(EDGE Driver-Mc) Zigbee switch MC, Zigbee switch power MC, Zigbee multi switch and child MC
MARIANO hello and thank you for all the help. I cannot find, could u please add this simple tuya button, it has single. Double, held actions.
Thanks so much for these drivers!
I just installed a Zigbee enbrighten 43080 dimmer in-wall switch. I was hoping these drivers would allow me to trigger actions from double tap up or down. However, after switching to your edge driver, there doesn’t appear to be an option for double tap.
Am I doing something wrong? Is it possible to add double tap to the driver? Is there another driver I should be using?
Hi,
I do not have any driver for this device that allows double tap.
maybe the drivers @philh30 or @csstup can help
Phil’s Z-Wave GE/Jasco driver supports double tap, however, I don’t see any Zigbee drivers in his repo. Same with Corey’s.
Hello, I bought Avatto Smart Switch in Aliexpress on this link.
I bought right thing that is zigbee 220V US.
But I cannot control each button on smartthings app.
So I have tried to use Mariano’s Edge Drivers, etc.
But I cannot find edge driver for my switch.
For Mariano’s Edge Drivers, I tried to use Thing Mc.
But Smartthings app cannot load my switch’s information.
So, can you help for my device of which manufacturer code is _TZ3000_sgeijniq ?
The device id is 836bd5df-f5e0-4ff6-9ca7-a52c9c8db10b, and Model is TS0013.
Hi,
Added to this driver version
You need install this driver version
uninstall device and reinstall device
You do not perform a driver change
 Name         Zigbee Multi Switch and Child Mc
 Version      2024-03-12T18:44:43.695603867
- id: "Avatto/_TZ3000_sgeijniq"
    deviceLabel: Avatto TS0013 Switch
    manufacturer: _TZ3000_sgeijniq
    model: TS0013
    deviceProfileName: three-switch
Hello Mariano,
I just bought a ZigBee3.0 Dual USB Wireless Socket Plug from Moes (SKU: ZP-LZ-FR2U-WH-EN).
The default zigbee switch driver in Smartthings does not allow to control separately the main plug and the USB outlets.
I guess your driver should be the answer to my need, however I could not find my device in the fingerprints :
  • the model is : TS011F
  • the manufacturer code is : _TZ3000_2xlvlnez
    Would it be possible to add this device to your driver?
    Many thanks & kind regards.
Hi @Ph_D
I need more info if this device, endpoints and clusters.
Please, pair with zigbee thing mc to see this info
@Mariano_Colmenarejo
Thank you very much for the quick response.
Here is what I have after pairing my device with zigbee thing mc
Did something change recently? I noticed my SmartThings app icon looks different now. So the app must have updated. But now, all my energy monitoring devices, that use these drivers, no longer show an option for days or hours on the Energy meter. It is only showing the total energy used. It is no longer showing me the historical data.
The Power meter still shows an option for hours and days. But that doesn’t do much good for me since the Energy meter used to show the kWh used daily or hourly. A Cumulative meter isn’t very useful for me when I need to see how many kWh a device using daily or hourly.
So was this some change SmartThings made? I am seeing this from my two v2 hubs that I have in use. With all my Zigbee and Zwave Energy monitors. I have several z-wave and around three dozen Zigbee energy monitors. Prior to the SmartThings change, the hourly and daily kWh historical data was available on all of those devices.
Hi,
 Version      2024-03-16T09:36:22.152152743
- id: "_TZ3000_2xlvlnez/TS011F"
    deviceLabel: TS011F Two Outlet
    manufacturer: _TZ3000_2xlvlnez
    model: TS011F
    deviceProfileName: two-outlet
Hello @Mariano_Colmenarejo
Thank you very much.
After deleting and reinstalling the device several times, the standard Smartthings driver β€œzigbee switch” is always used by default. Therefore I need to perform a manual driver change to select your driver instead. I can confirm I am using the latest version.
On the device page (see screenshot below), switch2 is greyed out. I get a message that disappears quickly saying that the device does not have all its status information up-to-date yet.
On the web dashboard (advanced view), in the device page, I am able to switch switch2 on and off using the commands.
Hi @Mariano_Colmenarejo, thanks for the great job you’re doing with the drivers.
I have a Moes smart touch switch with your Zigbee multi switch and child MC driver.
The status of the led indicator turns on when I switch the light on, I need the opposite, the led indicator should be on when the lights are off.
Could you please implement that function?
Thank you very much
It is a problem reported by other users, a custom driver should have priority over a stock driver with cluster matches.
I think that if you wait a while, half an hour, the cache or whatever they have implemented in the hub will allow everything to work.
It’s a nightmare, the undocumented and meaningless changes that make and ruin something every day, it’s unbearable!!!
You were perfectly right, now all settings are activated and all commands work perfectly.
Congratulations and thanks again for your great help to the Smartthings user community.
Yes, it must be one of the many changes in new App versiΓ³n
@Mariano_Colmenarejo drivers don’t generally work with devices using the Tuya EF00 cluster. You need to use the following driver.
can you add this 6 way multi switch, too?
thank u very much!
Why did you delete and repeat the question if you already had an answer right in the previous post?
If it says EF00 in the cluster sections you’ll have to look for other drivers like the ones mentioned by Paul.
oh… I see!
sorry for that.
I just saw the post that Mariano forgot a post which is on another driver,
so i think he forgot mine, too.
Thank you for help!
