Cannot find "My Testing Devices" on smartthings app
for “Cloud Connected Devices”
I tried:
  1. Create a schema apps in “Schema cloud connector”
  2. Add a Device profile named “Light”, has 2 additional capabilities: “Switch”, “Switch State”
  3. Install SmartThings app from Play Store
  4. Enable debug mode in app and restart app.
  5. Add Device - Partner devices
  6. there’s no “My Testing Devices” on “Recommends”, or elsewhere.
Does it look like this in your app?
Hi, @hspark. Welcome to the SmartThings Community!
You mean you enabled the developer mode here, correct?
These are the steps:
If so, and you still don’t find the option:
  1. Are you using an iOS device?
  2. Did you recently create your account?
We saw a report about this happening on iOS when the account was recently created, but that should have been solved so, we can verify that’s the issue if you test this on an Android device.
Yes, developer mode… is enabled.
issue seen on android os (galaxy s10), and I retried on ios (iphone 15 pro), it’s same.
my samsung account created some years ago.
Hi, @hspark
Ok, so please provide the following information to report this to the engineering team:
  1. Screen recording of you entering Add device > Partner devices
  2. Then collect the app logs as follows (these steps only work for Samsung devices):
    1. Go to the “phone/calls” app on your Android phone
    2. Dial *#9900#. It will open the Dump sys
    3. Choose RUN DUMPSTATE/LOGCAT and wait for it to finish
    4. Then, select COPY TO SDCARD(INCLUDE CP RAMDUMP), it takes some time as well
    5. Connect your phone to a computer (USB cable)
    6. Open the device (phone) in the file explorer to see its content
    7. Find the log folder and look for the text file whose name is similar to “DUMP_STATE_G93FXXU1DQJ3.DM_202508261516”
      The last value is the current date and hour, which helps you identify the correct folder.
    8. Copy that file to the computer and share it with us at build@smartthings.com
    Note: You can also send the file directly from your phone, but it can be hard finding the file due to its long name.
  3. Open support access to your account as follows:
  4. Confirm the email account registered in the forum is the same one you use for SmartThings. If not, please share it with me over DM.
  5. Enable support access to your account:
More info about this access here: https://support.smartthings.com/hc/en-us/articles/36170233944852-Enabling-Account-Data-Access-for-Support
Solved it.
the reason is not registered a “Product”.
I wondering about is it necessary for C2C linkage….
Thank you for letting me know. According to the documentation, it says we need to register the products we would like to test: Test Your Schema Integration | Developer Documentation | SmartThings
But I’ll double-check with the team, and if this is an expected condition, we’ll improve the documentation.
