Please update main app to Version:4.0 R.0.0.1a and give it another try. Thanks for reporting the bug!
Will give it a try and let you know
That worked. Thank you. Looking forward to taking a run at this.
Glad it worked, let us know what you think about it or how we can make it better. Have fun playing!
Everyone make sure you check back on the wiki every so often. Itās a work in progress and Iām really focusing on it over the next couple of weeks⦠There will be use cases, how toās, and much more on thereā¦
please send me your ideas and Iāll put them in there!
Pushed an update for both the Main App and the Profile app:
Note: general bug fixes and reliability improvements:
Version:4.0 R.0.0.2 (Parent),
Version:4.0 R.0.0.3 (Profile)ā¦
Iām a little confused on the installation part. I got the parent app installed but I am confused as to which āchildā app to install for the minimum requirement. Which profile app is it?
Or should I just install all of them?
The Profiles is requiredā¦to enable messaging and Profiles group conrrol
And then you have (optional)
the Notifications Add-on if you want to receive alerts on remote speakers
And the Security Add-on, mainly if you use keypads with your SHM
Thank you very much for the fast response as always. Iām sure Iāll have more questions down the road.
Just drop a line any time. Jasnoās phone and mine will buzz, so we will be around lol
PAGE NOT FOUND IN LINK
- At this point please follow this link To the GitHub Repository for the EchoSistant
Lambda Software. https://github.com/BamaRayne/Echosistant/blob/master/smartapps/bamarayne/echosistant.src/echosistant-lambda.js
You will follow the exact same steps as you did when you installed the EchoSistant Code in the IDE.
Once you are in GitHub click on the RAW button, highlight and copy the code from this page. Navigate back to the Lambda
page and paste your code into the section as shown below:
ooops⦠Iāll fix that now!
thanks!
Fixed it⦠thanks
Thank you.
Wellā¦
I guess itās time for me to drink the Kool-Aid and install this.
Alexa, order some Kool-Aid.
Cheers! Let us know what you rhinkā¦
Is that combination of ādrinkā and āthinkā ?
bout time!!!
I found it here but that link is also broken.
