I’m not sure where this device belong to, but it is a 3 gang switch where in the DTH world it has child switch. I hope you can add it so it will appear as 3 individual switches which I can assign each to adifferent room
@Mariano_Colmenarejo can you add support for the Aqara Dual Channel Relay LLKZMK11LM into this driver?
The only available driver for it llkzmk11lm does not support the creation of Child Devices like yours does…
I don’t care much about power metering, I was using the Smartthings native Zigbee Dual Switch DTH with these relays for years without any problems… I just need to be able to treat the 2 channels as 2 completely separate devices (for grouping into different rooms, for Google Home integration, many other things)
I would really appreciate if you can add the fingerprint to your driver & let me know how I can support. I’m not very competent with Edge yet (haven’t even accessed the CLI yet) but I’m ready to learn quickly & support…
Added to this driver version
only switch-1 (main) are power meter
Name Zigbee Multi Switch and Child Mc
Version 2023-05-22T11:29:59.240391846
- id: "LUMI/relay.c2acn01"
deviceLabel: LUMI Double Relay
manufacturer: LUMI
model: lumi.relay.c2acn01
deviceProfileName: two-switch-power-1
@Mariano_Colmenarejo thank you so much, it took a day or so to reflect on my hub for some reason, but once it did, it worked like a charm…
Now I have another ‘dumb’ question - I have 20 similar relays in my home already, installed & connected to the Hub via the old DTH & working fine. Is there a way to force migrate them to your driver without having to delete & re-add them?
Keep in mind that 20 relays = 40 devices, and God knows how many rules
Also they are installed inside wall switches, so lots of screws to undo just to hit that pairing button
I’ve searched the forums & generally online, can’t seem to find an answer…
Yes that’s an option but the problem is that I doubt the Child devices will be created automatically & remain within the lighting groups & automations…
Anyway this saves me the physical part, unscrewing the wall switches to re-pair. Thanks.
Here is a smartthings post with a section dedicated to the migration of devices that do not use stock DTH and can migrate to a community-created Edge driver if it is already installed in the Hub and the driver is compatible with the device.
Yes I am familiar what happens when a device is deleted…
I hope they replace them with ‘things’, then I can at least re-configure only the condition/action after properly replacing them with a new child device from your driver…
BTW, I was not using a custom DTH with these, I was using the Smartthings ‘Zigbee Multi Switch’, which is marked in bold in the list on this post List, not sure when they were added…
Anyway thanks for the help. Seems the best approach is to just wait.
Yes correct. That’s why they stayed as DTH. now that I have a community Driver with the right fingerprint, will they be migrated? as I understood from the post you shared it should be yes… but what’s not clear is the child devices, for that will wait & see…
Hi all, Just wondering if anything changed in the last day or so ? I have 5 Tuya zigbee 3 plugs that i have been using with this driver for 3 or 4 months now with no issues. Yesterday they all stopped working. i tried all kinds of stuff and rebooted the hub etc etc. eventually I downloaded another zigbee power EDGE driver from smartthing Drivers (BETA) and that now works fine for all the plugs. Just wondering what changed in the last couple of days ?
