With the ZigBee switch edge driver, only the top of the four switches works. Please add it.
Hi @wannaseok and @Eitan_Fitusi
Added to this driver version
You need install this driver version
uninstall device and reinstall device
You do not perform a driver change
βββββββββββββββββββββββββββββββββββββββββββββββββββ
Name Zigbee Multi Switch and Child Mc
Version 2024-03-27T20:33:28.096258365
- id: "_TZ3000_mrduubod/TS0014"
deviceLabel: TS0014 Switch
manufacturer: _TZ3000_mrduubod
model: TS0014
deviceProfileName: four-switch
- id: "TS0003/_TZ3000_avky2mvc"
deviceLabel: TS0003 AVATTO Switch
manufacturer: _TZ3000_avky2mvc
model: TS0003
deviceProfileName: three-switch
Iβm updating from @Eitan_Fitusi
deviceLabel: TS0003 AVATTO Switch"
This device is working fine with no issues. Thank you very much for adding
Hello,
This device use Tuya EF00 cluster and you need use this driver
I donβt have any driver that works with that device, go to the thread that I told you in the previous post about devices that use the EF00 cluster
Firstly You must install zigbee thing mc⦠And send picture with information about this device.
I added the information in the message above
Tomorrow I will have access to the cli and I will add it to the driver
Hi,
Version 2024-04-19T19:34:25.428572617
- id: "TS0004/_TZ3000_imaccztn"
deviceLabel: ZG-005Rf Four Switch
manufacturer: _TZ3000_imaccztn
model: TS0004
Works perfectly, thank you!
I appreciate your fast response ![]()
You can create child devices and rename and locate them as you want
There is no option for switch 1 for child device, just 2,3,4 and all.
Switch 1, main, with a simple mosaic you can rename it whatever you want and place it wherever you want
The labels of the multiple tiles cannot be modified by the user, only can rename switch-1, main
Understood!
Thank you ![]()
@Mariano_Colmenarejo
When I create child switches, I can set them lights but the main one canβt be set as light!
I tried them with another multi switch and the same bug exist.
