Announcement | SmartThings Edge for Devices and Automations
@Paul_Oliver, told me that he was using my channel’s zigbee motion sensor Mc driver, which is a modification of the original, with temperature reporting settings and it worked fine for him.
In case you want to try it
I’m trying to setup ST dev env in my macOS High Sierra & need some help as I can’t really follow the over simplified guide.
I followed instruction from smartthings-cli, Step 1. Download the binary from releases tab of the github page, in the page, I saw the Assets section, expend the section, downloaded smartthings-macos-zip.
Different from Step 2, after download, I expend the file, I got an executable file with the name “smartthings”. (not sure why the github step 2 say install it and rename to smartthings, probably not updated).
I move it to a folder call “st_edge”, go into command prompt, navigate to the “st_edge” directory, Following step 3 on the “smartthings-cli” github page, fire the command “smartthings --help”, response is “command not found”.
So what did I missed?
To execute a binary in the current working directory on a Unix system you’ll need to add ./ (dot slash) before the binary name. So to execute the smartthings command in that directory run ./smartthings
This page summarizes some of the history on why this particular bit is required (it’s security related). Linux FAQ: Why Do We Need a Dot Slash Before a Local Command | MangoLassi
Thanks for the very swift reply Paul, that work. Will be good to have someone update the github readme, so less people get stuck at the 1st 3 steps.
Thanks for the ./ FAQ :slight_smile:
Working well for me as well
Where did you find that driver for the ZEN30? Does Zooz have an edge channel?
@nayelyz @erickv
What is the status regarding Edge support on wifi hubs? I’ve had a couple people unable to get one of my drivers to work: it can’t seem to create a (virtual) LAN device as a result of an Add device / scan nearby. Is this a known issue?
Our team is aware of some behavior that is preventing some Edge functionality on the Samsung Connect Home and SmartThings WiFi devices from working as intended. We are working on correcting this behavior and hope to have it resolved in a future firmware release for these devices.
OK thanks Nayely!
Inovelli has posted some beta drivers:
Where we can subscribe to their channel?
I don’t think that you can
I just created a private channel. It’s working fine apart of minor bugs with colors.
@Rafael_Borja Can you share it, please
LINK FIXED
Here you go: (please not that’s a very beta personal channel)
https://bestow-regional.api.smartthings.com/invite/Nxlw9BxXYKMA
Best regards!
From Eric Maycock:
I’m getting used to the new development process, so I’m not sure if these URLs will be for the final version, but . . .
LZW30/LZW30-SN
SmartThings. Add a little smartness to your things.
LZW31/LZW31-SN
Try it out and let me know how it goes.
I don’t think notifications are supported yet.
@Bry @Eric_Inovelli looks good to me
Is Inovelli Dimmer NZW31 w/Scene supported by this driver?
Here is the thread:
