determines in what time interval the periodic power reports are sent to the main controller.
Range: 0~32000 (1-32000s)
Default: 3600
This parameter determines in what time interval the periodic energy reports are sent to the main controller.
Default: 3600
Send scene ID on single press
Send scene ID on double press
Send scene ID on tripple press
Send scene ID on hold and release
Toggle Mode
1 pushed - S1 1x toggle
4 pushed - S1 2x toggle
5 pushed - S1 3x toggle
1 held - S2 1x toggle
4 held - S2 2x toggle
5 held - S2 3x toggle
Momentary Mode
1 pushed - S1 1x click
2 pushed - S1 release
3 pushed - S1 hold
4 pushed - S1 2x click
5 pushed - S1 3x click
1 held - S2 1x click
2 held - S2 release
3 held - S2 hold
4 held - S2 2x click
5 held - S2 3x click
Thanks. I now understand that the “SwitchType” is the same as parameter 20.
I tried out your device handler Magnus, but it failed somehow. However, I tried to use the “integrated” device handler for the Fibaro Double Switch and it worked. Not sure if this is a long-term solution, but as of now, it works perfectly to me.
Thanks again guys!
There is a stock edge driver, which is supposed to replace the groovy DTH of the zwave fibaro double switch and others devices
I have tried it and it has problems working channel 2, among others, but it is already reported to be fixed.
this is the thread in case you want to mark it to keep track of when it is fixed.
Great, thanks again. The integrated Fibaro Double Switch device handler added a “(CH2)” component, so that was not a good solution anyway. But the generic Z-Wave Switch device handler seems to work fine.
Not sure, but as I only have the single switch, I dont think your problem applies to me.
  - id: "010F/0403"
    deviceLabel: Fibaro Single Switch
    manufacturerId: 0x010F
    productType: 0x0403
    deviceProfileName: switch-button-power-energy
Well, in the same Beta smartthings driver is the Fibaro Single switch.
Simple devices are easier to work well and locally in your Hub
If you want to try this is the thread and link to the channel smartthings beta drivers. Now have many drivers
There are now more drivers available than what is listed in the post
