[ST Edge/Beta] Zigbee dimmer driver (supports MOES)
Supported devices
The driver supports
  • Moes MS-105Z Dimmer
Moes MS-105Z Dimmer
Single gang Zigbee dimmer, Max Power 150W. Requires Neutral wire.
Implemented with Tuya private cluster.
To pair the device, enter the pairing mode, then switch it on/off 10 times.
The detailed view contains
  • Switch (to turn on/off)
  • Dimmer (switch level)
  • Preset button (Sets dimmer to predefined switch level. The predefined value can be changed in settings)
It also shows signal strength.
Channel
https://api.smartthings.com/invitation-web/accept?id=b119aed9-4083-46bc-bc16-584b9d738abe
Please install
Zigbee Dimmer Driver [YG]
Cheers,
Yakov
Hello,
As of today my zigbee dimmer has issue:
Smartthings app does not switch on/off, but
When i use phisycal switch the app updates the status.
Can you help?
Dusan
Hi @dusanhauko ,
Could you please provide the log from the driver, that capture switching on/off from the app?
Hey,
I did reset and repair and it’s working ok. Thanks anyway for good driver :wink:
hello, I also have the same problem, from the app it no longer works but from physical button it goes, if reset works for a few days and then the same problem returns
@EnrCol ,
Could you please provide the log from the driver?
can you tell me where I find the logs? thank you
@EnrCol , please see instructions for collecting logs in the following link.
Hi @ygerlovin
Do you think your driver will work with MOES 2 Gang ZigBee Dimmer Module as well?
@Raboo
2 gangs are not supported. I’m looking for volunteers to provide logs for it
@ygerlovin ok, I am thinking of buying one. If I do I will provide logs then.
Hi,
This driver can handle this device?
  • zigbeeNodeType: ROUTER
  • application: 42
  • endpointId: 01
  • manufacturer: _TZE200_dfxkcots
  • model: TS0601
raw: 01 0104 0051 01 04 0000 0004 0005 EF00 02 0019 000A
It’s a Moes Smart Dimmer Switch
Hi @Pyrylamo ,
Unfortunately, only MS-105Z is supported
The product’s model number in your post is not the same as the one on the manufacturers website. First I was confused and thought that this product might not be sold anymore. But if I compare the serial number on your picture with the one that moes sells it seems to be this one, right?
They say that the model name is “ZM-105-MS”. Would be nice if you could confirm if it’s the right one. A link to the product site in your post would be awesome. And by the way: thank you very much for the driver :slight_smile:
Hi
I have 2 gang dimmer
model is 105bz
please check this post that I have written
@BluePicture ,
I don’t have this device, I wrote the driver for someone else.
So I provided all the info I was given and I have no way to validate it.
Sorry if it caused confusion
Hi @Chryth.jin ,
I find it very challenging to add support for multi component devices without having a device to test against.
I’m sorry, I won’t be able to help you.
Hi @ygerlovin
Do you have a working Edge driver for a Tuya switch TS0601 that uses EF00? (_TZE200)
(No dimmer, no parent/child… Just a switch)
If so, would you be so kind as to share the code please?
Thank you
thanks for relpy~!
Hi @ygerlovin
Do you have a driver for this device? If not, is it possible to create one?
Tuya zigbee human body sensor radar detector, real-time microwave motion.
Sensor Presensa
